Reply 6420 of 27457, by appiah4
- l33t++
wrote:wrote:Finally got around to installing FastVoodoo 4.6 drivers on my SLI system and the mismatched cards work perfectly. […]
Well, sort of.
They work perfectly at 640x480 and 1024x768 but at 800x600 everything has a red-ish hue.
Strangely enough, even the id logo intro of Quake 2 seems to suffer from the issue when launched with the -gl_mode 4 parameter.
No idea why, it might be some quirk with the TV it is connected to, I suppose. As far as I'm concerned, this is a success. Playing Quake 2 on an MMX at 1024x768? Checked and off my bucket list..
Try installing the overclock util. I bet it is running at some 93/95mhz.
Try setting it to 90 and test. Lower it by 1, for each test.
Oh shoot, I completely forgot about the default overclock in the FV drivers! I'll do that first thing next time I check it out.
Also, has anyone ever gotten Descent 2 D2_3DFX to work with SLI I wonder..
