Quake III Arena Benchmark Thread
Reply 80 of 222, by Fusion
Beat my last score! I don't think I can milk this system anymore, a 0.4fps jump is pretty good considering I didn't overclock higher or change any hardware:
52.0 FPS, Fusion, Voodoo3 3000 16MB PCI @ 195/195, Pentium III 800EB, Intel i810e, 384MB PC133, WinMe
EDIT: Modifying cg_lagometer, and changing the value to 0 in your q3config gets you an additional .5fps. You're welcome. 🤣
Pentium III @ 1.28Ghz - Intel SE440xBX-2 - 384MB PC100 - ATi Radeon DDR 64MB @ 207/207 - SB Live! 5.1 - Windows ME
Reply 81 of 222, by dottoss
falloutboy wrote:
Makes a big difference on my Super Socket 7 system. Have not testet with others. 44.8 fps with sound ; no a3d sound 62.9 fps wi […]
leileilol wrote:
(some "pro" players also alleged the sound system in Q3's also slow, though i don't feel that's true first-hand)
62.9 fps without sound
Quake3 1.32 with custom settings (quite low)
demo four
K6-III+ 550MHz
Tyan S1590
GeForce3-Ti200 Det. 14.10
Vortex 2
Win98SE
In Quake 2 it's only 5% difference on that system.
Oh yes, it makes a different. All the professional benchmarking people used to disable the soundsystem when benching GPU and/or CPU back in the days when Q3 was used for that purpose 😀
Without sound = s_initsound 0, then snd_restart = 592 FPS.
The attachment quake3.jpg is no longer available
With sound: 10. 486.6 FPS, dottoss, Geforce 6800 Ultra (AGP), Intel Pentium 4 EE 3.4 GHz Gallatin, Asus P4C800-E, 1GB DDR 400 CL2-2-2-5, WinME
When running with sound, setting the quality of the sound from low to high and vice verse will affect FPS, a lot.
Reply 82 of 222, by silikone
Purging an integral part of a game seems counterproductive for what is the go-to real-world performance benchmark, no?
Do not refrain from refusing to stop hindering yourself from the opposite of watching nothing other than that which is by no means porn.
Reply 83 of 222, by dexvx
Most all in-era benchmarks for Quake3 disabled sound.
Back then it was less about real world performance and more about raw hardware performance. The timedemo's themselves are not very real world because there is only a set number of frames being rendered each time (thus 100 fps goes super fast).e
Reply 84 of 222, by Fusion
It's insane to think that I've been benchmarking Quake 3 for over 17 years! 🤣 This is sad. Obviously not everyday but still. 😮
Reply 85 of 222, by lazibayer
lazibayer wrote:
Just for laughs... 2.7 FPS, Rage Pro AGP 2x 8MB, K6-3+ 450 OC 133x4.5=600, 256MB PC133 2-2-2, P5A-B, Windows XP, stock driver, 1 […]
Just for laughs...
2.7 FPS, Rage Pro AGP 2x 8MB, K6-3+ 450 OC 133x4.5=600, 256MB PC133 2-2-2, P5A-B, Windows XP, stock driver, 1024x768, 16bit color, 32bit texture.
17.8 FPS, Rage Fury (128GL) 32MB, K6-3+ 450 OC 133x4.5=600, 256MB PC133 2-2-2, P5A-B, Windows XP, driver version 6.13.3279, 1024x768, 32bit color, 32bit texture.
26.5 FPS, FireGL2 64MB @PCI mode, K6-3+ 450 OC 133x4.5=600, 256MB PC133 2-2-2, P5A-B, Windows XP, driver version 6.12.10.2106, 1024x768, 32bit color, 32bit texture.
OC'ed the Rage Fury from 103/103 to 125/154 and scored 24.7 FPS. Powerstrip can only support upto 154/154 on this card. Surprisingly the 8ns memory works pretty well at 154MHz, while the core crashes at 127MHz.
Reply 86 of 222, by Standard Def Steve
My Win98SE installation recently crashed and burned. Now that I've got Win98 reinstalled, my Celeron/V3 system is actually performing better than it used to. I'm guessing it's because this time I'm using DX7a and official 3DFX drivers (last time I used DX9c and AmigaMerlin drivers).
New result:
Celeron-1400, 440BX, 512MB PC100, Voodoo3 3000 AGP, Aureal SQ2500, Win98SE: 46.4 fps
"A little sign-in here, a touch of WiFi there..."
Reply 87 of 222, by lazibayer
Continuing the stretch of oldware...
3.1 FPS, Intel i740 8MB, K6-3+ 450 OC 112*5.5=617, 256MB PC133 2-2-2, P5A-B, Windows XP, 5.1.00.1404 driver for w2k, 1024x768, 32bit color, 32bit texture.
Although both using OpenGL -> D3D wrapper i740 is faster than Rage Pro and also has better image quality. Under 112*5.5 Rage Pro only scored 2.5 FPS and it was under 16 bit color. Why didn't I put i740 under 133MHz bus speed? Because it won't boot into windows at all.
Reply 88 of 222, by SPBHM
well, still more than 1 frame per second!
K6-2 533, VIA MVP4, 128MB PC97, Trident Blade 3d IGP, ESS onboard, Win98SE: 1.7 fps
even the menu feels like it runs at 1FPS, if I lower everything it's kind of playable at low res, over 20FPS
Reply 89 of 222, by vlask
Testing something quite rare, so tried Q3 too.
Trident Blade XP 32MB AGP clocked at 166/166MHz - 11FPS
Tested on Athlon XP 2200+, Soltek SL75-KAV (Via KT133A), 512MB SDR CL3
Not only mine graphics cards collection at http://www.vgamuseum.info
Reply 90 of 222, by lazibayer
0.7 FPS, SiS 530 IGP, IBM 6x86L-PR200 OC 100x2=200MHz, GA-5SMM, 256MB SDRAM, XP SP3, PCI mode, 1024x768x16bpp color, 32bpp texture.
Reply 91 of 222, by W Gruffydd
Thanks for the benchies.
Wasn't the DDR version of GeForce 256 released in 2000, though?
My list of wanted hardware
Reply 92 of 222, by Putas
That is probably only Blade T64, right?
Reply 93 of 222, by Standard Def Steve
Core i5-3470 @ 3391, B75, 8GB DDR3-1600, Intel HD 2500, onboard audio, Win7-64: 400.7 fps
Reply 94 of 222, by Standard Def Steve
And here's the same machine with a GTX 560 installed:
Core i5-3470 @ 3391 MHz, B75, 8GB DDR3-1600, GTX 560, onboard audio, Win7-64: 977.2 fps
Reply 95 of 222, by dexvx
Late 1999. Like literally last week of December.
Too bad the FX 5800 Ultra didn't make the cut into 2002.
Reply 96 of 222, by lazibayer
31.7 FPS, FireGL2, P4 1.3GHz, Dell Dimension 8100, 1GB PC800 RDRAM, XP SP3, 1024x768x16bpp color, 32bpp texture.
31.7 FPS, FireGL2, P4 1.3GHz, Dell Dimension 8100, 1GB PC800 RDRAM, XP SP3, 1024x768x32bpp color, 32bpp texture.
33.0 FPS, FireGL2, P4 HT 2.8C, Dell GX270, 1GB DDR400 DC, XP SP3, 1024x768x16bpp color, 32bpp texture.
33.0 FPS, FireGL2, P4 HT 2.8C, Dell GX270, 1GB DDR400 DC, XP SP3, 1024x768x32bpp color, 32bpp texture.
33.0 FPS, FireGL2, P4 2.8A, Dell GX270, 1GB DDR400 DC, XP SP3, 1024x768x16bpp color, 32bpp texture.
33.0 FPS, FireGL2, P4 2.8A, Dell GX270, 1GB DDR400 DC, XP SP3, 1024x768x32bpp color, 32bpp texture.
Reply 97 of 222, by Shagittarius
The attachment Q3ABench.jpg is no longer available
I got this every run...this might be the limit.
Reply 98 of 222, by Fusion
Damn... that beats my x800XT 256MB @ 565/540. 🙁 Stupid Intel.
Reply 99 of 222, by dexvx
Ok one minor nitpick as I was browsing through some old articles. The last Athlon to release in 1999 was the Athlon 800 (512KB). So that should be allowed on the 1999 cpu side.
https://www.anandtech.com/show/424
December 20, 1999 article
"As if that were not excessive enough, with rumors that Intel was going to start sampling their Pentium III based on the new Coppermine core in 750MHz and 800MHz flavors, AMD was pressured to release data on their competing product early. And thus we have our review of the AMD Athlon 800."
