First post, by GiSWiG
So the card does not have a manufacuter stamped anywhere. The only identifiable marks are CGTS2 ver1.0 and 64M.
The chip is marked gforce2GTS Pro.
The memory is Samsung. Most screenshots of geforce2GTS card seem to not use Samsung.
It has 64MB of memory.
On boot, it shows as a Geforce2 Pro VGA BIOS.
I used TechPowerUp GPU-Z which really just states it is an NVIDIA GeForce2 GTS/GeForce2 Pro
The memory clock throws me off a bit. According to GPU-Z it is ~180MHz (DDR). From what I've seen, a GTS is 166MHz and a GTS Pro runs at 200MHz. Modern cards throttle memory speed but I don't think older cards did. I'm wondering it this card does and boost up to 200 when gaming (I'll test that later).
From what little information I can find, it might be a PowerColor. I cannot find any reviews that covered PowerColor. What screenshots I have found are fuzzy or don't fully show the card. Also, unless the memory does throttle, I'm thinking it is either a overclocked GF2 GTS or an underclocked GF2 GTS Pro.
I've attached some screenshots.
Thanks for any help!
Steamer/GOG-er: ASUS Crosshair IV Formula | AMD Phenom II X6 1100T 3.7GHz all cores | Mushkin 8GB DDR3 RAM 1333 w/ 6-6-6-18 1T | Dual AMD Radeon HD 6850s in CrossFireX | X-Fi Titanium | Dual-boot Windows XP and Vista
