Reply 18540 of 58211, by bjwil1991
DaveJustDave wrote:
Picked up a Tandy 1000SL for $20. need to clean it up before i try booting it. A bit dirty and missing a rubber foot (anyone k […]
Picked up a Tandy 1000SL for $20. need to clean it up before i try booting it. A bit dirty and missing a rubber foot (anyone know a good source for these?) but otherwise ok.
Has another interesting hard card design inside. it's an 8086, so i wonder if the drive is ATA or XTA? hmmm
Wow. That system is in great shape. And for $20? That's a great price. On eBay, those systems are going for an arm and a leg, especially the broken ones.
Reply 18541 of 58211, by TheAbandonwareGuy
Why would a broken system be worth more? That makes zero sense at all.
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 18542 of 58211, by Jade Falcon
Rank BANNED
BANNED
Not the best wording I'm guessing. I think he means even broken systems go for alot.
Reply 18543 of 58211, by ODwilly
Picked up a free Pentium II 300mhz Dell Latitude 7000 laptop. 64mb Ram onboard with TWO empty ram slots. Have both an pair of 256mb,128mb,and a 512mb compatible ram stick for it 😁 even came with a 8gb ide drive with a windows 7 install from another machine! It is mostly tooless deconstruction and even has an easily removable vga card!
Reply 18544 of 58211, by brostenen
Munx wrote:
My haul from this Sunday, everything 2 euro-doubloons each!: […]
Yamaha YM724 sound card. Already have one, however the other one didn't have an SB link soldered and for this price it was hard to pas it up
Cirrus Logic GD5446. Will make a nice replacement for my S3 Virge cards as the ones I have suffer from poor blackness levels
Aopen MX34 motherboard (VIA Apollo Pro133A chipset) with 1999's fastest CPU - P3 800.
OAK OTI-067 ISA VGA card with 512KB memory. Should come in handy if I ever manage to get a 386 build going. The tilted capacitor on the bottom needs to be replaced.
CL-5446 and YMF-724... Sweet... 😜 Those models are some of my favorite hardware. Awesomme.
Reply 18545 of 58211, by badmojo
Cyrix200+ wrote:
Heh, a litte bit off-topic here, but I was checking my 486 boards and found this 'cache' on one of them. Looks legit!
Classic! When you think about how dishonest that is it's incredible - some jerks sat around a boardroom table and agreed to blatantly rip off their customers with IC shaped chunks of plastic. It really was the wild west.
Reply 18546 of 58211, by cyclone3d
Have a couple PCI Quadro FX 600 cards on the way.
And a few very important (can't build systems without them) parts.
I found out that almost all of my old ATX power supplies are dead/need recapping so I ordered 4 Seasonic units. 1 400w which turns out was really a 500w (SS-500ET) so I got a free upgrade and 3x 350w (SS-350ET)
as well as 3x 24-pin to 20-pin with -5v added.
Going to have some fun when the PSUs get here.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 18547 of 58211, by bjwil1991
Got a VooDoo3 3000 PCI Card in the mail with its original box, manuals, and driver/software CD. Can't wait to install it in my K6-2 system.
Reply 18548 of 58211, by appiah4
Grabbed this Dell Optiplex GX110 system (upgraded with some ATI PCI card, hopefully a Radeon 9100 or 9200, but more likely a Radeon 7000 or Rage 128..) and its Philips 105S monitor for $10.
It also came with an unassuming terribly yellowed keyboard that turned out to be an AT102W mechanical with Alps switches.
Now, I need to retrobright those caps somehow.. Never did this before 😒
Reply 18549 of 58211, by DaveJustDave
holy smoking coffee drinking grandma's teeth those are yellow! 8bit guy on youtube just did a comparison amongst several different retrobrite methods..
appiah4 wrote:
http://image.bolterandchainsword.com/uploads/gallery/album_11505/med_gallery_60983_11505_332358.jpg […]
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
Reply 18550 of 58211, by luckybob
And the TL;DR from his video and my own personal experience;
Just use that cream with the 40 on it, put it in the sun and wait.
Reply 18551 of 58211, by DaveJustDave
although the ozone generator idea is interesting! his results might have been much better if he was feeding ozone continuously into the bag.
imagine being able to do an entire monitor without taking it apart!
Reply 18552 of 58211, by cj_reha
I have recently come in contact with a guy who works as a scrapper in Colorado. The particular junkyard he works at does not separate computer parts, and consequently he has pallets and boxes of old parts and towers. He recently sent me these two AT towers, and I've had a lot of fun with them. Both need a cleaning and have minor issues (the right one does not find the CD drive in BIOS) but they both work fine so far 😀
Left: "Magtron" branded mini tower. Interestingly, has a keyboard port in the side panel.
CPU: Intel 486DX2-66
RAM: 32 MB 30-pin SIMMs (8 x 4 MB)
Motherboard: Shuttle HOT 409
Video Card: Cirrus Logic CL-GD5426-80QC-A 1 MB VLB
Sound Card: ExpertColor MED3931 (OPTi 931 chipset)
HDD: Seagate 260 MB
Optical: Matsushita 8X
Floppy(s): Teac 5.25" & 3.5"
OS: Windows 95
Right: Generic AT case with a sliding door. Neat design
CPU: Cyrix 6x86-P166+GP (133 MHz)
RAM: 16 MB 72-pin SIMM (2 x 8 MB)
Motherboard: Amptron PM-8800A (PC Chips re-brand)
Video Card: Matrox Millennium 4 MB PCI
Sound Card: Sound Blaster 16 ISA
HDD: WD Caviar 2.1 GB
Optical: Acer 10X
Floppy(s): Teac 3.5"
OS: Windows 95
The generic case's OS is pretty broken; missing system files and really slow. I plan to wipe it and reinstall. The 486's install is actually quite clean and snappy, so I will keep it like that. I had to remove a barrel battery that had not yet corroded the board but an external battery is also connected and it seems to hold settings for a few hours.
Both are fun to play with, and I've recently got word the guy got ahold of a 486SX desktop, so I may break the bank and buy that one too 🤣
Reply 18553 of 58211, by SaxxonPike
The attachment IMG_20170823_163747.jpg is no longer available
Got an AWE32 I can finally use. Rev 1 CT2760. These things are huge, holy cow.
Sound device guides:
Sound Blaster
Aztech
OPL3-SA
Reply 18554 of 58211, by .legaCy
yes i watched this episode of 8 bit guy and the ozone generator seemed to be promising, aswell as the heating method.
Reply 18555 of 58211, by luckybob
honestly he is over thinking the ozone thing. some wood and a few panels of glass/plexiglass and a tube of silicone. you can then build a hotbox for the process.
hell you can probably just use an old aquarium with a tight lid to do the same thing.
Reply 18556 of 58211, by DaveJustDave
that's not a half bad idea.
someone needs to market a dedicated mess-free retrobrite chamber. put your stuff inside, plug it in, and leave it out in the sun until it's 1985 again.
Reply 18558 of 58211, by hard1k
HO HO HO
This year Santa has visited me rather early, and I must have been a really good boy as he brought me a complete-in-box Creative 3D Blaster VLB - with all original accessories, tested and fully working 😀
Please have a look at the pictures taken by the previous owner (actually I haven't found any pics of the complete package on the net, so I could easily be the first one to upload them here):
Of course, in order to preserve the mystery the conditions of the deal will be kept confidential.
I guess I'll have to take on the quest for the unobtainable RAM upgrade module - has anyone actually seen one of those out in the wild? Any picture / part number / anything else?
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 18559 of 58211, by Stiletto
Ah, man. Lucky!
do the Fandango!" - Queen
Stiletto
