x0zm_ wrote:Jade Falcon wrote:Well i got bad news. The ocz pcie ssd I got was a dud. At frist it was working but things started to get wonky. Now only one of the two ssd's on the card works.
Well that sucks.
But to my original plan of just useimg the raptors.
Damn, was going so smoothly too 🙁
Oh still, still great temps and a kickass Vista system!  😎
Well the pcie ssd was kind of a last minute addition. I wanted 8 raptors to begin with.  I'll need to find a rear hdd cage for the case to use 8 of them, that or make one.
Also with both 6900's under a load the cpu goes from low 30's to low 40s under a load. the 6990s are rather hot cards. I think I'll get a second fan for the rear rad. Also I'll need to find a lower profile vga to Dvi thingy. The case is a bit too long for my desk and the DVI to VGA adapter is far too long and the case sticks out to far.
EDIT:
On a side note, the sound card I got for the system is firckin amazing.  Its a Prodigy HD2 Advance witch is a via envy card. Now I had a lot of high end sound cards and DAC's. but this thing not only takes the cakes it bakes it and eats it too.
Link to card http://audiotrack.co.kr/en/internal/231
