Reply 6360 of 32070, by bjwil1991
- l33t
I tested and repaired the following I got during my thrift store adventures:
Yamaha PSS-460 <-- found the missing plastic pieces associated with the Note B key that was loose and wouldn't stay in and was higher than the rest, super glued the pieces in the right spots, put the key back in, reassembled the keyboard, and viola. The key works and I thought it was dust. NOW it's 100% functional once again. Worth it.
Tri-pod for my video camera <-- screwed in the surface mount to my video camera, and I tested to see if it'll swivel around (up, down, left, and right) and it works 100%. Totally worth the $2.99
Apple Pro Keyboard <-- Hooked it up to my iMac G3/600 to use as the correct keyboard, and every key is working. I'm even using my iMac to type this up right now. It has 2 USB ports, one of them is occupied by my scrolling optical mouse, and the other one would be for a USB light so that I can type at night without using a lamp or a light above me. Totally worth the $3.95
The Adventures of Wallace and Gromit <-- Plays back beautifully and the quality is superb.
