Worms Floppy image.
First post, by sketchus
Hi all,
I hope this is OK to post here.
I'm trying to reinstall my copy of Worms 1 from floppy disk. Unfortunately the disks seems to be corrupt and I cannot for the life of my find an image for the floppies online.
Is there any chance anyone has a backup of their discs?
I have proof of ownership if needed.
Thanks.
Reply 1 of 7, by Azarien
Is the whole disk bad or just some files are unreadable? Name/date/size of the file would be helpful.
Reply 2 of 7, by sketchus
There's only two files on the disk, one is the install.exe and the other is just labelled "disk.1". I can check the file size tomorrow.
Reply 4 of 7, by sketchus
Of course:
Reply 5 of 7, by cyclone3d
@sketchus
You have a PM.
GOG still sells worms, so that is probably why you can't find a download anywhere.
Team17 still exists, so you may have some luck contacting them to see if you can get an image of the original disk. Or maybe they will even give you a replacement copy via GOG or something.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 6 of 7, by sketchus
Thanks to everyone, I know this forum would come through. I have got what I needed and am now worming away 😀
Reply 7 of 7, by .legaCy
Just remembering that GOG versions might not work correctly and will require you to unpack the installer.
