First post, by twiz11
I am burned out, what do you or I do?
Take a rest and calm down 😀
Good luck!!!
Better to be burned out than burned up.
If the truth hurts, tough shit.
“It's better to burn out than to fade away”
Experiment with a new substance. Date sketchy women with loose morals. Take off your shoes, climb a tree, and learn to play the flute.
I'm sorry to hear that, twiz11. The first step is to acknowledge it, which you have done. Now you must analyze what it is, precisely, that is causing this. Then, take measures to fix it...obviously easier said than done. Take some time for yourself, do something you enjoy. Do you like reading, but haven't had time? Too much time at work? Too much stress in your personal life?
I'm no therapist, but I am pretty easy to talk to. If you think it beneficial, send me a PM.
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Buy a new computer?
Is this too much voodoo?
Check your power supply for bad caps.
Obey and conform, watch tv, consume, marry and reproduce, sleep , no thought.
Take it easy for the time being and try to evaluate the reasons what got you into this predicament and make changes to your life so this won't happen again to you in the future.
With this very limited information this is the best answer I can give.
wrote:Obey and conform, watch tv, consume, marry and reproduce, sleep , no thought.
Mandatory shot that I slightly modified with confetti from Roger Waters concert.
You edited a perfect photo?
Nice! I love John Carpenter films!
I'd say Jade Falcon is all out of bubble gum...
Time for him to kick ass
