First post, by u1comp1
How to make the Kkrieger run on the fullscreen in the resolution 1920x1080 ? This game runs all the time in the resolution 1024x768 (Win 10 x64).
Reply 1 of 6, by kolano
It's out of the demo scene and likely uses a umber of odd compressions on the executable, that will probably make it hard to do any edits to the exe. Perhaps something to update some of it's memory values when run, but I'd guess that would also be a pain.
Eyecandy: Turn your computer into an expensive lava lamp.
Reply 2 of 6, by stranno
This game was insanely small back in the day considering the graphics.
Reply 3 of 6, by leileilol
Also per-pixel shader-based lighting at 1024x768 was considered a high-end luxury for 2004...
Reply 4 of 6, by bakcom
Sure, that was the whole idea.
Reply 5 of 6, by kolano
I think Farbrausch published the code here...
https://github.com/farbrausch/fr_public/tree/ … kzeug3_kkrieger
...I'd guess some tweaks could get it integrated into their later demo tool based on the same code...
https://github.com/farbrausch/fr_public/tree/ … ster/werkkzeug3
...which has all the GUI for resolution selection and etc.
Reply 6 of 6, by u1comp1
You can specifically say that you need to fix the game in order to increase the resolution ?
