Reply 18860 of 57467, by appiah4
Sapphire Radeon DDR 7000 PCI for my Optiplex GX110 project.. This is a backup, in case the G450 I got turns out to be a dud (or I decide to scrap the idea of MS-DOS and OS/2 on the thing altogether..)
Reply 18861 of 57467, by Srandista
As I was saying few days ago, mystery package shows on my door bell today. Behold, X800 Pro VIVO AGP 😀
This is the version, which came form factory with 12 pipelines activated, but only because of BIOS. I will be flashing X800 XT PE BIOS, once I test, that it can handle higher frequencies 😎
Oh, and btw, I must say, that I never receive anything warped in paper towel, let alone some PC hardware 🤣
Reply 18862 of 57467, by tikoellner
I want to share with you my today's purchase (seller photos):
IBM XT/286 (5162).
From what I can see it's equipped with IBM EGA card with memory expansion daughterboard. Pretty rare!
Reply 18863 of 57467, by luckybob
@tikoellner
I hear the XT/286 can be a rather uncommon and expensive machine.
Reply 18864 of 57467, by xjas
^^ Well, you learn something new every day. In my mind, "XT" meant "8088" and "286" meant "PC/AT." Madness.
Reply 18865 of 57467, by tikoellner
Yes, it seems very rare. As I read, only 20.000 were ever made. So when I spotted one listed locally, I decided to bid. I finally bought it for ~120USD equiv.
I don't know if it's working. Externally it looks pretty OK. I have a spare XT case if necessary.
I will also try to upgrade it:
1) I already have AST 286 Rampage card I will try to use;
2) I guess I will put Creative Sound Blaster 1.0. inside. I also own PAS 8 bit, but it does not seem to be period correct - what do you think?
3) I will consider both EGA and VGA card. But will probably keep original IBM EGA adapter (have two of them) as this one has this neat expansion board.
Reply 18866 of 57467, by tikoellner
Yes, I thought so as well. I think those XT/286 were replaced by AT (5170) very quickly - and that's the reason they're so rare.
Here you can see the motherboard:
http://www.classicpc.nl/img/p/87-212-thickbox.jpg
Thankfully no battery onboard!!!
What is VERY interesting, XT/286 is said to be FASTER than IBM AT 5170, due to zero wait state memory.
Reply 18867 of 57467, by xjas
Picked these up for my VR machine over the last couple days. I didn't really need the CRT but I like how it's kind-of color matched.
The attachment 1.jpg is no longer available
The attachment 2.jpg is no longer available
It's a nice one too, the detachable VGA cable makes it a little more manageable to lug around.
I've said in the past that I'm a big fan of the picture of late (2000-2005) generation CRTs, and that's true, but I will concede that LCD panels are a better technology. 😜 This thing is heavy, and it takes a ton of space. How the hell did I lug a 21" SGI monitor around to LAN parties when I was a teenager?
The attachment 4.jpg is no longer available
Speaking of LAN parties, it's great to have these! The Wingman Extreme was my go-to stick when I used to play the competitive Descent circuit back in the day. I seem to remember breaking several of them before switching to a Gravis Firebird II, but fortunately this one is in great shape. The Wingman Original's trigger button doesn't work but I bet I can fix it.
The attachment 3.jpg is no longer available
Incidentally the monitor had a bunch of little velcro circles stuck (HARD) to it for some reason. Can you tell there was one here?? 😜
Reply 18868 of 57467, by Pabloz
everything for 20 dollars, + an acer socket7 motherboard + voodoo2 vga cable + voodoo2 sli cable
one card looks like
FCC: ICUVGA-GW803N
P/N: 9803-20N
Gainward Dragon 3000 12MB Voodoo2
the other card looks like
600-0027-03
Trust Skywell Voodoo Dragon 2 Magic 3D II 12MB Voodoo2
but its not black, and it says voodoo2 version3, and the memory is 110mhz, same design as innovision, maker is so far unknown
there is a matrox powervr card without any output that i dont know what the heck it is
Reply 18869 of 57467, by lazibayer
Pabloz wrote:
everything for 20 dollars, + an acer socket7 motherboard + voodoo2 vga cable + voodoo2 sli cable […]
one card looks like
FCC: ICUVGA-GW803N
P/N: 9803-20N
600-0027-03
You have a good sense of treasure. The power vr card is probably worth the combination of the two voodoo2 cards. Super rare. It's a competitor of voodoo1 and it doesn't use pass thru cable.
You can find its drivers at matrox.com under the name m3d.
Reply 18870 of 57467, by xplus93
one card looks like
FCC: ICUVGA-GW803N
P/N: 9803-20N
600-0027-03
Holy sh*t, that's a good deal. How did you score that one?
XPS 466V|486-DX2|64MB|#9 GXE 1MB|SB32 PnP
Presario 4814|PMMX-233|128MB|Trio64
XPS R450|PII-450|384MB|TNT2 Pro| TB Montego
XPS B1000r|PIII-1GHz|512MB|GF2 PRO 64MB|SB Live!
XPS Gen2|P4 EE 3.4|2GB|GF 6800 GT OC|Audigy 2
Reply 18871 of 57467, by Pabloz
pure luck
there was a guy selling a box full of old hardware. he was thinking about getting 100 dollars for it.
he did the auction, but i offered only 20 bucks, 6 days passed and nobody else offered for the box , and i won it.
didn´t know these were worth so much, i saw the matrox m3d card for 150dollars on ebay? what a crime.
Reply 18872 of 57467, by Jade Falcon
Rank BANNED
BANNED
Looks like the fly back plug zapped the casing on the CRT 😲
They could have ad a web cam or something stupid suck to the top of the casing. But who knows?
Reply 18873 of 57467, by hard1k
LaCie displays were intended for the publishing and design, so they had a special hood against the sunlight:
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 18874 of 57467, by cj_reha
Found what I thought was an old PC at the thrift store, turned out to be just another generic s478 P4. Oh well. It was $10.
If specs on inside of side panel are to be trusted, its a P4 2.4ghz/512mb ram/radeon 7000 32mb agp/msi 845e max2 mobo. currently having an issue where the board is completely dead (fans don't even spin, even with tested PSU) so I'll probably part it out and chuck the mobo in my ewaste pile.
Reply 18875 of 57467, by TheAbandonwareGuy
You've got a case and a 52x CD ROM if nothing else.
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 18876 of 57467, by cj_reha
Yeah, chucked the board into my ewaste box. Completely dead even with reseated everything, different PSU, etc. Oh well.
The case is pretty damn nice though, probably gonna peel off the Pentium 4 sticker and use it with a slot 1 build.
Reply 18877 of 57467, by luckybob
No. Fuck that case. I hate those damned enlight cases with a burning passion. No case has ever cut me more than these bastards.
I would have happily paid $10 to go full office space on it.
Reply 18878 of 57467, by cj_reha
🤣 I will admit it's got a shitty design where you have to tear the front panel off to slide off the panels, but it isnt as bad as my Enlight AT case. THAT bastard has given me a ton of cuts.
Reply 18879 of 57467, by probnot
I have that case. Hasn't cut me, but I don't like the stupid rails needed to mount drives. Especially since I don't have them...
Also, I'll take removing the front to slide one side off vs sliding the whole cover off (like those P2 era InWin cases)...it jams up, or doesn't line up every time!
