Reply 220 of 318, by dexvx
wrote:wrote:It is clear winner in High Polygon Count (1 light) test, I give it that, but it lost in 8 lights test and barely have any leads in 4 lights test.
PS. Also TNT2 isn't a GeForce.I think something is going wrong with 3DMark2000 on that system. The results just aren't right. Fillrate for the GeForce is way off the mark. It should not be less than any TNT2. The GeForce is only showing about 25% of its potential...
You realize he's using his super rare 64-bit SDR NV10? The TNT2 Pro has over double the memory bandwidth available.
