Reply 19220 of 57460, by lazibayer
lazibayer wrote:
Bought 4 RAMBUS sticks and they arrived exactly as pictured below:
Just four bare sticks and two deflated airbags in a box. I will test them tonight.
The test results are in...
The good: they work
The bad: two of them are PC800/40, and two of them are PC800/45
The ugly: they were advertised as PC1066 modules on the ebay listing
Reply 19221 of 57460, by Kreshna Aryaguna Nurzaman
cj_reha wrote:
Got one of these Nakamichi 5 CD changer drives. I think it was around $30 shipped.
Demo of it loading and storing 5 CDs and ejecting them with cover off: https://www.youtube.com/watch?v=iodxMJQVmnc
Very impressive, but does it work with DOS?
Kreshna Aryaguna Nurzaman.
Reply 19222 of 57460, by appiah4
lazibayer wrote:
The test results are in... The good: they work The bad: two of them are PC800/40, and two of them are PC800/45 The ugly: they we […]
The good: they work
I hope you didn't buy them for a fistful of dollars..
Reply 19223 of 57460, by lazibayer
The good: they work
A fistful of quarters, maybe... 🤣
Still, I am negotiating a return or refund from the seller.
Reply 19224 of 57460, by dexvx
Batyra wrote:
dexvx wrote:
Got this Gigabyte GA-5AX with unknown CPU in dusty condition.
Nice! I havent seen this revision yet.
Yea, it seems to be quite an early revision (if not earliest). Here's a thread from madshrimps talking about it. Looks like you should be able to flash to BIOS meant for rev 5.2, but it obviously is missing the > 100 FSB feature.
http://www.madshrimps.be/vbulletin/f10/gigaby … -victory-44180/
Reply 19225 of 57460, by okenido
Real bargain today, got 10 computers for 30€ xD
I just opened one of them (the little beige tower), it seems to be a pentium1 or something of this era
There is EDO ram, a trident graphics card and an aztech sound card which seems pretty good with a real OPL chip on it
Reply 19226 of 57460, by cj_reha
Have not tested yet but according to a friend it will show up as 5 CD drives in DOS and Windows.
Reply 19227 of 57460, by cliffclaven
Picked up a Microsoft bus mouse at a thrift store.
I initially thought it was a PS/2 mouse and I have no adapter for it.
Is this what it uses?
http://www.ebay.com/itm/Microsoft-InPort-Bus- … f4AAOSwqYhZwvGz
Reply 19228 of 57460, by luckybob
Those bus mice are quite uncommon. The controllers are usually worthless without a mouse.
Reply 19229 of 57460, by Formulator
Always good deals out there.
$45
$18
Reply 19230 of 57460, by jade_angel
Formulator wrote:
Always good deals out there. […]
$45
Second from the right - is that a SMAC? We had a pile of those at work, way back in 2000... (Most were P2/266 with Cirrus graphics, some were P2/450 with Matrox G200s)
Main Box: Macbook Pro M2 Max
Alas, I'm down to emulation.
Reply 19231 of 57460, by Formulator
Not sure just yet, as you may see these units are pretty dirty so it may be wise to inspect before applying power.
However just peeking in through the open bays, I would guess a socket 7 of some type.
Reply 19232 of 57460, by luckybob
@Formulator
$18 for a nice looking Kaypro? (the middle one) You f-ing stole that thing.
@jade_angel
It is a standard atx case. not a good one, but standard of the era. I own one, had some no-name boring p2 era parts in it.
Reply 19233 of 57460, by Formulator
I was really only hoping for the original diskettes...it came with the full manual set, but the owner tossed any and all media.
Reply 19234 of 57460, by Tetrium
okenido wrote:
http://image.noelshack.com/fichiers/2017/39/2/1506451202-img-20170926-203408-copie.jpg […]
And the CPU socket has 2x2 of those extensions, but the HSF is mounted using one of those wire clamps shaped a bit like a "Z". Those I find to be very useful as these allow mounting Socket 7 heatsinks onto Socket 3 motherboards that have only 2x1 of those extensions 😀
My retro rigs (old topic)
Report spammers here!
Reply 19235 of 57460, by vlask
Both for about $23. Both damaged, but been repaired....
Not only mine graphics cards collection at http://www.vgamuseum.info
Reply 19236 of 57460, by Kreshna Aryaguna Nurzaman
The highlighted is the awesome part of it.
Reply 19237 of 57460, by Jade Falcon
Rank BANNED
BANNED
What if I want to switch to disk2 when I have 5 disks in the drive? dose it eject disk 3, 5 and 5? or can to switch to disk 2 from 5? and so on?
Reply 19238 of 57460, by luckybob
That sounds horrible. I have a 6 cd changer that supposedly requires a special program to change disks, but only comes up as one drive. One of these days I'll check it out with the 7th guest
Reply 19239 of 57460, by derSammler
No, it will show up as one drive and give you access to whatever disc you select by pressing the corresponding button.
