I took the 3dfx flash V2.17 program and the regular VGA BIOS 1.15 from this site https://3dfxbios.cl-rahden.de/index.php?title=Voodoo4
I followed the flashing procedure but I received ane error message saying that the EPROM chip is not supported by the flash program...DAMN.
1. I put in a folder on the HDD, C:\V4\ , the 3dfx flash 2.17 kit composed from the following files flash.exe, dos4gw.exe and readme.txt
2. In the same folder I also put the stock VGA BIOS V1.15 from the site above which I renamed to V115.rom
3. I booted into DOS and from the folder I launched flash.exe v115.rom
4. I selected from the list the V4 card: 1
5. The flash procedure couldn't continue because the EPROM chip wasnt supported....Error: Unknown flash EEPROM manufacturer. (Man. ID: FFh, Dev. ID: FFh)
The README.TXT from the 3dfx flash, versions V2.13, V2.14 si V2.17 clearly states: "The following flash parts are supported: AMD 29010, ATMEL 29010, ATMEL 49F010, SST 29EE010, SST 39SF010 and Atmel AT49BV512." I only tried the V2.17 and because the README.TXT listed the same supported chips I didnt bother to try another version. Only V2.XX are for the V4 and V5.
My card has the EEPROM CHIP: SST 39VF512 / SST39VF512 / SST MPF 39VF512 90-3C-NH 0014159-D UU002
It seems that the EvilKing is all bark and no bite...aka KAPUT.
I tried to do a copy of the bad VGA BIOS with the dumpbios.exe/dumpbios64.zip program but I couldnt select the card PCI or AGP and the program made only a copy of the S3 VGA BIOS.
http://3dfxbios.stantoworld.co.uk/
I found two sites from 2007 in which a guy with a v5 5500 PCI with the same EEPROM BIOS chip had the same problem. Even back then it couldn't be solved, so my hopes of recovering my card have gone up in smoke...
http://www.modlabs.net/forum/topic/10947/
http://www.david-baum.de/board/index.php?page … &threadID=13324
I might remove the BIOS chip and try to reprogram it using a BIOS programmer but I'm not going to do this anytime soon. I need a good soldering/hot air station and a BIOS programmer. At the moment I dont have any of these. Another solution would be to use a EEPROM chip with better support. Good luck finding that... After this experience I think it is obvious that a stock V4 VGA BIOS file wouldnt run on this card. I would need a PowerColor EvilKing IV VGA BIOS file which is hard to find.
In all the 3dfx flash kits I searched I found files that had the same date, size, MD5 / CRC32. I dont think that I'll find a flash program to support my chip SST 39VF512 . All the README.TXT files list the supported EEPROM chips as: AMD 29010, ATMEL 29010, ATMEL 49F010, SST 29EE010, SST 39SF010 and Atmel AT49BV512.
I still need a VGA BIOS file for my V4. If someone has it maybe he can send it to me.
Thanks in advance.
