Running Dosbox under MSDOS, without Windows? I remember reading about this a while back..
Getting old software/games running on older hardware.
Postby keenerb » 2017-8-30 @ 17:01
At some point I stumbled across a method for running Dosbox under actual MSDOS, using some sort of windows 32-bit console support library.
Is that actually possible, or did I hallucinate the whole thing?
keenerb
Re: Running Dosbox under MSDOS, without Windows? I remember reading about this a while back..
Postby mrau » 2017-8-30 @ 17:02
and the reason for this exercise would be what?
mrau
Postby Jade Falcon » 2017-8-30 @ 17:09
To Emu old hard ware on a new system? :confused: Or just for fun?
Anyway I have seen a *inux Live CD floating around on the net that uses DosBox as the use interface or something to that effect.
EDIT:
I have seen people install MS-DOS in dosbox
http://www.transmissionzero.co.uk/compu ... in-dosbox/
Jade Falcon
BANNED
Postby DosFreak » 2017-8-30 @ 17:23
You're looking for HXRT. Last time I tested a couple of years ago performance was pretty much the same in DOS as it was in Windows but this was a P166 so DOSBox was slow either way.
viewtopic.php?f=5&t=12035&p=82886&hilit=hxgui#p82886
Point would be to run games on the computer that are too fast on the host or if something about your hardware or software configuration prevented the game from running then DOSBox would work.
User avatar
DosFreak
Postby keenerb » 2017-8-30 @ 17:34
mrau wrote:and the reason for this exercise would be what?
To see if it works?
I'm curious if my AMD 5x86/133 running DOSBOX could better approximate an old 8088 system than you can normally achieve simply by disabling cache/etc.
keenerb
Postby .legaCy » 2017-8-31 @ 00:44
My P4 build that runs windows 98 has issues with SB16 emulation so dosbox serve the purpose of solving this issue.
Also for speed sensitive games, so my windows 98 has a "extended range" on retro gaming.
User avatar
.legaCy
Postby keenerb » 2017-10-08 @ 19:11
DosFreak wrote:Did some tests with my compiled SVN of DOSBox (still a WIP)
viewtopic.php?f=31&t=55706&p=617752&hilit=guide#p617883
Excellent. I'll be looking at trying this out sometime soon.
keenerb
Postby Malik » 2017-10-09 @ 02:04
I'm not really interested in Dosbox running under pure DOS, unless I want to make any new modern computer behave like a DOS machine, by booting directly into DOS and Dosbox subsequently. But then, I could simply use the appropriate OS - Windows/Linux/OSX to do the same, by loading the respective native Dosbox build without unnecessary complications or headaches.
And I believe most computers or laptops available today are able to run Dosbox comfortably, to run any speed-sensitive games more conveniently.
BUT, just wondering... so Dosbox in pure DOS can make use of any PCI or ISA sound card or on-board sound chip to produce sound? Like in Windows? If so, how does it do that? I thought Dosbox can only do this via Windows' API. Does Dosbox probe for sound devices in pure DOS? Or it behaves like a dos game itself, by detecting the drivers loaded? How about for machines that have the original SB/SBPro or Adlib cards, which do not need to load any drivers? And how about MIDI? can it detect and direct output to an attached MT-32 too?
User avatar
Malik
Postby DosFreak » 2017-10-09 @ 04:34
Nothing with DOSBox was modified to make it run in DOS, only the usage of HXRT makes it work.
SB16 and MIDI support are provided by HXRT.
Last year a modified build of HXRT was provided with Intel HDA and AC97 support.
Others benefits besides added game compatibility is the usage of scalers, screenshot, video recording, emulated sound and video cards. Also of course potentially 3rd party patches so pixel perfect, saved states etc.
Just discovered today that the mouse is unusable. Cursor stuck at top upper-left. Mouse buttons work fine though.
When I adjust the sensitivity with host ctmouse,dosbox settings or game settings I can get it slower but it's still unusable. Looks like this will require some coding skills that I lack.
It may be possible to use use djpp to make a DOS native DOSBox but that's beyond me and is possibly pointless since HXRT works. Would probably be great for learning though.
Just for kicks tried out MESA3D 7.5.1 and it works! Requires 32bit color and it's slow of course.
User avatar
DosFreak
Postby gdjacobs » 2017-10-09 @ 23:57
DosFreak wrote:Last year a modified build of HXRT was provided with Intel HDA and AC97 support.
This is kind of amazing, but I still question how robust the support is. Plus, as Malik said, why not use a Linux build and avoid the limitations.
User avatar
gdjacobs
Postby retrogamerguy1997 » 2017-10-12 @ 02:06
What is HXRT? I see it mentioned in this thread a couple times.
retrogamerguy1997
Postby Malik » 2017-10-12 @ 05:36
A quick Google search will lead to: ftp://retronn.de/dos/extender/hx/HXRT.TXT
User avatar
Malik
Postby Stiletto » 2017-10-12 @ 15:12
retrogamerguy1997 wrote:What is HXRT? I see it mentioned in this thread a couple times.
It lets you run a limited selection of Windows programs/utilities/games in DOS.
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Postby retrogamerguy1997 » 2017-10-14 @ 04:04
Malik wrote:A quick Google search will lead to: ftp://retronn.de/dos/extender/hx/HXRT.TXT
sadly when I try to look things up, I never find what I'm looking for. Thanks though
that seems pretty neat
retrogamerguy1997
Postby Jo22 » 2017-10-15 @ 06:38
I don't know about you, but I would like to see a Win32s version of DOSBox somewhen.
Even if it would be just a proof-of-concept and with some restrictions,
to fit within the limits of Windows 3.1. :D
User avatar
Jo22
Return to Software
Who is online
Users browsing this forum: No registered users and 3 guests
