What are some good, less demanding early 2000s first person shooters?
Getting old software/games running on older hardware.
Postby electron » 2017-10-27 @ 22:22
What are some of the best early 2000s first person shooters? Any good sci-fi ones? Specifically, I'm trying to see if there is anything that could possibly run on a Toshiba Libretto U100. The graphics chip is obviously pretty bad (855GME Extreme Graphics, 64MB), but I'm wondering what kind of early shooters it can play. So, if anything, something that can run on some lower specs would be cool.
electron
Re: What are some good, less demanding early 2000s first person shooters?
Postby leileilol » 2017-10-27 @ 22:28
Star Trek Voyager Elite Force might work.
Voodoo2s aren't 100mhz stock
Geforce256 isn't released as a beta on New Years '99 under the Quadro brand
DOS gaming isn't a bilinear 320x200 16:10
DOS PCs aren't better than the Macintosh
DOSBox is not for running Windows 9x
SGL != Glide
User avatar
leileilol
Postby electron » 2017-10-27 @ 22:50
leileilol wrote:Star Trek Voyager Elite Force might work.
Looks like it should! Thank you.
electron
Postby gdjacobs » 2017-10-28 @ 04:35
I would think JK1 would work as well.
User avatar
gdjacobs
Postby BeginnerGuy » 2017-10-28 @ 04:39
I wonder how it would run Return to Castle Wolfenstein. That's pretty much my favorite 2000~ era shooter. Not quite sci-fi though :dead:
Sup. I like computers. Are you a computer?
User avatar
BeginnerGuy
Postby yochenhsieh » 2017-10-28 @ 06:48
Good Sci-fi FPS in early 2000s:
Half-life
Deus Ex
Aliens versus Predator
Red Faction
855GM barely matches a TNT~TNT2. You may want to consider some pre-2000 games.
yochenhsieh
Postby Davros » 2017-10-28 @ 10:21
halo
f.e.a.r (2005)
farcry
tribes vengeance
unreal 2
serious sam
User avatar
Davros
Postby yochenhsieh » 2017-10-28 @ 10:26
Far Cry is *very* resource demanding even at the time of its release (2004) and probably not suitable for 855GM.
yochenhsieh
Postby Osprey » 2017-10-28 @ 19:21
If it doesn't need to be a run 'n' gun shooter, System Shock 2 is one of the best sci-fi first person games. It has RPG elements, but you can mostly play it as a shooter if you want to. The BioShock games are spiritual sequels of it, to give you an idea of how it is. It's from 1999, so it's sure to run very well.
Osprey
Postby Davros » 2017-10-29 @ 20:19
What direct3d version does this chip support ?
if its equal to a tnt2 that would rule out most 2000 and above era games as they require pixel shaders
User avatar
Davros
Postby KCompRoom2000 » 2017-10-29 @ 22:52
Davros wrote:What direct3d version does this chip support ?
According to Wikipedia, the i855GM has DirectX 6 hardware feature level support and uses software emulation for DirectX 7-9 features which is why the Intel Extreme Graphics chipsets can run games that would refuse to run on an ordinary Dx6 feature level card (like a TNT2 or a Rage 128) because the cards from that era don't use the emulation techniques used by the Intel GPU drivers.
I remember being able to play The Sims 2 at minimum settings on an i845G GPU and that game requires a Geforce2 or a Radeon 7200 minimum, as well as requiring T&L Support. So some games that support a DirectX 7 feature level card will *for the most part* run on the Extreme Graphics chipsets (i830 through i865) albeit laggy at some scenarios.
1988-96:SL-54U5|P233MMX|64MB|Virge325|YMF719-S
1995-98:P2B-VE|C433|192MB|Rage Pro|Voodoo2|CT4500/32M
1998-01:GX150MT|PIII-S 1400|384MB|GF4Ti4200|CT4670
2000-05:A8V|A64 3700+|2GB|RadeonX800
User avatar
KCompRoom2000
Postby Anaxagoras » 2017-10-29 @ 23:16
Hi.
I think that Quake III Arena works fine in your computer.
Quake III Arena specs from MobyGames
It's not the best but funny to play with other people over LAN or Internet, or bots.
You can find OpenArena too, an opensource version of Quake III Arena.
Unreal and Half-Life, as mentioned above, should be very fast too.
yochenhsieh wrote:Good Sci-fi FPS in early 2000s:
I'm totally agree with yochenhsieh
My retro (and obsolete) computers:
- Sinclair ZX Spectrum 48, Z80A, Sinclair BASIC.
- PC-XT clon, MS-DOS 3.30.
- PC 486DX4 custom build, MS-DOS 6.22
- Toshiba Satellite Pro 4600, Pentium III, Windows 98 SE.
- Pentium 4 custom build, Windows XP.
User avatar
Anaxagoras
Postby Davros » 2017-10-30 @ 16:12
Did the intel chip support opengl ?
User avatar
Davros
Postby leileilol » 2017-10-30 @ 22:09
It does, and it should be able to handle Jedi Outcast as well (since the Intel Extremes are typically paired with the P4 stuff, and netburst happens to be very very good with anything id tech 3)
SGL != Glide
User avatar
leileilol
Postby yochenhsieh » 2017-10-31 @ 01:58
leileilol wrote:It does, and it should be able to handle Jedi Outcast as well (since the Intel Extremes are typically paired with the P4 stuff, and netburst happens to be very very good with anything id tech 3)
Please read the first post. It's a Toshiba Libretto U100 which has Pentium M 1.1Ghz.
Intel 1st/2nd Gen. graphic solutions may support many features it claim, its performance is poor and depends on the CPU a lot because some features are achieved via software emulation, e.g. T&L. This is the reason why I say it barely matches a TNT~TNT2. It's possible to run Direct7~8 games, but really don't push too hard on it when you have a 1.1Ghz CPU.
yochenhsieh
Postby leileilol » 2017-10-31 @ 02:24
yochenhsieh wrote:Pentium M 1.1Ghz.
.....which is actually faster than most early P4s and is a predecessor of the Core series... my point still stands :)
SGL != Glide
User avatar
leileilol
Postby retropwned » 2017-11-10 @ 04:59
Soldier of Fortune - not sci fi but an awesome game nonetheless. only avail on hard media.
retropwned
Postby appiah4 » 2017-11-10 @ 05:32
Rainbow 6 Raven Shield and Ghost Recon perhaps?
1989:A500R6|+512K/RTC|ACA500+|HxC/df1:|C1084S
1992:HIPPO-VL+|DX2ODPR66|8M|GD5428|CT2290
1995:PCI597-1|P133|32M|Trio64|Voodoo1|CT3980/2M|DreamS2
1998:S1573S|K6-2/400|64M|RagePro|Voodoo2/SLI|CT4500/32M
2001:GA-6OXT|PIII-1200|512M|GF3Ti200|MX300
User avatar
appiah4
Return to Software
Who is online
