First post, by 386SX
I was listening some retro reviews of the Sega 32X, the famous hardware expansion for the Megadrive/Genesis console, even if back then I never had this expansion or the Megadrive/Genesis itself (the Master System was still a common great console) I found impressive the capabilities of this expansion that unfortunately seems wasn't pushed to its limits.
If I'm correct 40 games were only released and many wasn't great but still I am amazed by the fact that this was really an expansion and not a newer console as I was expecting.
If I understood correctly with a video/audio passthrough cable the work done by the Megadrive/Genesis cpu/vdp was added to the video/audio output of the 32X much faster architecture composing a more complex final tv image/sound; different from what I'd expect by a 3dfx Voodoo accelerator card where the card switch beetween its output and the video card one. So basically both console could be programmed (at least both 32X and Megadrive using one only game) to make some video AND sound effects each and finally compose them.
At the end developers could program all these stuff more or less:
Megadrive: Motorola 68000 @ 7.61 MHz + 64 KByte RAM + Z80 @ 4 MHz + VDP (Video Display Processor) + PSG (TI 76489 chip) + eventually Sega SVP cartridge coprocessor running @ 23Mhz
32X: Dual Hitachi SH-2 RISC @ 23 MHz + Motorola 68000 @ 7.61 MHz + 32X VDP (Video Display Processor) + PCM sound
MegaCD: Motorola 68000 @ 12.5MHz + various cache memories + PCM
This was lot of stuff to program! I understand that back in that time with the PSX almost out all this hardware could still not do much and with the Saturn too it seems obvious developers had other projects but still, technically is amazing having so many hardware chips you can use at the same time.
What do you think about it? One thing I found funny is that at the end you'd have three different power supply for a single home console. 😁
Thank
Reply 1 of 6, by GoblinUpTheRoad
Yep, this is how you play SEGA!
Image stolen from Google...
Reply 2 of 6, by gdjacobs
160 bit?
Reply 3 of 6, by 386SX
Ahah. But a good developer could have some alternative way of coding all that hardware, if not for the graphic maybe for physic and AI. 😊
Reply 4 of 6, by leileilol
Some of its existing library were already stressing the 32x as it is. Darxide especially
Reply 5 of 6, by badmojo
Sega really messed their customers around during that period with those crazy add-ons / systems that were quickly dropped for their next idea. I loves my Mega Drive / Master System, but I'm strictly non-Sega from then on.
Reply 6 of 6, by 386SX
I was and am a fan for the nostalgic motivation when I had both the Master System and a Game Gear, the best handheld you could have imagined back then, tha was basically a Master System portable. You can even natively run the Master System cartridge onto it with the adapter.
But I understand the confusion around these expansion devices. Imho as other said the alternative road, using the SVP on-cartridge cpu (like the SuperFX) maybe was the right thing instead of the 32X confusion. It seems that SVP chip was probably more capable of the SuperFX so waiting for the Saturn, their customers would have probably bought more expensive games with that chip on board. Virtua Racing (?) game for the Genesis (the only one with the SVP) is quiet impressive.
