First post, by vvbee
Mobo: asrock am2nf3-vsta
Cpu: amd athlon x2 5050e @ 1120 to 1400 mhz
Ram: one stick of 1024 mb ddr2, limited to 384 mb usable with himemx
Video: matrox g400 dualhead 32 mb
Sound: audigy 2
Disk: super talent ultradrive me 64 gb mlc sata ssd
Psu: silverstone st30sf v1, passive up to 55 c
Goals:
- quiet operation, fanless if possible but for component longevity will prefer a single effectively silent fan across all components
- comparable to a top pentium 3 system in cpu performance while keeping wattage lower
- runs late 90s and very early 2000s games well at 640 x 480 with good visual integrity across the spectrum
Underclocking:
- cpu is rated for 2600 mhz at 1.25 v, underclocked to 1120 mhz at 0.85 v (9 w tdp)
- ram is rated for 533 mhz, underclocked to 400 mhz
Cooling:
- no dedicated fan on cpu, gpu or psu - psu has a fan but it never turns on
- stock amd heatsink on the cpu
- one 120 mm yate loon d12sh-12 wired at 5 v moving air across the system
Benchmarks:
- sandra 2003: cpu speed comparable to a 1200 mhz p3, memory bandwidth 3x faster
- 3dmark 99 max: 8020, comparable to a 1400 mhz p3 with a voodoo 3 3500 as per vogon's 99 thread
- crystaldiskmark: seq read/write 114/93 mb/s, 4k read/write 26/7 mb/s
Videos:
- running some games: https://www.youtube.com/watch?v=RsJXXBTuKA4
- temps running prime95 for two minutes: https://www.youtube.com/watch?v=6iS0rG54hqM
I've not seen the cpu reach 40 c at 23 c ambient, so there's room for reduced cooling. A fan speed adjuster is next on the list to cut the fan below 5 v with finer control.
A faster video card would be good for the newer games, but I've not seen one that would simultaneously match the g400 in 3d image quality in the older games.
