Reply 280 of 421, by dJOS
Has anyone tested this with the "Yamaha Audician 32 plus" board?
They can be had new from eBay and use the YMF718-S chip - apparently they support MIDI via the gameport and are SB-Pro 2 compatible.
The impossible often has a kind of integrity which the merely improbable lacks.
Reply 281 of 421, by bjt
Yes, it works 😀
Reply 282 of 421, by dJOS
bjt wrote:
Yes, it works 😀
Fantastic, thank you.
Reply 283 of 421, by dJOS
I finally got around to trying SoftMPU with my K6-III+ equipped with SB16 PNP (Pre-Vibra but CQM edition) and it works great with SQ3, Siplheed and SQ4 .. although my card has the hanging note bug which presents pretty early. Not a big deal tho as I have both a Yamaha Audician 32 plus and an SB AWE64 in transit. I'm not sure why I bought the AWE64 but hey, cant hurt to own one i guess. 🤣
I'm also using QEMM 386 v7.04 with no issues. 😎
PS, thanks for your hard work bjt, tis brilliant being able to use my MT-32 on real HW again!
Reply 284 of 421, by bjt
Nice one 😀
Reply 285 of 421, by lazygamereviews
So I've had great luck using SoftMPU until today when I am getting the message "Real Time Clock support not detected." Can't seem to find out what that means? Just using it with a Sound Blaster 16 card on a Compaq 486, which definitely has an RTC. Shouldn't be any TSRs that would conflict, only have CTMOUSE and DOSKEY loaded.
https://www.youtube.com/lazygamereviews
Reply 286 of 421, by bjwil1991
What version of CTMOUSE do you have? 2.0 beta 4 is recommended over 2.1 alpha and 1.9
Reply 287 of 421, by bjt
Interesting, I haven't heard of that problem before.
Have a play with the ROM shadowing options in the BIOS. If you don't have any luck I can provide a patched version that bypasses the RTC check.
Reply 288 of 421, by lazygamereviews
Unfortunately the BIOS doesn't have any settings for ROM shadowing to adjust.
I'd be happy to try a patched version! Would bypassing the RTC check affect functionality much?
Reply 289 of 421, by bjt
No, it will still use the RTC. Not really sure why the check is failing on your Compaq (could your copy of SoftMPU be corrupt?) but here's a patched version anyway.
Reply 290 of 421, by lazygamereviews
Thanks so much! It's working perfectly now 😀
Reply 291 of 421, by bjt
I love it when a plan comes together 😎
Reply 292 of 421, by escarioth
HI 😀
ive manage to get my hand ona a Roland MT-32 and i can say it this patch works GREAT with my sound blaster vibra 16 CT2950
i did came upon some games that didnt works
lots of the working one are already on the compatibility list
if you want i can list them all (all games are originals)
but the ones i cant seem to make works are
Loom : game and music starts...but as the music plays the instruments seems to get into a real mess.
Princess maker 2 : it just wont start...but from what i saw it might be because im on IRQ5..guess it has to be on 2 or 9
Companions of Xanth : right at setup im being ask wich IRQ is my midi....i dont think ill be able to play this one
if anyone as any help for those 3 games 😀 id be more then happy to hear 'em
even if they're old....those old dos games are still the best!!!
Reply 293 of 421, by bjt
Loom has problems with faster machines, try disabling your L1 and/or L2 cache to slow the machine down. It doesn't require intelligent mode so will work fine without SoftMPU too.
Yes, Princess Maker 2 requires IRQ 2/9.
Companions of Xanth worked OK for me, but I only tested the non-talkie version.
Reply 294 of 421, by escarioth
Ah so disabling the cache will correct the problem 😀
my cache can only be disabled in Bios.
every other way ill crash the whole pc.
so i guess ill have to make this on special occasion
companions of Xanth : thats the version i currently got....hmmm.. when choose roland MT-32 for music it ask wich IRQ to use.
im a bit puzzled by that question. is it the same as my SB16 card ? (irq 5)
as for princess maker 2....damn.. i guess i cant do anything for now.
Reply 295 of 421, by bjt
Yes, IRQ 5 should do it. Wonder if there is a speed issue there too?
Reply 296 of 421, by escarioth
woah....
that disabling cache stuff DID put back LOOM working and sounding RIGHT. 😮
Thanks Bjt ! (and i still have to run softmpu or else no sound)
but something is strange. despite having set my cache to disabled....it went back at enabled.
right after restarting and everything is now working....Loom and even Xanth.
with cache at enabled status.
If only this could get rid of my Xcom TFTD roland/sb16 problem 😵
Reply 297 of 421, by AmiSapphire
Yeah, quite odd. I have a Compaq Armada 1573DM laptop I was experimenting with and actually needed this patched version when messing with DOS 6.22, but didn't need it when using Windows 98 SE's DOS files.
I was making a custom startup disk from DOS 6.22's files until I ran into that issue, so I also made one from the DOS files of Win98SE as a result. Will have to investigate whether this behavior changed in Win95's DOS files or not, but I have other things to do for now.
EDIT 2017/10/30: SoftMPU's RTC check bypass is no longer needed starting with Windows 95A's DOS files on Compaq laptops! Interesting.
Site update: cwcyrix.duckdns.org -> cwcyrix.nsupdate.info due to the former no longer working.
Reply 298 of 421, by dr.zeissler
Any chance to get this thing working on a 286 ? (probably not)
Reply 299 of 421, by TimMer1981
You could try HardMPU?
"I will take your bones, still alive and in great pain, and make them into a chair. I will call it "My Screaming Chair". Every morning I will sit in it and listen to you scream. Any questions?"
