First post, by ElBrunzy
- Oldbie
I just recently bought a EWS64L. I'm not actually sure on which computer I will put it and with what soundcard it will share the isa bus, but outlook are that I will daisy-chain the card with another one, either digital or analogue. If I have to do the analogue chain it wont be a problem, but if I want to do digital I would need some information I cannot find, that is the front panel connector pinout. I know that the digital I/O are for the XL version, but according to my experience with front panel connectors, you usually can just plug a jumper somewhere and have digital out and the L have that connector or so it seem.
From pictures I've see of the front panel and schematic of signal path of the AudioSystem EWS64 hardware manual I think there is good chances that the digital in and digital out travel freely on either of the FP connector. So I would just had to intercept them to achieve in the box digital IO.
Maybe in the lack of such documentation a good picture of front panel pcb could give me a hint about where to look on the ribbon?
