Reply 6960 of 29851, by alvaro84
Got my 939 testbed (Abit AX8) properly see A64X2 CPUs. I have no idea why but the 4200+ I wanted to test showed up as 1 CPU and CPU-Z showed 1 core / 1 thread too.
What's worse I have no idea how I did it. I installed the ACPI multiprocessor and the A64X2 driver, nothing happened. Deleted the one CPU entry from device manager hoping it would find two - still nothing, it found only one after reboot. Then I just restarted, went to the BIOS setup, didn't change anything interesting, saved, booted and voila, two cores with two threads. I'm somewhat confused.
At least it works now...
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 6961 of 29851, by probnot
Cleaned the AT cases I picked up last weekend. I opened up the empty case's PSU to inspect, aaaand...
That's why it was gutted. Might still be OK after a re-cap, but I'm not in need of one right now, so it's getting shelved.
The PSU from the other case is good though, looks like it was replaced mid-90's and the rails measure pretty clean.
Reply 6962 of 29851, by brostenen
Going through old Amiga games disks... Takes a lot of time, testing wich games need the ide controller disabled on my Amiga600, wich games that need to have the kickrom 1.3 disk loaded, and wich games need both. Time consuming to go through some +200 disks.
Reply 6963 of 29851, by brostenen
BloodyCactus wrote:
Installed FreeBSD 3.5.1 and BeOS 5 on my K6-2+. Ive was a FreeBSD user since it was a patchset on 386bsd.
Also used to run + develop for BeOS ye-long time ago. I had 3/4/5. Figured I'd take a look at Be5 on my K6 before upgrading it to a Haiku nightly.
aah memories! 🤣
Nothing beats a good Unix. Well... Unless gaming is on ones mind that is.
I too have experienced FreeBSD installs in the past. I think that was somewere in 1996.
Made my first webpage, hosted on that FreeBSD machine, on that closed intranet at that time.
10 pages, each with a single image of nude pinup girls each, and a back and forth arrow.
Except for the last page, that had a picture of a blind man.... A kind of twisted joke. 😁
I repeated the idea of a twisted joke on webpages, years later, when I studied WebProgramming.
The language that were used on my education was ASP.NET 4.0 with C# and SQL 2008 r2.
I used to have that konami-code script on each and every single website that I produced.
And when triggered, it showed a picture of an polar explorer having shot and killed santa claus.
THIS:
Reply 6964 of 29851, by cliffclaven
Stripped down to the bone several cases for anything useful. Spare drive bay covers, rubber feet, speakers, back plane covers, led indicators. Should have enough miscellaneous parts for a good while.
Reply 6965 of 29851, by CkRtech
probnot wrote:
Cleaned the AT cases I picked up last weekend. I opened up the empty case's PSU to inspect, aaaand... http://i.imgur.com/XDw122E […]
Ha. Oh man. Could we get a full shot of that PSU? Based on the output side, I imagine the primary side is two caps by their lonesome + a barren wasteland of PCB that is void of components? What is the brand and model?
Reply 6966 of 29851, by BitWrangler
How dare you malign and rebuke what could have been one of Lucky Star's finest examples of engineering 😁
Reply 6967 of 29851, by probnot
It was actually less barren than you'd think. Still very cheap though (Vtech branded). I've already stored it away in the shed for now.
Reply 6968 of 29851, by gdjacobs
Ah, man, that PSU is such a sexy beast.
Haters gonna hate, I guess.
Reply 6969 of 29851, by bjwil1991
Upgraded the memory in my Socket 370 system from 512MB to 768MB, changed the video card from the dreaded GeForce4 MX4000 PCI card (was too slow and some games didn't work out too well - would either crash or not play at all) to the VooDoo3 3000 PCI card that was in my K6-2/300 system (still have the system) and that system has the S3 Virge/VX (Velocity 3D) and STB VooDoo2 accelerator card, 128MB of RAM, no HDD (going to use the 60GB HDD I recently purchased as the drive with the drive limitation set to 32GB), no CD drive (going to buy one, as well as a dual floppy drive), and it'll run either MS-DOS 6.22/Windows for Workgroups 3.11 or Windows 95C.
Reply 6970 of 29851, by BitWrangler
That's odd, don't remember having to disable IDE on the 1200, just ran relokick ... was it a tight RAM thing?
Reply 6971 of 29851, by dexvx
Does anyone know if Athlon MP's require a good 5V rail?
I'm having trouble powering up a Tyan Thunder K7 S2462; it has a ATX12V 24pin connector and an 8pin CPU connector. The board (aside from dust) looks in good condition on initial inspection. I'm using a new Corsair CX750M (20A 3.3V/5V). The fans don't even spin up. I can try my other PSU's, but the older ones only seem to have a 4pin aux connector.
Edit:
Hmm... looks like it doesn't conform to EPS12V standard?
http://www.overclockers.com/forums/showthread … 62-PSU-Question
Edit 2:
Man... If board is useless without ATX GES. If I buy an adapter and board is dead. Well crap.
http://www.rackmount.com/Rackacc/ATXGES.htm
Reply 6972 of 29851, by CkRtech
Reply 6973 of 29851, by brostenen
I am using a different software solution. I don't remember the exact name. Though the adf file was named something like kick13for500 or something like that. Basically the one tailored for the Amiga500plus. Using it, because there is no setup at all, and everything runs from a floppy disk. The Amiga600 is after all, basically just an 500 with minor changes, like no numeric keyboard, and an IDE controller plus an PcCard port added to the machine. Nothing like the 32bit 1200 other than it shares a few hardware technologies and the outer design language.
Reply 6974 of 29851, by BitWrangler
Hmmm, I'd say 70W per CPU and 20% overhead to be safe.... and you've got 100W so if you can try it single CPU, it might fire up then.
Reply 6975 of 29851, by oeuvre
Playing around Windows for Workgroups 3.11 on my ThinkPad 770
Reply 6976 of 29851, by appiah4
IRC on Windows 3.11, classic. I can't remember, did Win 3.11 require Trumpet Winsock to go online on a Dial-Up? I presume you are connected via LAN in this setup though?
Reply 6977 of 29851, by bjwil1991
I even tried to connect to AOL with the LAN connection (username and password were right), but they ended support for the older AOL programs.
And he's using LAN since the system has the Microsoft TCP/IP driver and software installed.
Reply 6978 of 29851, by oeuvre
Yeah, TCP/IP via tcp32b.exe and a PCMCIA ethernet card (Xircom XEM5600)
Reply 6979 of 29851, by bjwil1991
Wait a minute. Is that the same card you posted a picture about a few weeks ago? Interesting.
I'm planning on installing the CardPark I got a couple of days ago into either my Socket 7 (K6-2/300) or Socket 370 system, but it's only ISA.
