Peixoto's patches for a few old games
Reply 80 of 896, by Curlyoxide
I downloaded the multipatch from http://www.tombraiderchronicles.com/windows10/index.html seems to be the same as the one linked in help.exe
I will make sure again that I am using the most current one
It seems to be related to directx tho since dgvoodoo’s directx dlls have no problem with 2560x1440
Thank you for the response Peixoto
Reply 81 of 896, by Peixoto
Curlyoxide wrote:
I downloaded the multipatch from http://www.tombraiderchronicles.com/windows10/index.html seems to be the same as the one linked […]
I don't mean the multipatch, i mean my patch. DirectDraw seems to have limitations in the size of he render target, but i believe it only applies to render targets larger then the monitor resolution.
I also suspect your monitor supports 2k, but its native resolution is actually full HD.
Reply 82 of 896, by Curlyoxide
I do have the latest one posted on the onedrive site that you linked at the start of the thread
Says 9-13-17 date on it of your patch I don’t see a more recent one released
Reply 83 of 896, by uncaged
Peixoto wrote:
uncaged wrote:
Greetings!
I have just one minor complain about Onimusha. It runs great, but it is not fullscreen on my PC.
https://imgur.com/wUlR6ls
To solve your problem, change your computer's resolution to 1280 x 960 before you start the game
Understood! Thank you very much for clarifying 😀
Reply 84 of 896, by Peixoto
Ok, it seems there is an arbitrary limitation on the size of the render target on Direct3D 7 and earlier. Fortunately
this guy (https://github.com/UCyborg/LegacyD3DResolutionHack) found a solution which i integrated with success in all my patches. I have reproduced the error in your trace file and fixed it with that solution, so it most likely will work for you and anyone with a 2k/4k monitor, but you will have to wait until next week
Reply 85 of 896, by Curlyoxide
Ok thank you for the update
I am glad a solution can be found like I said not a game breaking bug but was an annoying one hehe
I appreciate the work that has been done tho!
Reply 86 of 896, by Peixoto
OK, the new version should work on 2K/4K monitors, let me know the results
Several patches also received some updates, all is detailed in the help
Reply 87 of 896, by Curlyoxide
I can confirm latest patch fixed the resolution issue for Tomb Raider Last Revelation!
Thank you for the fix!
Reply 88 of 896, by catfromnesbox
hey, can you fix the problem in ''sonic adventure 2 battle'' where the truck appearing above sonic
Reply 89 of 896, by RaZziel94
uncaged wrote:
Peixoto wrote:
uncaged wrote:
Greetings!
Hello,I tried to change the resolution of my computer but it does not work. Can somebody please lend me an advice? Actually, when I run game through original launcher it runs in full screen with right resolution but after the movie ends it runs extremely slow but that is why you created this patch probably...
any way I beg you could you please help me? 😢
Reply 90 of 896, by Peixoto
Post your error.log please and an apitrace trace file, if possible
Reply 91 of 896, by RaZziel94
Emmm what? How? or where?
oh ok apitrace is program..
here is log from Peixoto´s file :
Peixotos's patch remote settings:
complatlayer: WinXPSP2
Controller: A=4;B=3;X=1;Y=2;LEFT_SHOULDER=6;RIGHT_SHOULDER=5;bLeftTrigger=11;bRightTrigger=7;start=9;back=10;LEFT_THUMB=12;RIGHT_THUMB=8;deadzone=0.25;ff=True;
d3D: 8
d3D_Driver: igdumdim32.dll
dshow: 1
error_log: C:\Program Files\CAPCOM\Onimusha\Peixoto\error.log
HD: 1
injector_dir: C:\Program Files\CAPCOM\Onimusha\Peixoto
max_4x3_res: 1024x768
Mydocs: C:\Users\Viktorie\Documents
os_version: 10.000000
resolutions_list: 320x200 320x240 400x300 512x384 640x400 640x480 800x600 1024x768 1280x600 1280x720 1280x768 1360x768 1366x768
script: Scripts\Onimusha.ahk
script_hwnd: 0x280962
target: C:\Program Files\CAPCOM\Onimusha\OnimuPC.exe
target_dir: C:\Program Files\CAPCOM\Onimusha
target_name: OnimuPC.exe
Textswap: samples=4;thumbnail=256;path=C:\Users\Viktorie\Documents\Games\Onimusha\Textures;Next=];Prev=[;dump=home;Switch=del;color_switch=c;Quick=shift;nopopins=True;
Succedeed to create the DirectShow interfaces
Succeeded to hook IVideoWindow::SetWindowPosition
Succeeded to hook IMediaControl::Run
Succeeded to create Direct3D8
Succeeded to hook IDirect3D8::CreateDevice
Succeeded to hook IDirect3DDevice8::EndScene
Succeeded to hook IDirect3DDevice8::CreateTexture
Succeeded to hook IDirect3DDevice8::SetTexture
Succeeded to hook IDirect3DTexture8::Release
Succeeded to hook IDirect3DTexture8::LockRect
Succeeded to hook IDirect3DTexture8::UnLockRect
Succeeded to hook IDirect3DTexture8::GetSurfaceLevel
Succeeded to hook IDirect3DSurface8::Release
Succeeded to hook IDirect3DSurface8::LockRect
Succeeded to hook IDirect3DSurface8::UnLockRect
Succeeded to hook IDirect3DDevice8::CreatePixelShader
Succeeded to hook IDirect3DDevice8::DeletePixelShader
Succeeded to hook IDirect3DDevice8::SetPixelShader
Max Primitives8388607
Succeeded to hook IDirect3DDevice8::SetVertexShader
Succeeded to hook IDirect3DDevice8::SetStreamSource
Succeeded to hook IDirect3DDevice8::DrawPrimitiveUp
Succeeded to hook IDirect3DDevice8::CreateVertexBuffer
Succeeded to hook IDirect3DDevice8::CopyRects
Succeeded to hook IDirect3DDevice8::Present
UnLockTexture8RectHook: 0
Succeeded to unhook IDirect3DSurface8::lockRect
Succeeded to hook IDirect3DSurface8::lockRect
Succeeded to unhook IDirect3DTexture8::lockRect
Succeeded to hook IDirect3DTexture8::lockRect
Succeeded to unhook IDirect3DDevice8::SetTexture
Succeeded to unhook IDirect3DTexture8::Release
736
The ssecond error log actually it does not start the game animore sounds work but video not maybe it is because I used dgvoodoocpl (the game runs beter but when sucking souls it drasticaly slows especialy when Im drawing high blue souls, the small window looked like it runed faster)btw i do not know how to use apitrace it opens comand prompt but imeditely closes
d3D: 8
dshow: 1
FMV_scale: 1
HD: 1
script_hwnd: 0xc05ce
Max Primitives1048576
1080127612401240124012401240124812481248124012401248124012481248124012401248124812481276124812481248124012401240124012401240124012401248124812481240124012401248124812401240124012401240124012401240124012481240124012401240124012401240124012761248124812401240
Reply 92 of 896, by Peixoto
I'm glad to help whenever i can, but without the trace file there is not much i can do.
APItrace comes with instructions
I also found it strange that your driver enumerates these modes: 320x200 320x240 400x300 512x384 640x400...
maybe intel drivers are different but... are you sure you don't have any other wrapper or anything installed conflicting with the patch?
Reply 93 of 896, by RaZziel94
Peixoto wrote:
I'm glad to help whenever i can, but without the trace file there is not much i can do. APItrace comes with instructions […]
Well it is low notebook Lenovo 100S it have integrated graphic lenovo Hd(not much) and 32 bit system without option to upgrade... Ok I will try to find out how.
Reply 94 of 896, by RaZziel94
Soo is it this ? DDraw.dll Image:
.MPRESS1
.MPRESS2
.rsrc
Wjvp
TTDq
(RuS
DzpX
QgNz
yK;R
6fFaG
WTvj
7H>tl
hJI
)O,Z'y
PvNZX
0QHs
hou
-upt*
V6}NG5!
oPI
nWS
btG
S|Hus)
lFz
Tni<
SI(?Q
aMeD
xdFC
RtpP
Arg^Oj
QpI
M%GP
CcO
Df<M
U&hf
maq
dzD
gch
ICb
ml7a!;
%UuA
*OuS|-
L?aX(
iAy
QKh
sRZ
mmD0
v~Lb
qYI8
XIEym
1o(6Zj
sytvO
'UQ#T
HPj u
|^sD!!G
+EvP'-
D5CI
cY[j
j-Vq
0ydQ
…Show last 3349 lines
\o#uo4
Te*Pm
Rzw
RQr
keT5
Mj{qK
QaIn
yPp
I0#qR4
YYs
"PLS
kxb
rLNG
xcl
Ykt8
x%Q;O7
YcW
fqN
sVHQXAm
mZ}f
swW
m=U0W
adLw
L5pD
b6AV
cu-Ea
nW[mR9
AJR
kIG
GIX
CL'za
lMa
9(*L'Wl
sF~-}W%
Dhh
g9J/oq
QmD
x-J'o
7dL&i
BD^fV
sqr
c)tW'`
Q`jU
x)OqD
=dKW
wbm
Mb/I;
FSGG
X!vW
GGE,U
S;zFm
Bwl
|!dDr
+Sa~ns
'TGB+g'
oww
vNtU
g^M{MY
LJXRt/|
enT
gT^_}wZ
XgJ
I=DF
uPZ
~L:HX
=IWDa
hwo
eZP
xHo
U<>OE
n[UA
Z<_Q6S
xTS
es+8R
DCS
Imu
WH9o
}N!U#=ia
60XiH
oK&U
xRd
yeG,D
!Nim
toO
p6mA
CmX
jjT.
q)hI
qIl\Smxmxi0
nkv2
kkk
l q\5M
GTp
qeuI
fqi<
m}{bF
yBP
ZqV
PkO
FaA@
Dvb
PNg
BZL
l (lL
EO;a,
jCZ
cz8U
U&TwM
EXa
2OhRI
P?YAB[-
Hto~
"/PbpQ
JTR
OSQc
sb<I
bwn0
tpL
jZxH
bWj
yxm=
g hi
WbS
QWv
oTW*
HHg
CzW
RT8w
Wco=X
oHs
OHB
BLa
hkJ
7Yq3e.4_
7Z5XO
ZnD
uWF`L
H|nn-
Dqv
sBO
KDa
>.TnW
nKG
fHFD
jt\~S
q[MB
Sszf
cfI
?5)TbS
lVa9FcG
yxgT
'mKW
u%oU4
gNY
aDV
TpF
t:Wcm
HfI
\wPY
IaEl
ptH
HLR
vrA
NMU
jNWj
a`HdO:Alp
u#Jr*U
jFTJ]
NZT
N6cG
Z7LWr
|pAA[
A3yFe
emD
HN"u;
Pcsf
Luo
DOLL$]
aFd
"tR8m2
fPa[>
j{JV
-]sMuP
@n`ZAq
lF9<o
YwS
zPwl|
Rs9kc
k-6ZAq
vEM
DVr_
dvJ*U
jax
?4ZKMHJ
VBt
OC'a5
dDM
d6ox
i'c-~*K
EiN
A1Gy]
nC`DY
jrC
izfm8z
z7cW
QI;I
K0qa
mXP
uzT.
a7X@x
I[WUY
Qzj)
3Wjw
kLk)
W0Rg
o*mWO-
4cUx'.
ZIR
hyQH
HlC
ndZ`N&
FiO
_-TtO
btN
KNK
6BFm
UKB
IdG<
MV5RlJ
bc)d
pUlI;
w}yt
s!5xy
bkkjE
Ykl
ty"g
DYL
zvL
Lvt
28zSK
qbz
jP~c#
LUR
Mgy
P^5UY
QX0A
MyL
tk[,WT~
Rf*^H
Gf.;D
qkc
7"UhX
wKE
ycm
RFcM~
b6Ut
VRV
g,Yq
Xtb0HHz0
Sdv
]ZkB
IFw
2uGb
FpI
AtgQ
T5Gi9$
ZGr
,RAt^
D0QE"d~
3^mbxK
xqe
Re6z
QXX
QUM
*aAY
SV:QF
Oqr=q
"XYI
L]Nl
wgV-
Wu4,W
F/Hg*
tkW
ULCVF-
`D3V#K
xoD
(&7XjK
jfg
LZ7T
Ady
.UH=HdHhI
00lbIA
'aWC
Mdz
=yHXs
EyF
c|~/Ft
\%Wid
Pe=N
/DDc
PQV
Wpt}
_x f#6*RF3
.elQ_
eRG
KQf
&R Bf
Q~cO
Paj
.BOS
QsQ
RR-iz>
t5jD
H;joP
RO>T
`NP8V(A
Y9eW6'
oFKN
G)B_e
i]Gs
Y{_>:o?~T
OGd
uAd
Gub2D
KZPi
JW'7x
Ua9v
O|9^&wA
IUni,
cPk
cbC1#f
baj@
JCJp
uTi
!1D&uL
ySF
HUy
6trL,
f&Eb
gGb
PTw
S$dt
eBx
XI77H
Hzf
dek
K)q j,
ufOL
AYj
NogP
$SHi
bbjq_
L\CWX~
hDw
hlt~
cC^au
He~BO
#Ae(xu
K1pnkQv
kRy
dGc0
riE
pjz
cac
w;QB
UIw
KHz0
IDa
eUp
KVR
cG<B
KeY
^Jvt8
ZQIR4j
fhx
eox?/
,cnDw
fQt
~D9Gi+
uO#O
vnb
YqM
,rco6
NQt;'
ntY
LZy1
yhb
QwEeXRj[
#VeZC,
EER
bYJzL<
T74yV
eeu
wpq
hWa^
J"H}_r
EfB
KXE
n]yJ
[alWm!O+
rAO-D
xBo
WsD3R-
oLWE;d
lGW?
ES?w
4Oo\g
+zXn
MEhk
0}*>itt
Bzn/
M|y3Z71HS
XnQ
qwJD
Qo%d
lQm
uni
UfCP
Q!jz
U)ZZ
b@nO
vXe?-Z`C
t7vWr?
wew
dqR
k!r}6C
/hGS
+ptS
CpoO&a
lCi0{W
HWcP:
M.ID
Vj]G
GMHzmL
dWD
uoKR
xd70nK
rf-w
EbZ\
poH;
Bba5f
Wsw`
vC{W
wOX
kzSe
k7XL`
4(lAi
LrrR
zsp
IK>N"
JSu
IUX
/1n,lE
Lsu
bYOS
_JP$HV
Z(geHLo
YXq;
QI(R
sRz,
@Tr'P?
uAj
RY}8V
OJu
Mt:PR\
iSJ
lRR=
/&muFW
cvOr
Xy#*C
1XsW
Kb;G
DK2k
GGJ
QL"v5
c[sL!
JREwC
IeyzK
EyiQ&
GWg
h7vZ
pNrSh
AlZS
BZXy! 6"
yDO
kHG
f{l9"G
rrWs
*ZZv
FpJw
eEv
Jtj
LDV
'OHE
tRO
UVB
%qaozO
)YCeX
Pra
IpX
l^w$Q
AoaJ3
XG2D
oTn$z
wqH7X@%
Wvn
coB
pwgsq
_quJ
NGQN;
!x$:Mm
yHZZ
A-zNN
/zQZ
QjE
qlg
hr&\rhv
BJ/z
x+'%B*Z
iNS
sVT
k(yr
MV{A4k
5BHUm
Jc`V#1e
dnX
Jj%e
~A*9hY
o@Jf
AM3n5
tSn
URi
O2P=YE
MKU
JrZDN
RXG
WuI}V8k
OyP
FWNs
nhY
LSa
ncr
^TQ[i
B3rN
!8jVS
AC[Up#P
ULg
Y7sD{
Mcf
RT_CUSTOM
VS_VERSION_INFO
StringFileInfo
CompanyName
FileDescription
dgVoodoo 2.54 DirectDraw Wrapper
FileVersion
InternalName
DDraw.dll
LegalCopyright
Copyright (C) 2013-2017
OriginalFilename
DDraw.dll
ProductName
dgVoodoo
ProductVersion
VarFileInfo
Translation
qa&h\
Yuk]
U%Qx
BvH
]FSacF#b
b>Ae-
^jfMq
-wGmm-
tef
nXW
ZmD
YZMc
cX8&v
PJZ
tKF9
lj-.X
QCdL6
Y<Ly
GvY?
fzp(tj
Rv[~%'G.
Jx78!T_
uAv^
>FQG>'
DAC4u
Fnk
ofo^
Ner
K.l6q
jAd
hAES
hNq
F(VQka
ysM
bkF
obK
5xiF
"rsH
YrA;
LK=m
u"Ab:
wBR
8OjD@
Z<kBPa0B
PAR<
"}UyC
zjP3
8~3fnX6
U+BdGr
Uzc
bAn
/-R#L1Q
^ks,n"Gx
Di%m
`ABiNi
rqQ
2wiW
ph+ii
93Goz%4&
CZv
wufN
Mrm
VU2I
kpVYp
XGnJJ
xDn"
dbr\
pI\h
uX=m;?
uzU
Oqp
Lg.v
CA[O
Gvp
qDJ
gwD
Ogf
CEK
jBN
abI
JZtU
gXM
LF)X
pSf
nsj
Xtw)U
olC
L.Qk
oQi
+G5A/8h&
IIV
BxX
=zv4&Cx
ZEk
)NUh
HhU
ip,D
UwR
"$#4s4Z0xu
l5t^)'[e
oSn.
ycwq
8o+mm
fVE
Rnr
3GBp
GFwWA
hNu59C
n-fr
KQbi6
Cyps
GXn
A'[J-1A
J[1j7O
P+*xU
eLi
R?jL
R":VQ
U6Jy
n*JK
qwQ
%DvU
OVt-z
DAi'i
Mhs
IEpb
MFY
vcR
xtT6
cy>Y
"`pyn
1Ujc
WGI
DxM
nzm
YPXw[rLR
Jfl
QmG
qEI
Tao
2PxW
B:fW
kZX=h)
GFT
m{MG
Xf.j
zT#'w|+&$
nBh
wIQ
K?fJ|
1zzG
T_6VN79
H^O*iAJ\>
D_k?x
wvD
RAZ|
xML
elYEK
BeT3~
=Xco
lMQ
@qlYJ
Tml
IwX
CbC
|JCI6
D*jbtB
pcw
e(ie
}GmV
1sDvp@]I
XPWz"T#
zXD
+hca
XZrb
MlS
.EHl
c}yb3
\pQi
hP%Td
S0DQ@
qHdw;
Ra*kA
GLM
ypgM
Nyv
CHq
XRB$
3ysh
vshU
n9L*RI
9JXc\
xbU
K<YZ52
/wHS
itu_
tZ(e7
HtiHt
Htr
T$xR
DDraw.dll
AcquireDDThreadLock
CompleteCreateSysmemSurface
D3DParseUnknownCommand
DDInternalLock
DDInternalUnlock
DirectDrawCreate
DirectDrawCreateClipper
DirectDrawCreateEx
DirectDrawEnumerateA
DirectDrawEnumerateExA
DirectDrawEnumerateExW
DirectDrawEnumerateW
DllCanUnloadNow
DllGetClassObject
ReleaseDDThreadLock
GetModuleHandleA
GetProcAddress
KERNEL32.DLL
SHLWAPI.dll
PathAppendW
USER32.dll
GetDC
GDI32.dll
BitBlt
SHELL32.dll
SHGetFolderPathW
ole32.dll
CoTaskMemFree
WQI
UWVS
9L$ts
D$xf
t$t#t$l
D$Hf
T$sf
D$t#D$h
D$t+D$\
D$Hf
D$Hf
L$xf
D$t+D$\
T$Df
t$Hf
D$Hf
D$Hf
D$Hf
t$\tZ
D$tIt
9l$tr
<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">
<trustInfo xmlns="urn:schemas-microsoft-com:asm.v3">
<security>
<requestedPrivileges>
<requestedExecutionLevel level="asInvoker" uiAccess="false"></requestedExecutionLevel>
</requestedPrivileges>
</security>
</trustInfo>
</assembly>
D3D8.dll Image: .MPRESS1
.MPRESS2
.rsrc
nt\Q{T
hCl
FxM
"Zli=
mSe
quE
wWO
xGfr
OKR@
YEgR
O8Rp
pDK
lgU*:}
TUr>
oXyj
w5rQ'
wrg
}mFl
Qj~I
&HFtz
cyH
UfD
DfQ
wYO`
sil
-vBv
Pd6s
xohnEH
SpyE6
Ch4 M>
T6fw(
Y+E4zj
ffJ>y
xyCG5
U*Qvh^
uuw
G@(PZ
1RrQ
GAN
g4!Hs
jCi
tbnN
gQk
lELB"x
Jxf
jrr
fNK0
tr&j.
Y"4V[{Cyxa
Gwm7
LZM
mVZA
rfV
jul
cpg
Ihr
\ARp
XhS2
pp4a9
S@OO
CzGZ
Sn.S
tPj
eKZ
f!CU
Y[q]:O
hf'X
UVr
kTh
5s%yb
qRL
+lst
M:t"s
F>H%I
WAEAPn
gqq
y~Rp
ujEl
.HYOT
_k8)Cf[
s5>`;up
RRv-u
<lq|ed
DAw
(Ui!b
YMHC^
^fVa
qK)S
Kue
bQO0
fuW
x v7r
N3Bv
e%Zz
3mwd
gM+xr
phP
zXZ/
ZIXF&
*FAa
%HRm
QmE
GC0B
bzP
H3IA
gjpm
Rnw
fSb
igD
XQ~b
f5ics
EKzz
HTPx
0RZR
yGi
Ouo
KP2J^
HGg
fbT
JHi
KdVF
aUlVi
YBHBn^!
lCr
nCR
KCp
FW&_k"P
U`Tu
r~Drn
I1jT
Bey
sBYs
Dnn3
jwR
UOQ
t&11YQ
zPr^
bNe7
qyc
LP.kq
?!xPl
GbN
qPN
n3TT
Q10Jm
xWC
RAt"W
g3FyW
iAfrc
H*B\m
hJT
OfV
gIl
oQ(oiF
IYF
vux
Bdu
0wV0x
hoO
xvW
x;Rc
PZq
GvR
fcj
o5wH
GqiM
dJu8
gK(lJ
n|Zd
!c-Mh
c\Uj
VEO
cUbAz
K$DU
iTav
QrT
&koD
I$8Mj
ZDQ"
F;Op
lWtu
biM
EQB
gBL/
iI$r2|
$N?.%dV
fbd
zWy5G9
Bcz
lsI
gRy'
/:wXC
iNO
Cfs
qhvZ
bCJ3fEos
zIS
uM9MR~
VrE
lrU
Pns
D%ZY
XX-Ax
rEH
LSm,O
oN@y
yJv
ius'
'?fl||M
Z\1$vj`
5N|}_;JHB
$OUi
H$*uW
CmxS
lGG
ywc
tgl
haO
L+FuX
Shz
WNJ
oGS
PzK
Q^FB
v<Skq
peu'Cb
QXrs
BaeS
'XMN
Y4Tg
BSj*-m7
yLr~
wlH
cL~pt
myw
cxt'A
GdT1
,r#IO
(w$jh0
bKXP
TlK
CdS
duo
YnV 8B4r-w9
YqM8
PkOF
qqS>
HYs
Tnx
gv'Y
_XkZ
qu+q
pjM
PLH
]kfd
Q#B:%ol
Xa2Z
9KPEU]
JEW
+UZX
RjD
\5\nqR
*^tkh
AMb,-
uf(d
>l.aN
ryp
tDp
o8Ei
Z Dy
zh><E
C*MV
fFC!a8
VQq
JJs4
X5UA
QXIGf
ZLB
QER
Ccb
uQxM
:Riy
llf
gCB
ldA
tEc
Mc'c
wh|S
ihH3
klN
TmY
HNd
1D{YjO
MFq
BIP
QX>H
vWx
=Jx!b?_&
\Fvf
]Ogq
c{Db
u=jI
Ycl
avqI
N'LL
k:hF
dxhka
i!CW.
tke
Z}Tv
mh(aW
uU?x
cPW7
8uln?
sBg
wIh
yCW
STq
JLq
zrz^
mTB
kxZ,
tR>g
qEu
&slh
SSz3
zEO
b&xmm
oI|AC'd
lXF
afdj+~
scW
O.EA
ZR;w
jtsr
QGl
-tCn
Exf
o9JY,!q
MWy
orp5
Sgk=?W
Wtg
wGH
pb_v X
cvH
9ruea
Bsaf
vC7YK
PYN
zzw
dJ,y9
PICmri
M1Sh
1zau?}
nOe&
>apu
Aj`i
oYk$
4TfO
WbKJ
BK]T
tVo
czS
RYN
ptxu
lgK
v!EofF
XlY
aWhY
RNew(
,pBIn
pAZU
vDB
ZZw=
{&PWRZ
DqF
MgO
XsG
VC5S
nJU>J4s5
NFG{UZ
PXb
PO$Y
`=L(#dr
kUGu
y&LR^
0^hbp6
TVX
ldK
7DCI
o@wz
rit
^8TiD0R
UIK
/kdDc
EgP.x
RzE;
:nZh3
NwIVV
La}D
SZp
Yfr
v{{[%vvny
Hbb
gC-(Y
7Q+gN
IC{o
QgO
SZa$
evR
of~{j
iQc
Vy1_F
hx!iX
oB{N
Gtw
4Pnpn
jiKl
ymc
bVx<Q
@GHA
oQq
c%i5W
KZ"J7f
Ou_U
ECd
dLt
JyhW
EgW;
LCC
Xfu
Nkg
z]nre
bAH9
phy
`oGMPEL
uYq
<Irg&!#
TAl
DVak@
mZ,yR
IEs
SRJ
RUo
QrF
jNRx[
kyK
IY; `iO
d/Ic
GPk\
pvfpM
NQO
FVNe
Pu(L
fhN6~Z
9{bb<?,wh
nJw$C
zyw5
ENn
PUj
T~Ut
qfK
jAf
TfP
]W4oT
hWyj
Iw,.Oo
PrX
Tml8$
sR W
kvW
E6U>f
V'KZ
jom
QB3t
ulG,
"jR4q
~hSb
zGoR
`ue}0D|
Upk
vhOAg-
DQ<J
Y)gO
bQp
GXW
LXI/
viM=D^A(
"1pJv
ZJQ
lZJ
%djB
OrpT?
V+TKJ
lC5u=
Pvc
Z Fa
^AY*<W
jbP
see
vs&q
z2RXm!
yZh
ihj
nhl
itL
"5F%s;w
JfW
bsM
_V'oNxE
+ejy
GAl
h~Gj{G
xMB
v@yQ
brSZ
CZt
tXK
v>ym>B
pmf
g5EEE2
thB/H
Bigh
EcM
eb1ikCq
h7UT
zug
7pUL
yC_P
PYM
ROk
E#KJ
sKsPqO4
inW
slQs
("AZg?
Ec|Z
ZI{l
b7*Sq
lGV
oU=aA
nNZ
dvq
k.pTf
CGM
I)tJGD~
}TpO?
j#A:De
nCZ|l
3Vrd-
rYN?
LCg
>gUn#
FTd
aat
FDM
eyO)s
r0SX
qoe
Z_kuj'
HLX
jYU8y
GPx
k47sO'
MrK
HbF
KmB[~
FGO
NYH
+uVp
Hwb
dee`
jKsY
fgU
KeFC|
rg_g
kIc
wC0l
Svg&
mWF(J
Xns$
jky'
2Gep
LF;TH8b
Abq
v/ZSd
OMP
xyM+
PAc
S/NE
5Or?C
MKd
lwN
oKr@"2
cVv
!uRg
PNwT
5n-Zrfy
C(dQ
pYh
cAYJ
#i-XJc
DV:P
jz@d
t9h-m
yuhHWo
-6CFq
Uy0b
;cY-i
INy
kze
jOTk
(XHbV
!glq
xwr
mCE=
w/WB
cWep
UTi
~VgW
VVE
l|o^c
U)Fu
4gIu
wgn#
6suQ
kxQ
2D@ppM
<zj$_g
*M;oy
NtF
bjH
BxMeO
=]hOY
DIA
~UsPL
qkY
knhv*
faT
XiaC
MVN
)c@SQ
+dp)4nVg
XCL.n
'X_SF}
NMg
g%YH
^jkx:$
dFn
YyI
BxD
,EpM
7?bjT
GaO
Lxk
H?7sOT
vn+~y
J}8T4>T
kFz
TlN
Xjt
vuIi
LyP
Oig
nf{l
LPW$
kaW
e?Cf
HJL
H1Yi
Ltb
tmr
rOB
Il3A
o>JH
Bcw}`h
$H&[Ts
#MMo
gDt
VZ6i
Ha{q
oTgZ
xfzt
3VSR\D
Xw0NS
Mpa
idN}
mDf!
Alq
)y}FT.Z
BO?Ej
Nau
Idl
yhi~
ov8e
HIS
Hfl
iwi!
S%Cu
f$Oh
Ji7O
dJ=W
Ke,c
JHN
ZP5L2
"I8(As
gpY
xGV
I`YE
vzr
?ek:h2N
.jLsE*
%dLc
ppY
K8sbz!
WdS
yH]2P
J*wR
vOc
omb
fN4j
Uiqz
iwQ
N7 Hu
Q7TuV
OXs
H-fKP
qeK
o$Y`R
IeLH
OS-x
Qiv
*sYFII
VDt
#apC^
Enl
OAWU%s\m
jBKC
w{#Oo(
:vMN:J
exQ
;XY47(e^
HGK
LC$V
%fSz
ff3iV
Z\qc
c{oeL
aNJM
qCSRO
rTM~
0caO
psK
eBz
N[W5c
oo=QH[,a
GVOu.
QBXV
aFO
fT: &r
"k>#bTc
BQ8U
bFd
iFi
GfL
csic
ZL'K
F)Hj
Wmx)
xSM
MRD
fKr
VEg
sQ T
Cn[e
fzK
jqT
CJD
CmAO
pvk
VG>Cd
m:djt
rra
Bo2N`
b uD
ItRY
ePY
B?Cu
edFHs1
PkN
R3Vx
PmQ
Cpo
AN2H
dAK&
NczM
S8tdP@
qmD
DWZ
~oZTfcG
8lOV
pap
3adc
Been
|dx-k
ANF
%PiX
yqg
"Z0Hw
SUlk@
NFM
WEH
g9kT
BgPZ(
qcU
afP
dkk
UKH
GD`&~Dw
WP[l;
wPKuq
%r7w:t
YsR
wDc
c1Qz
%,&TnM
GTs
xgQ
bej(r{`
blR
HEE
2URf
bM-!uH/
TJW
&yry
ihrV
WqJ[3
LoL
Ei,N
sQ++-#G
tI]T%{
Ry}J
0ka.y
BnQ
wbZ
LrZ
VVG
aC[by
1kRj(
LRy
1tnb
wxg
PPu
yoo
QJj
SDp
"wj<z:I
qJd|
vWlA
9GLY;
Wh6T
FF^C
NhZ
ZPe
Q6ll
DeC
WMr%
W/OB
N2th3
qhR
tGs
+jb7r
@SgE
k7WB/
crH
aUS
ZpQf
Z>yp
Ff(ht
ZFq
Att
cxD
5nBF
{9iLRbp
ngkd
'iqKV
Dlv
uITg5
lYw
gIZc'
(TJ{p
~bHZ
fk[J
nju0
g~qDv;
gMH'
kyi
fqL
cho
XbMW
BlF
kjGd
XEu
Kt&T
q}aH
TtI_V
OCsL
QGh
c`u6T[
CIv
hPL
Tadab
Zy?Q6q
xsh}
MnO
|ZTM
j8v_X
E76/d[zM
QYMye
@ab}b
jp8d
FDs
Q?"yq
hKZ
oJj
EA>iZ
y4/dM(
^N7Ik
IYW
kkv
!A[zK
nXO
tLM}
FDMC"\I
Cm=M
Z.AQE:
~DLd
BZ/["G
Rzqx
lVB
tUf
mwG
D^pV
GrX
jpZ
UvO>
REZ
ufTC<m]
`MIr
$hVB
M_XX
NCV
)Zz`d
wsm
HDN
wuc
tTR
2.fu1C
ACg#
sBL
&lxuW
Gb;W
FZGM
Fv\Y
$PDtF)u
QwVI
MWY
SiI#
[b(WK0
W&i6Xj`eJ
ovF
DrnX
yf=d
(T7Eif
wRz
Hfq\
olh
:&okn
RwW|l(
i%^XSY
PrJ
S,|YKR
vtxM
KCg
dDIV
&jg-$|d
]M)LB]*
LL*lU
qln
Emo
BZB
7jw}j
Mk=i
5OSS
mwE
eRb]
rB<zU|]
WUm
hxL
%"etM
,WaU
kgC
aQn=_=X
N\r*h^
GVc
vpv
yca
G5yI\
WUR
qlV
rWEx$R
kZv
=n@dRW
c-BtP
xpgKT
zx+(AS
CW*Z
N<sU
iLU~a
aun
t4N"r
PBP
zUw
FMV\H
oWQ
jThS
XkT
{boA
kby
ils
V=Xk
v6^w_D
lMQ
iRn
nUw
SAj
Y1FUi
zgoXVm
xml;
Ts{i
DtC
HOK
j;DM
srX
CqE
Nem
0\Z\By
LQyd
,<R}kc
K=&de
xE8h
pnSj
#gNtR
VtT
Ro*j
YRe
,xEAw
HbK
kB+c?RWA
QJyD
VDv
BdH
fpKm
hWA
tr-Z
FWiP
#fm"L
vHQ
uAR
C[XL:{VH2
bZW
WiG
NcN
tUFm
$Tgu
vsX&
-_B)Yv
.$C(bNi*
ErD
kHu
vUo
HmTM
VnF
tyZ4
JzOY
uCJ
r?Ns6
Vm*PM?
y.A7%R
rOa`
,lFg
&neI
JuK
=CIe
DHFn
DvF
pG*bv
PUY
-IiH
ap<W
tqM
Uce
uAwu
gDc
o,Lg +
b5mC7
eoN
tZd'
dv2V
Zoe{]92
(kTU
+(ku P8f
alzg
rdeqV
QcK/
ZNhE
TX`L
RT_CUSTOM
VS_VERSION_INFO
StringFileInfo
CompanyName
FileDescription
dgVoodoo 2.54 Direct3D8 Wrapper
FileVersion
InternalName
D3D8.dll
LegalCopyright
OriginalFilename
D3D8.dll
ProductName
dgVoodoo
ProductVersion
VarFileInfo
Translation
M4EIUij
QZ$=u
iTz$p
afVd
x|Gc
gdWP
PmK3
NSv
xb/Z
zZKu
Saf
UUSj
aJx
_EUx
LU\I
*nNee
~IHI
2QtH
|QGpL
gJ<zL2"~
iLn
IH![-wXPZakVM
iq)t
hEK
Qw`nJ
3$CtQ
h|kx&
mmu
jnp
w X@tr
<fTg'
KAF
jG;R
Rdf6
`cp<A
rtQM
mKK
w'r,WGFr
APS.
Cgd
fbt
sNj
XRP,EC
B]"J2a
enY
FzS
akMS
wMF
mMV=
KlM&
zmc{
U^jw
isQ
Lv~:J
chG
~W&mb
Uco
eby
)JU|J
VPS
D3D8.dll
DebugSetMute
Direct3DCreate8
ValidatePixelShader
ValidateVertexShader
GetModuleHandleA
GetProcAddress
KERNEL32.DLL
SHLWAPI.dll
PathAppendW
USER32.dll
GetDC
GDI32.dll
BitBlt
SHELL32.dll
SHGetFolderPathW
ole32.dll
CoTaskMemFree
WQI
UWVS
9L$ts
D$xf
t$t#t$l
D$Hf
T$sf
D$t#D$h
D$t+D$\
D$Hf
D$Hf
L$xf
D$t+D$\
T$Df
t$Hf
D$Hf
D$Hf
D$Hf
t$\tZ
D$tIt
9l$tr
<security>
</security>
</trustInfo>
</assembly>
Peixoto.Dll Image:
jjj
jjj
jjj
jjj
!This program cannot be run in DOS mode.
@@Rich{
.text
`.rdata
@.data
.data1
.rsrc
@.reloc
VWj
PQVW
QVWh
VWj
D$HSP
Qhxs
hhs
UhHs
Wh(s
QSSSSSSUP
SSj
SSj
RSSWP
T$LRj
T$4SRP
T$$Rh
L$,Qh
T$LRj
QSUV
QSUV
SUW
SUV
L$ SU3
D$ ;D$0r
SUV
D$$VUPWS
T$$QVURWS
L$ ;L$0r
SUV
L$ SU3
D$ ;D$0r
uV9n
D$$VRP
L$$RVPQ
D$(;D$,r
D$$PSVQ
SVW
SVW
SVW
QDP
HLj
HLj
VSW
UVWSP
VRS
uL9D$
tBj
jXP
VWP
FTQ
PQR
VRP
VWSP
SVW
WVP
t(9p8u#
DSUVW
T$,RPV
T$XVR
D$\PV
L$XVQ
htt
hHt
Vhxu
u$Phtu
hDu
htu
htu
htu
htu
SVWPQR
UVWh
PpUSQ
SUR
UVW
BPQP
IpPWSV
T$0WP
D$4RPV
D$ WPV
SVQ
L$(QR
D$,VPU
L$$SUP
SUV
D$ SQ
SVW
WRV
T$(QR
4VWj,
D$HQ
L$HR
hVW
D$Hj
L$DQR
D$HPQ
T$LS
T$TV
T$dW
D$ SP
T$ Rj
T$$Rj
T$@Rj
T$DRj
T$(Rj
T$,Rj
T$0Rj
T$4Rj
T$8Rj
T$<Rj
F0Qj
~D]9|$Dt
V0PWQ
V(Pj
V(Pj
V8Pj
V8Pj
WVP
|$,VWSP
t';p<u"
WVP
UQWS
QRPV
@PQRP
QRP
@PQRP
QRP
Q0VP
WUS
PWSV
PQRV
@PQRP
QRP
HLR
QRP
QSUVWh
T$$UWSP
WRP
SVWh
SVP
VSP
WVP
SUVWh
QWSU
uE9D$ u?
SVh
@PQRP
QRP
HLR
QRP
SUVWh
VSW
SUVWh
Q$PUWS
VWh
@PQRP
QRP
HLR
QRP
SUVh
QSV
QQP
REU
t';p(u"
QQP
PSWV
UBPR
WVP
WSVP
SVP
UVWj
tEVh
PVW
D$$Pj
T$,Rj
t*;p<u%
VRP
PQR
VWSP
L$ Qj
WPV
SQV
SRV
WVP
VDR
O0PQ
SUj8
nDj
PWS
QRU
W,RP
QRVu
RVu
QDPV
B@QV
QLPV
BHQV
QPj
QRj
vBU
tPW3
SUV
Rj@UW
PQUW
SVW
SVW
SVW
SVWP
SVW
tVSV
SVW
rw+M
SWj
NNt
t}HHts
KHt"Ht
HHu$
t%Vhj
SVW
<hTr
hLr
hHr
hDr
WVS
WVS
WVS
u WPS
uCWVS
t%WVS
hXv
8csm
SVW
SVW
0PQR
SVWtW
tJjP
VWu
tVSW
SVWj
uXP
EhW
u$VW
=DXT1t
=DXT2t
=DXT3t
=DXT4t
=DXT5u
MD+E8+UH;
ET+M<+EL;
MlQS
ElY
UHR
RSP
Qpj
ElY
M(SP
uxP
FHPW
HHj
HHj
UdRP
Wj4P
SWP
SSSP
St1j
WWP
WWWP
EpS3
RSP
UtuU
#=DXT2t
=DXT3t
=DXT4t
=DXT5u
ELu
+}T+uX
uxVV
EHt
uxVV
SVW
Pht}
uojPZ
jWZ
jNZ
at)It;
tyj
OtH
atCJtP
djQ
QQS
KtP
hTEXT
QQS
FFGG
stP
hFILE
sth
hLINE
~DCP
YYh
SUVW3
uS@@j
YYj
vcII)-p
stW
E Ph<
PVh(
VVP
uwS
UVW
t$Wh
DXT1t$
DXT2t
DXT3t
DXT4t
DXT5u
CCGG;\$$
GG9E
CCGG;\$$
QSV
VWj
VWj
t:It.
tDItA
WVj
WVj
WVj
WVj
WVj
WVj
WSj
WSj
SWj
SWj
8SVW3
WRWWQP
`SVW
wN9E
uh9U
=DXT1t$=DXT2t
=DXT3t
=DXT4t
=DXT5t
tm9U
=DXT1tu=DXT2tn=YUY2t+=DXT3t`=DXT4tY=DXT5tR=UYVYt
um;E
ud;u
HVW
HtkH
HtpHH
HHt|H
QQV
tAS
SVWh
9pHt_
tQSW
WSS
WSS
BBF;
BBF;
BBF;
BBF;
SVW3
SVW3
BBF;
BBF;
SVW3
SVW3
BBF;
SVW3
SVW3
BBG;
SVW3
BBC
(SVW3
(SVW3
SVW3
BBA
,SVW3
s=SVW3
QQSVWj
UYVYu
RVP
SVW
CSj
=DXT1
=DXT2ty=DXT3tR=DXT4t+=DXT5
=DXT2t
=DXT3t
VWuL
DzD
DXT13
HtaHHt3
=DXT2
=YUY2
=DXT3tf=DXT4t5=DXT5
tqW
khl
tNW
Hhl
PVVt;
AuA
a(Cj
AuV
tQW
tVW
YYu
D$PP
PVV
D$PPVV
PVV
D$PPVV
D$TP
D$PPVVt;
upW
ELP
ELP
SWj
Q 9~Pt,Sj
9NPt
FXP
SWj
Fxf
Flu
^xWW
QWSP
SVW
uXtn
PPPP
uhPP
uhPP
slt
UH+U@
EL+ED
MPu/
;Upr
;EXr
Ep;Ctw
EX;Cx
Epj
spY
EdPV
slt
Edt2
;ETs'
;ETr
ETu
Mlv
Mt)}t
;Epv
KtPQ
U(RP
UhsJ
;UPr
Uhr
sX;up
UuL
UVWu>
YtO
QSVW3
PWh
SVW`
,SVW
SWj%Y3
VWu
tUj
AuM
PSV
uxj
9U|VW
tFj
Exf
ETP
]lf9ELt
ETj@
YY|d
VWj
Edj
ExP
ElP
Uxu
(SVW
APY
AThP
Apf
AxB
A<EF
QQW
Wuq9E
WVUS
WVUS
nD$H
oL$H
oL$H
oD$P
oL$X
oT$p
ol$x
oL$H
oL$H
oD$P
oL$X
oT$p
ol$x
oL$P
od$x
ot$H
od$p
NULL
PID_%4X
PID_
VID_%4X
VID_
DeviceID
Win32_PNPEntity
\\.\root\cimv2
{0B2B8630-AD35-11D0-8EA6-00609797EA5B}
cFailed to load AHK dll
.ahk
\My Cheat Tables\
\AutoHotKey.dll
peixoto.dll
Arial
ABCDEFGHIJKLMNO
RSTU
!"#$%&'()XYZ*+,[-./\]^_`abcdefghijklm
VGH#
JL@1@IKZ
!2345MNPOQSTU;>]>^a
++-]N.Pa
./01.]9:N[P9:S
.,,,,++.]-,,MN,P,,
ol$P
ol$P
ol$P
ol$P
oL$P
od$x
ot$H
od$p
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
oL$P
od$x
ot$H
od$p
ol$P
ol$P
ol$P
ol$P
oL$P
od$x
ot$H
od$p
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ML;MH
bad allocation
Copyright Daniel Lobo, aka Peixoto: dabo.loniel@gmail.com
ahktextdll
AutoHotkey.dll
OPAL8
X8RGB
A8RGB
A4RGB
A1RGB
X1RGB
RG6B
wglDXUnlockObjectsNV
wglDXLockObjectsNV
wglDXObjectAccessNV
wglDXUnregisterObjectNV
wglDXRegisterObjectNV
wglDXCloseDeviceNV
wglDXOpenDeviceNV
wglDXSetResourceShareHandleNV
wglCreateContextAttribsARB
AHK Plugin
ahkReady
ahkdll
ahkExec
AutoHotKey.dll
UYVY
YUY2
DXT1
DXT2
DXT3
DXT4
DXT5
=%s(%d) : (Assembly Error) %s
%s(%d) : (Assembly Error) statement incomplete
%s(%d) : (Assembly Error) constant definition in shader body
def
%s(%d) : (Assembly Error) shader version expected
syntax error
sat
logp
expp
dst
lit
log
exp
sge
slt
max
min
rsq
rcp
bem
texld
texdepth
texcrd
phase
texdp3tex
texm3x3
texreg2rgb
texdp3
texm3x2depth
texm3x3vspec
texm3x3spec
texm3x3tex
texm3x3pad
texm3x2tex
texm3x2pad
texreg2gb
texreg2ar
texbeml
texbem
tex
texkill
texcoord
cmp
cnd
lrp
frc
mul
mad
sub
add
mov
nop
invalid mask '%s'
invalid swizzle '%s'
invalid register '%s[%d]'
invalid register '%s[a0.x + %d]'
invalid register '%s'
oFog
oPts
oPos
_bias
invalid constant
comment extends past end-of-file
preprocessor directives are not supported
#line
Internal assembler error! %d
coissue not supported in vertex shaders
a0.x can only appear once in an index expression
illegal register number
illegal register in index expression
complement cannot be used with other modifiers
complement not supported in vertex shaders
negate and divide modifiers cannot be combined
constant modifiers not supported in ps.1.4
invalid version
yacc stack overflow
statement expected
ValidatePixelShader
d3d8.dll
d3d8d.dll
LoadDebugRuntime
SOFTWARE\Microsoft\Direct3D
D3DX8 Shader Assembler Version 0.91
DebugSetMute
BLM
Software\Microsoft\Direct3D
DisableMMX
GenuineIntel
DisableD3DXPSGP
Application transferred too many scanlines
Invalid SOS parameters for sequential JPEG
Corrupt JPEG data: found marker 0x%02x instead of RST%d
Premature end of JPEG file
Warning: unknown JFIF revision number %d.%02d
Corrupt JPEG data: bad Huffman code
Corrupt JPEG data: premature end of data segment
Corrupt JPEG data: %u extraneous bytes before marker 0x%02x
Inconsistent progression sequence for component %d coefficient %d
Unknown Adobe color transform code %d
Obtained XMS handle %u
Freed XMS handle %u
Unrecognized component IDs %d %d %d, assuming YCbCr
Opened temporary file %s
Closed temporary file %s
Ss=%d, Se=%d, Ah=%d, Al=%d
Component %d: dc=%d ac=%d
Start Of Scan: %d components
Start of Image
Component %d: %dhx%dv q=%d
Start Of Frame 0x%02x: width=%u, height=%u, components=%d
Smoothing not supported with nonstandard sampling ratios
RST%d
At marker 0x%02x, recovery action %d
Selected %d colors for quantization
Quantizing to %d colors
Quantizing to %d = %d*%d*%d colors
%4u %4u %4u %4u %4u %4u %4u %4u
Unexpected marker 0x%02x
Skipping marker 0x%02x, length %u
with %d x %d thumbnail image
Unknown JFIF minor revision number %d.%02d
Warning: thumbnail image size does not match data length %u
JFIF APP0 marker, density %dx%d %d
%3d %3d %3d %3d %3d %3d %3d %3d
End Of Image
Obtained EMS handle %u
Freed EMS handle %u
Define Restart Interval %u
Define Quantization Table %d precision %d
Define Huffman Table 0x%02x
Define Arithmetic Table 0x%02x: 0x%02x
Unknown APP14 marker (not Adobe), length %u
Unknown APP0 marker (not JFIF), length %u
Adobe APP14 marker: version %d, flags 0x%04x 0x%04x, transform %d
Caution: quantization tables are too coarse for baseline JPEG
6a 7-Feb-96
Copyright (C) 1996, Thomas G. Lane
Write to XMS failed
Read from XMS failed
Image too wide for this implementation
Virtual array controller messed up
Unsupported marker type 0x%02x
Application transferred too few scanlines
Write failed on temporary file --- out of disk space?
Seek failed on temporary file
Read failed on temporary file
Failed to create temporary file %s
Invalid JPEG file structure: SOS before SOF
Invalid JPEG file structure: two SOI markers
Unsupported JPEG process: SOF type 0x%02x
Invalid JPEG file structure: missing SOS marker
Invalid JPEG file structure: two SOF markers
Cannot quantize to more than %d colors
Cannot quantize to fewer than %d colors
Cannot quantize more than %d color components
Insufficient memory (case %d)
Not a JPEG file: starts with 0x%02x 0x%02x
Quantization table 0x%02x was not defined
JPEG datastream contains no image
Huffman table 0x%02x was not defined
Backing store not supported
Requested feature was omitted at compile time
Not implemented yet
Invalid color quantization mode change
Scan script does not transmit all data
Cannot transcode due to multiple use of quantization table %d
Premature end of input file
Empty input file
Maximum supported image dimension is %u pixels
Missing Huffman code table entry
Huffman code size table overflow
Fractional sampling not implemented yet
Output file write error --- out of disk space?
Input file read error
Didn't expect more than one scan
Write to EMS failed
Read from EMS failed
Empty JPEG image (DNL not supported)
Bogus DQT index %d
Bogus DHT index %d
Bogus DHT counts
Bogus DAC value 0x%x
Bogus DAC index %d
Unsupported color conversion request
Too many color components: %d, max %d
CCIR601 sampling not implemented yet
Suspension not allowed here
Buffer passed to JPEG library is too small
Bogus virtual array access
JPEG parameter struct mismatch: library thinks size is %u, caller expects %u
Improper call to JPEG library in state %d
Invalid scan script at entry %d
Bogus sampling factors
Invalid progressive parameters at scan script entry %d
Invalid progressive parameters Ss=%d Se=%d Ah=%d Al=%d
Unsupported JPEG data precision %d
Invalid memory pool code %d
Sampling factors too large for interleaved scan
Wrong JPEG library version: library is %d, caller expects %d
Bogus marker length
Bogus JPEG colorspace
Bogus input colorspace
IDCT output block size %d not supported
Invalid component ID %d in SOS
Bogus buffer control mode
MAX_ALLOC_CHUNK is wrong, please fix
ALIGN_TYPE is wrong, please fix
Sorry, there are legal restrictions on arithmetic coding
Bogus message code %d
0123456789ABCDEF1.0.5
IHDR
IDAT
IEND
PLTE
gAMA
sRGB
tRNS
PNG
AuthenticAMD
UnknownVendr
need dictionary
IDAT
jHq
kdz
rqg
LhX
Qkkbal
Zjz
i]Wb
knv
owG
kaE
MGiI
wn>Jj
incompatible version
buffer error
insufficient memory
data error
stream error
file error
stream end
ReleaseDC
GetDC
MessageBoxW
USER32.dll
InitializeCriticalSection
LeaveCriticalSection
EnterCriticalSection
WriteConsoleW
CloseHandle
ReadFile
GetFileSizeEx
CreateFileW
CreateThread
GetProcAddress
GetModuleHandleA
GetModuleHandleW
VirtualFree
GetLastError
VirtualAlloc
Sleep
OpenProcess
LoadLibraryW
GetModuleFileNameW
KERNEL32.dll
CoUninitialize
CoSetProxyBlanket
CoCreateInstance
CoInitialize
IIDFromString
ole32.dll
PathFileExistsW
PathRemoveFileSpecW
SHLWAPI.dll
SHGetFolderPathW
SHELL32.dll
OLEAUT32.dll
GetModuleFileNameExW
PSAPI.DLL
wglDeleteContext
wglGetProcAddress
wglMakeCurrent
wglCreateContext
OPENGL32.dll
SetPixelFormat
ChoosePixelFormat
DeleteObject
CreateFontW
GDI32.dll
malloc
memcpy
wcsstr
swscanf
memset
free
??2@YAPAXI@Z
_itow_s
_wsplitpath_s
_local_unwind4
MSVCR90.dll
??3@YAXPAX@Z
_encode_pointer
_malloc_crt
_encoded_null
_decode_pointer
_initterm
_initterm_e
_amsg_exit
_adjust_fdiv
__CppXcptFilter
_except_handler4_common
_crt_debugger_hook
?terminate@@YAXXZ
?_type_info_dtor_internal_method@type_info@@QAEXXZ
__clean_type_info_names_internal
_unlock
__dllonexit
_lock
_onexit
XINPUT1_3.dll
RegCloseKey
RegQueryValueExA
RegOpenKeyA
ADVAPI32.dll
DrawTextA
DrawTextW
HeapReAlloc
HeapAlloc
SetThreadContext
GetThreadContext
Thread32Next
GetCurrentThreadId
GetCurrentProcessId
Thread32First
CreateToolhelp32Snapshot
SuspendThread
OpenThread
HeapFree
ResumeThread
FlushInstructionCache
GetCurrentProcess
VirtualProtect
HeapCreate
HeapDestroy
VirtualQuery
InterlockedExchange
InterlockedCompareExchange
TerminateProcess
UnhandledExceptionFilter
SetUnhandledExceptionFilter
IsDebuggerPresent
QueryPerformanceCounter
GetTickCount
GetSystemTimeAsFileTime
WideCharToMultiByte
GetVersionExA
GetProcessHeap
LoadLibraryA
IsProcessorFeaturePresent
GetObjectA
CreateFontIndirectA
DeleteDC
SelectObject
SetTextColor
SetBkColor
SetBkMode
CreateDIBSection
CreateCompatibleDC
_snprintf
__CxxFrameHandler
_vsnprintf
atoi
isdigit
isalpha
isalnum
isspace
sscanf
_strdup
setlocale
_ftol
floor
_CIacos
_finite
peixoto.dll
CreatePixelShader8Hook
CreatePixelShader9Hook
CreateTexture8Hook
CreateTexture9Hook
CreateVertexBuffer8Hook
DeletePixelShader8Hook
DrawPrimitive8Hook
DrawPrimitiveUp8Hook
GetSurfaceLevel8Hook
GetSurfaceLevel9Hook
IsXInputDevice
LoadBinary
Lock4Hook
LockManagedSurface8RectHook
LockManagedSurface8RectHookCheck
LockManagedSurface9RectHook
LockTexture8RectHookCheck
LockTexture9RectHook
ManagerBltFast
ManagerLock4
ManagerUnLock4
OniReleaseTexture8Hook
OniSetTexture8Hook
ReleasePixelShader9Hook
ReleaseSurface8Hook
ReleaseSurface9Hook
ReleaseTexture8Hook
ReleaseTexture9Hook
SetPixelShader8Hook
SetPixelShader9Hook
SetPixelShader9HookD
SetRenderState2Hook
SetRenderState2HookB
SetStreamSource8Hook
SetTexture3Hook
SetTexture3HookB
SetTexture7Hook
SetTexture7HookB
SetTexture8Hook
SetTexture9Hook
SetVertexShader8Hook
UnLock4Hook
UnLockManagedSurface8RectHook
UnLockManagedSurface9RectHook
UnLockTexture9RectHook
UpdateTexture9Hook
CEPlugin_DisablePlugin
CEPlugin_GetCEFuncs
CEPlugin_GetVersion
CEPlugin_InitializePlugin
ChangeGl24BitTextureIndianes
CreateEffectHook
Critical
DrawIndexedPrimitive3Hook
DrawIndexedPrimitive3VBHook
DrawPrimitive2Hook
DrawPrimitive3Hook
DrawPrimitive3VBHook
DrawPrimitive7Hook
DrawPrimitive7VBHook
FindDXTnTextureInCollection
FindTextureInCollection
GetSurfaceID
GetTexture2ID
IDirect3DDevice2_DrawRect
IDirect3DDevice3_Clear
IDirect3DDevice3_DrawRect
InitHDHooks2
InitHDHooks3
InitHDHooks7
InitHDHooks8
InitManagerHooks
InitShaderOverride8
InitShaderOverride9
InitTextSwapLib
InitTextSwapLib8
InitTextSwapLib9
InitTextSwapLibGl
LoadData2Surface
LockSurface4Hook
OpenGLInit
Pal2RGB
PointerCollectionCreate
ReleaseAllHooks
ScaleVertices
SetDDSurfacePixelFormat
Surface4BltFastHook
Surface4BltHook
TransformVertices3Hook
UnLockSurface4Hook
copyData2Surface
d3D8AssemblePixelShader
d3D8CreateFont
d3D8CreatePixelShader
d3D8DeleteFont
d3D8DrawRect
d3D8GetmaxPrimitiveCount
d3D8LoadSurfaceFromSurface
d3D8Write
d3D9_DDI_BltHook
d3D9_DDI_Init
d3D9_DDI_SetPixelshaderHook
glBindTexture_Hook
glTexParameteri_Hook
sethook
sigscan
surfaceCopy
unhook
.?AVPOINTER_DICTIONARY@@
.?AVConstantForce@@
.?AUIDirectInputEffect@@
.?AUIUnknown@@
YYYYY
YYYYYYYYYYYY
}YPPPPYYYYa
``YYYYYYYYYYY
PPPP
JJJJKRJJJJOLJJJJJJJJUE@JJJEYMFJ]JJJJJJJJJJJJJJacgNJJkmJJEmJJDEJJ
DPv
.?AVtype_info@@
UYVYYUY2DXT1DXT2DXT3DXT4DXT5F
UYVY
UYVY
YUY2
YUY2
DXT1
DXT1
DXT2
DXT2
DXT3
DXT3
DXT4
DXT4
DXT5
DXT5
Jj?,L
CEu
EKB
4h!"4h!"4h!"4h!"4
L>tU
VS_VERSION_INFO
StringFileInfo
CompanyName
peixoto dll
FileDescription
Peixoto's helper routines
FileVersion
InternalName
peixoto dll
LegalCopyright
Copyright 2014 Daniel Lobo
OriginalFilename
peixoto.dll
ProductName
peixoto
ProductVersion
VarFileInfo
Translation
=h!"4h!"4h!"4h!"4
<security>
</security>
</trustInfo>
<dependency>
<dependentAssembly>
<assemblyIdentity type="win32" name="Microsoft.VC90.CRT" version="9.0.21022.8" processorArchitecture="x86" publicKeyToken="1fc8b3b9a1e18e3b"></assemblyIdentity>
</dependentAssembly>
</dependency>
</assembly>PAPADDINGXXPADDINGPADDINGXXPADDINGPADDINGXXPADDING
0F0N0U0i0
1D1J1O1V1
1I2S2]2h2
1Y2u2z2
616C6W6y6
9-9T9d9n9z9
:N;T;];o;y;
>.>E>e>z>
7A7b7o7w7
9P:f:r:
8%818?8P8d8j8o8
:B:G:S:Z:f:o:w:
;-;:;S;a;q;
>1>D>a>f>o>w>~>
151F1L1Z1
2%2.262?2O2j2w2|2
4#4.464E4K4a4
5/5:5B5i5z5
7 7)7.7A7G7b7h7m7
9#9.969?9J9R9e9w9}9
;-;8;I;Z;e;m;
;&;2;>;a;p;w;
<"<+<:<B<S<]<b<
80969L9Y9z9
1.242J2S2Z2_2u2
3 3%3+3F3K3W3g3m3t3
434D4O4W4
6&6,62686>6D6K6R6Y6`6g6n6u6}6
808;8S8i8v8
9P:V:\:b:i:
;";F;N;Z;`;f;l;r;x;~;
6S8d8U<h<z<
8/8D8b8x8
6A8I8w8
1!1%1)1f1l1r1v1|1
2"2(242F2g2v2{2
4'4@4K4T4Y4f4n4y4
5%585>5Q5U5Y5]5a5e5i5m5q5u5y5}5
7D7*8B9O9e9u9
;!;4;<;B;S;Z;c;
8%8)8/838:8K8P8X8\8a8f8
3C4Z4k4
9K:Q:y:
4v5&6A6\6x6
5#5,5;5D5O5W5l5
6E7P7V7
<!<+<A<K<a<k<&=B=z=
>%>@>O>U>p>
081>1Y1e1k1
3p:t:x:|:
;$<<<D<S<g<
2+2_2p2&3M3e3m3|3
4!4'4J4A5N5[5
0,1F1d1o1
3+313F3L3a3g3v3
;#<I=O=g=z=
9E:X:g:v:
<(<k<7===D=K=R=\=f=m=w=
>#>*>1>G>M>T>[>b>l>v>}>
?"?)?0?7?>?E?Z?f?
C0J0Q0X0_0f0m0t0{0
1)131=1G1Q1[1e1o1y1
8#8*858A8F8M8
8d9r9z9
273F3n3y3
9I9Q9i9
0e1l1y1
3G3O3Y3`3g3q3
4F4N4[4b4i4p4w4~4
6C6J6Q6
7C7J7Q7[7r7
8C8J8Q8[8r8
8C9M9W9d9u9
:H:c:m:w:
=)=A=H=Q=j=u=
=I>a>h>q>
1>1I1T1g1
3 3&3,32383>3D3J3r3x3
6 6$6(6,6064686<6@6D6H6L6P6X6\6
= =$=(=,=0=4=8=<=@=D=H=L=P=T=X=\=`=
3 4$4(4,4044484<4@4D4H4L4P4T4X4\4`4d4h4l4
5 5$5(5,5054585<5@5D5H5L5P5T5X5\5`5d5h5l5p5t5x5|5
6(7,7074787<7@7D7H7L7P7T7X7\7`7d7h7l7p7t7x7|7
8 8$8(8,8084888<8@8D8H8L8P8T8X8\8`8d8h8l8p8t8x8|8
,;0;@;D;L;d;t;x;
<$<4<8<@<X<h<l<|<
>$>(>0>8>@>H>P>X>`>h>t>
?$?<?D?P?h?p?x?
1 1(10181@1H1P1X1`1h1p1x1
1 1$1(1,1014181<1@1D1H1L1P1T1X1\1`1d1h1l1p1t1x1|1
2 2$2(2,2024282<2@2D2H2L2P2T2X2\2`2d2h2l2p2t2x2|2
I used Proces explorer app
Reply 95 of 896, by Peixoto
RaZziel94 wrote:
Soo is it this ? DDraw.dll Image: […]
.MPRESS1
.MPRESS2
.rsrc
Wjvp
TTDq
(RuS
DzpX
QgNz
yK;R
6fFaG
WTvj
7H>tl
hJI
)O,Z'y
PvNZX
0QHs
hou
-upt*
V6}NG5!
oPI
nWS
btG
S|Hus)
lFz
Tni<
SI(?Q
aMeD
xdFC
RtpP
Arg^Oj
QpI
M%GP
CcO
Df<M
U&hf
maq
dzD
gch
ICb
ml7a!;
%UuA
*OuS|-
L?aX(
iAy
QKh
sRZ
mmD0
v~Lb
qYI8
XIEym
1o(6Zj
sytvO
'UQ#T
HPj u
|^sD!!G
+EvP'-
D5CI
cY[j
j-Vq
0ydQ
\o#uo4
Te*Pm
Rzw
RQr
keT5
Mj{qK
QaIn
yPp
I0#qR4
YYs
"PLS
kxb
rLNG
xcl
Ykt8
x%Q;O7
YcW
fqN
sVHQXAm
mZ}f
swW
m=U0W
adLw
L5pD
b6AV
cu-Ea
nW[mR9
AJR
kIG
GIX
CL'za
lMa
9(*L'Wl
sF~-}W%
Dhh
g9J/oq
QmD
x-J'o
7dL&i
BD^fV
sqr
c)tW'`
Q`jU
x)OqD
=dKW
wbm
Mb/I;
FSGG
X!vW
GGE,U
S;zFm
Bwl
|!dDr
+Sa~ns
'TGB+g'
oww
vNtU
g^M{MY
LJXRt/|
enT
gT^_}wZ
XgJ
I=DF
uPZ
~L:HX
=IWDa
hwo
eZP
xHo
U<>OE
n[UA
Z<_Q6S
xTS
es+8R
DCS
Imu
WH9o
}N!U#=ia
60XiH
oK&U
xRd
yeG,D
!Nim
toO
p6mA
CmX
jjT.
q)hI
qIl\Smxmxi0
nkv2
kkk
l q\5M
GTp
qeuI
fqi<
m}{bF
yBP
ZqV
PkO
FaA@
Dvb
PNg
BZL
l (lL
EO;a,
jCZ
cz8U
U&TwM
EXa
2OhRI
P?YAB[-
Hto~
"/PbpQ
JTR
OSQc
sb<I
bwn0
tpL
jZxH
bWj
yxm=
g hi
WbS
QWv
oTW*
HHg
CzW
RT8w
Wco=X
oHs
OHB
BLa
hkJ
7Yq3e.4_
7Z5XO
ZnD
uWF`L
H|nn-
Dqv
sBO
KDa
>.TnW
nKG
fHFD
jt\~S
q[MB
Sszf
cfI
?5)TbS
lVa9FcG
yxgT
'mKW
u%oU4
gNY
aDV
TpF
t:Wcm
HfI
\wPY
IaEl
ptH
HLR
vrA
NMU
jNWj
a`HdO:Alp
u#Jr*U
jFTJ]
NZT
N6cG
Z7LWr
|pAA[
A3yFe
emD
HN"u;
Pcsf
Luo
DOLL$]
aFd
"tR8m2
fPa[>
j{JV
-]sMuP
@n`ZAq
lF9<o
YwS
zPwl|
Rs9kc
k-6ZAq
vEM
DVr_
dvJ*U
jax
?4ZKMHJ
VBt
OC'a5
dDM
d6ox
i'c-~*K
EiN
A1Gy]
nC`DY
jrC
izfm8z
z7cW
QI;I
K0qa
mXP
uzT.
a7X@x
I[WUY
Qzj)
3Wjw
kLk)
W0Rg
o*mWO-
4cUx'.
ZIR
hyQH
HlC
ndZ`N&
FiO
_-TtO
btN
KNK
6BFm
UKB
IdG<
MV5RlJ
bc)d
pUlI;
w}yt
s!5xy
bkkjE
Ykl
ty"g
DYL
zvL
Lvt
28zSK
qbz
jP~c#
LUR
Mgy
P^5UY
QX0A
MyL
tk[,WT~
Rf*^H
Gf.;D
qkc
7"UhX
wKE
ycm
RFcM~
b6Ut
VRV
g,Yq
Xtb0HHz0
Sdv
]ZkB
IFw
2uGb
FpI
AtgQ
T5Gi9$
ZGr
,RAt^
D0QE"d~
3^mbxK
xqe
Re6z
QXX
QUM
*aAY
SV:QF
Oqr=q
"XYI
L]Nl
wgV-
Wu4,W
F/Hg*
tkW
ULCVF-
`D3V#K
xoD
(&7XjK
jfg
LZ7T
Ady
.UH=HdHhI
00lbIA
'aWC
Mdz
=yHXs
EyF
c|~/Ft
\%Wid
Pe=N
/DDc
PQV
Wpt}
_x f#6*RF3
.elQ_
eRG
KQf
&R Bf
Q~cO
Paj
.BOS
QsQ
RR-iz>
t5jD
H;joP
RO>T
`NP8V(A
Y9eW6'
oFKN
G)B_e
i]Gs
Y{_>:o?~T
OGd
uAd
Gub2D
KZPi
JW'7x
Ua9v
O|9^&wA
IUni,
cPk
cbC1#f
baj@
JCJp
uTi
!1D&uL
ySF
HUy
6trL,
f&Eb
gGb
PTw
S$dt
eBx
XI77H
Hzf
dek
K)q j,
ufOL
AYj
NogP
$SHi
bbjq_
L\CWX~
hDw
hlt~
cC^au
He~BO
#Ae(xu
K1pnkQv
kRy
dGc0
riE
pjz
cac
w;QB
UIw
KHz0
IDa
eUp
KVR
cG<B
KeY
^Jvt8
ZQIR4j
fhx
eox?/
,cnDw
fQt
~D9Gi+
uO#O
vnb
YqM
,rco6
NQt;'
ntY
LZy1
yhb
QwEeXRj[
#VeZC,
EER
bYJzL<
T74yV
eeu
wpq
hWa^
J"H}_r
EfB
KXE
n]yJ
[alWm!O+
rAO-D
xBo
WsD3R-
oLWE;d
lGW?
ES?w
4Oo\g
+zXn
MEhk
0}*>itt
Bzn/
M|y3Z71HS
XnQ
qwJD
Qo%d
lQm
uni
UfCP
Q!jz
U)ZZ
b@nO
vXe?-Z`C
t7vWr?
wew
dqR
k!r}6C
/hGS
+ptS
CpoO&a
lCi0{W
HWcP:
M.ID
Vj]G
GMHzmL
dWD
uoKR
xd70nK
rf-w
EbZ\
poH;
Bba5f
Wsw`
vC{W
wOX
kzSe
k7XL`
4(lAi
LrrR
zsp
IK>N"
JSu
IUX
/1n,lE
Lsu
bYOS
_JP$HV
Z(geHLo
YXq;
QI(R
sRz,
@Tr'P?
uAj
RY}8V
OJu
Mt:PR\
iSJ
lRR=
/&muFW
cvOr
Xy#*C
1XsW
Kb;G
DK2k
GGJ
QL"v5
c[sL!
JREwC
IeyzK
EyiQ&
GWg
h7vZ
pNrSh
AlZS
BZXy! 6"
yDO
kHG
f{l9"G
rrWs
*ZZv
FpJw
eEv
Jtj
LDV
'OHE
tRO
UVB
%qaozO
)YCeX
Pra
IpX
l^w$Q
AoaJ3
XG2D
oTn$z
wqH7X@%
Wvn
coB
pwgsq
_quJ
NGQN;
!x$:Mm
yHZZ
A-zNN
/zQZ
QjE
qlg
hr&\rhv
BJ/z
x+'%B*Z
iNS
sVT
k(yr
MV{A4k
5BHUm
Jc`V#1e
dnX
Jj%e
~A*9hY
o@Jf
AM3n5
tSn
URi
O2P=YE
MKU
JrZDN
RXG
WuI}V8k
OyP
FWNs
nhY
LSa
ncr
^TQ[i
B3rN
!8jVS
AC[Up#P
ULg
Y7sD{
Mcf
RT_CUSTOM
VS_VERSION_INFO
StringFileInfo
CompanyName
FileDescription
FileVersion
InternalName
DDraw.dll
LegalCopyright
OriginalFilename
DDraw.dll
ProductName
dgVoodoo
ProductVersion
VarFileInfo
Translation
qa&h\
Yuk]
U%Qx
BvH
]FSacF#b
b>Ae-
^jfMq
-wGmm-
tef
nXW
ZmD
YZMc
cX8&v
PJZ
tKF9
lj-.X
QCdL6
Y<Ly
GvY?
fzp(tj
Rv[~%'G.
Jx78!T_
uAv^
>FQG>'
DAC4u
Fnk
ofo^
Ner
K.l6q
jAd
hAES
hNq
F(VQka
ysM
bkF
obK
5xiF
"rsH
YrA;
LK=m
u"Ab:
wBR
8OjD@
Z<kBPa0B
PAR<
"}UyC
zjP3
8~3fnX6
U+BdGr
Uzc
bAn
/-R#L1Q
^ks,n"Gx
Di%m
`ABiNi
rqQ
2wiW
ph+ii
93Goz%4&
CZv
wufN
Mrm
VU2I
kpVYp
XGnJJ
xDn"
dbr\
pI\h
uX=m;?
uzU
Oqp
Lg.v
CA[O
Gvp
qDJ
gwD
Ogf
CEK
jBN
abI
JZtU
gXM
LF)X
pSf
nsj
Xtw)U
olC
L.Qk
oQi
+G5A/8h&
IIV
BxX
=zv4&Cx
ZEk
)NUh
HhU
ip,D
UwR
"$#4s4Z0xu
l5t^)'[e
oSn.
ycwq
8o+mm
fVE
Rnr
3GBp
GFwWA
hNu59C
n-fr
KQbi6
Cyps
GXn
A'[J-1A
J[1j7O
P+*xU
eLi
R?jL
R":VQ
U6Jy
n*JK
qwQ
%DvU
OVt-z
DAi'i
Mhs
IEpb
MFY
vcR
xtT6
cy>Y
"`pyn
1Ujc
WGI
DxM
nzm
YPXw[rLR
Jfl
QmG
qEI
Tao
2PxW
B:fW
kZX=h)
GFT
m{MG
Xf.j
zT#'w|+&$
nBh
wIQ
K?fJ|
1zzG
T_6VN79
H^O*iAJ\>
D_k?x
wvD
RAZ|
xML
elYEK
BeT3~
=Xco
lMQ
@qlYJ
Tml
IwX
CbC
|JCI6
D*jbtB
pcw
e(ie
}GmV
1sDvp@]I
XPWz"T#
zXD
+hca
XZrb
MlS
.EHl
c}yb3
\pQi
hP%Td
S0DQ@
qHdw;
Ra*kA
GLM
ypgM
Nyv
CHq
XRB$
3ysh
vshU
n9L*RI
9JXc\
xbU
K<YZ52
/wHS
itu_
tZ(e7
HtiHt
Htr
T$xR
DDraw.dll
AcquireDDThreadLock
DDInternalLock
DDInternalUnlock
DirectDrawCreate
DirectDrawCreateEx
DllCanUnloadNow
DllGetClassObject
ReleaseDDThreadLock
GetModuleHandleA
GetProcAddress
KERNEL32.DLL
SHLWAPI.dll
PathAppendW
USER32.dll
GetDC
GDI32.dll
BitBlt
SHELL32.dll
SHGetFolderPathW
ole32.dll
CoTaskMemFree
WQI
UWVS
9L$ts
D$xf
t$t#t$l
D$Hf
T$sf
D$t#D$h
D$t+D$\
D$Hf
D$Hf
L$xf
D$t+D$\
T$Df
t$Hf
D$Hf
D$Hf
D$Hf
t$\tZ
D$tIt
9l$tr
<security>
</security>
</trustInfo>
</assembly>
.MPRESS2
.rsrc
nt\Q{T
hCl
FxM
"Zli=
mSe
quE
wWO
xGfr
OKR@
YEgR
O8Rp
pDK
lgU*:}
TUr>
oXyj
w5rQ'
wrg
}mFl
Qj~I
&HFtz
cyH
UfD
DfQ
wYO`
sil
-vBv
Pd6s
xohnEH
SpyE6
Ch4 M>
T6fw(
Y+E4zj
ffJ>y
xyCG5
U*Qvh^
uuw
G@(PZ
1RrQ
GAN
g4!Hs
jCi
tbnN
gQk
lELB"x
Jxf
jrr
fNK0
tr&j.
Y"4V[{Cyxa
Gwm7
LZM
mVZA
rfV
jul
cpg
Ihr
\ARp
XhS2
pp4a9
S@OO
CzGZ
Sn.S
tPj
eKZ
f!CU
Y[q]:O
hf'X
UVr
kTh
5s%yb
qRL
+lst
M:t"s
F>H%I
WAEAPn
gqq
y~Rp
ujEl
.HYOT
_k8)Cf[
s5>`;up
RRv-u
<lq|ed
DAw
(Ui!b
YMHC^
^fVa
qK)S
Kue
bQO0
fuW
x v7r
N3Bv
e%Zz
3mwd
gM+xr
phP
zXZ/
ZIXF&
*FAa
%HRm
QmE
GC0B
bzP
H3IA
gjpm
Rnw
fSb
igD
XQ~b
f5ics
EKzz
HTPx
0RZR
yGi
Ouo
KP2J^
HGg
fbT
JHi
KdVF
aUlVi
YBHBn^!
lCr
nCR
KCp
FW&_k"P
U`Tu
r~Drn
I1jT
Bey
sBYs
Dnn3
jwR
UOQ
t&11YQ
zPr^
bNe7
qyc
LP.kq
?!xPl
GbN
qPN
n3TT
Q10Jm
xWC
RAt"W
g3FyW
iAfrc
H*B\m
hJT
OfV
gIl
oQ(oiF
IYF
vux
Bdu
0wV0x
hoO
xvW
x;Rc
PZq
GvR
fcj
o5wH
GqiM
dJu8
gK(lJ
n|Zd
!c-Mh
c\Uj
VEO
cUbAz
K$DU
iTav
QrT
&koD
I$8Mj
ZDQ"
F;Op
lWtu
biM
EQB
gBL/
iI$r2|
$N?.%dV
fbd
zWy5G9
Bcz
lsI
gRy'
/:wXC
iNO
Cfs
qhvZ
bCJ3fEos
zIS
uM9MR~
VrE
lrU
Pns
D%ZY
XX-Ax
rEH
LSm,O
oN@y
yJv
ius'
'?fl||M
Z\1$vj`
5N|}_;JHB
$OUi
H$*uW
CmxS
lGG
ywc
tgl
haO
L+FuX
Shz
WNJ
oGS
PzK
Q^FB
v<Skq
peu'Cb
QXrs
BaeS
'XMN
Y4Tg
BSj*-m7
yLr~
wlH
cL~pt
myw
cxt'A
GdT1
,r#IO
(w$jh0
bKXP
TlK
CdS
duo
YnV 8B4r-w9
YqM8
PkOF
qqS>
HYs
Tnx
gv'Y
_XkZ
qu+q
pjM
PLH
]kfd
Q#B:%ol
Xa2Z
9KPEU]
JEW
+UZX
RjD
\5\nqR
*^tkh
AMb,-
uf(d
>l.aN
ryp
tDp
o8Ei
Z Dy
zh><E
C*MV
fFC!a8
VQq
JJs4
X5UA
QXIGf
ZLB
QER
Ccb
uQxM
:Riy
llf
gCB
ldA
tEc
Mc'c
wh|S
ihH3
klN
TmY
HNd
1D{YjO
MFq
BIP
QX>H
vWx
=Jx!b?_&
\Fvf
]Ogq
c{Db
u=jI
Ycl
avqI
N'LL
k:hF
dxhka
i!CW.
tke
Z}Tv
mh(aW
uU?x
cPW7
8uln?
sBg
wIh
yCW
STq
JLq
zrz^
mTB
kxZ,
tR>g
qEu
&slh
SSz3
zEO
b&xmm
oI|AC'd
lXF
afdj+~
scW
O.EA
ZR;w
jtsr
QGl
-tCn
Exf
o9JY,!q
MWy
orp5
Sgk=?W
Wtg
wGH
pb_v X
cvH
9ruea
Bsaf
vC7YK
PYN
zzw
dJ,y9
PICmri
M1Sh
1zau?}
nOe&
>apu
Aj`i
oYk$
4TfO
WbKJ
BK]T
tVo
czS
RYN
ptxu
lgK
v!EofF
XlY
aWhY
RNew(
,pBIn
pAZU
vDB
ZZw=
{&PWRZ
DqF
MgO
XsG
VC5S
nJU>J4s5
NFG{UZ
PXb
PO$Y
`=L(#dr
kUGu
y&LR^
0^hbp6
TVX
ldK
7DCI
o@wz
rit
^8TiD0R
UIK
/kdDc
EgP.x
RzE;
:nZh3
NwIVV
La}D
SZp
Yfr
v{{[%vvny
Hbb
gC-(Y
7Q+gN
IC{o
QgO
SZa$
evR
of~{j
iQc
Vy1_F
hx!iX
oB{N
Gtw
4Pnpn
jiKl
ymc
bVx<Q
@GHA
oQq
c%i5W
KZ"J7f
Ou_U
ECd
dLt
JyhW
EgW;
LCC
Xfu
Nkg
z]nre
bAH9
phy
`oGMPEL
uYq
<Irg&!#
TAl
DVak@
mZ,yR
IEs
SRJ
RUo
QrF
jNRx[
kyK
IY; `iO
d/Ic
GPk\
pvfpM
NQO
FVNe
Pu(L
fhN6~Z
9{bb<?,wh
nJw$C
zyw5
ENn
PUj
T~Ut
qfK
jAf
TfP
]W4oT
hWyj
Iw,.Oo
PrX
Tml8$
sR W
kvW
E6U>f
V'KZ
jom
QB3t
ulG,
"jR4q
~hSb
zGoR
`ue}0D|
Upk
vhOAg-
DQ<J
Y)gO
bQp
GXW
LXI/
viM=D^A(
"1pJv
ZJQ
lZJ
%djB
OrpT?
V+TKJ
lC5u=
Pvc
Z Fa
^AY*<W
jbP
see
vs&q
z2RXm!
yZh
ihj
nhl
itL
"5F%s;w
JfW
bsM
_V'oNxE
+ejy
GAl
h~Gj{G
xMB
v@yQ
brSZ
CZt
tXK
v>ym>B
pmf
g5EEE2
thB/H
Bigh
EcM
eb1ikCq
h7UT
zug
7pUL
yC_P
PYM
ROk
E#KJ
sKsPqO4
inW
slQs
("AZg?
Ec|Z
ZI{l
b7*Sq
lGV
oU=aA
nNZ
dvq
k.pTf
CGM
I)tJGD~
}TpO?
j#A:De
nCZ|l
3Vrd-
rYN?
LCg
>gUn#
FTd
aat
FDM
eyO)s
r0SX
qoe
Z_kuj'
HLX
jYU8y
GPx
k47sO'
MrK
HbF
KmB[~
FGO
NYH
+uVp
Hwb
dee`
jKsY
fgU
KeFC|
rg_g
kIc
wC0l
Svg&
mWF(J
Xns$
jky'
2Gep
LF;TH8b
Abq
v/ZSd
OMP
xyM+
PAc
S/NE
5Or?C
MKd
lwN
oKr@"2
cVv
!uRg
PNwT
5n-Zrfy
C(dQ
pYh
cAYJ
#i-XJc
DV:P
jz@d
t9h-m
yuhHWo
-6CFq
Uy0b
;cY-i
INy
kze
jOTk
(XHbV
!glq
xwr
mCE=
w/WB
cWep
UTi
~VgW
VVE
l|o^c
U)Fu
4gIu
wgn#
6suQ
kxQ
2D@ppM
<zj$_g
*M;oy
NtF
bjH
BxMeO
=]hOY
DIA
~UsPL
qkY
knhv*
faT
XiaC
MVN
)c@SQ
+dp)4nVg
XCL.n
'X_SF}
NMg
g%YH
^jkx:$
dFn
YyI
BxD
,EpM
7?bjT
GaO
Lxk
H?7sOT
vn+~y
J}8T4>T
kFz
TlN
Xjt
vuIi
LyP
Oig
nf{l
LPW$
kaW
e?Cf
HJL
H1Yi
Ltb
tmr
rOB
Il3A
o>JH
Bcw}`h
$H&[Ts
#MMo
gDt
VZ6i
Ha{q
oTgZ
xfzt
3VSR\D
Xw0NS
Mpa
idN}
mDf!
Alq
)y}FT.Z
BO?Ej
Nau
Idl
yhi~
ov8e
HIS
Hfl
iwi!
S%Cu
f$Oh
Ji7O
dJ=W
Ke,c
JHN
ZP5L2
"I8(As
gpY
xGV
I`YE
vzr
?ek:h2N
.jLsE*
%dLc
ppY
K8sbz!
WdS
yH]2P
J*wR
vOc
omb
fN4j
Uiqz
iwQ
N7 Hu
Q7TuV
OXs
H-fKP
qeK
o$Y`R
IeLH
OS-x
Qiv
*sYFII
VDt
#apC^
Enl
OAWU%s\m
jBKC
w{#Oo(
:vMN:J
exQ
;XY47(e^
HGK
LC$V
%fSz
ff3iV
Z\qc
c{oeL
aNJM
qCSRO
rTM~
0caO
psK
eBz
N[W5c
oo=QH[,a
GVOu.
QBXV
aFO
fT: &r
"k>#bTc
BQ8U
bFd
iFi
GfL
csic
ZL'K
F)Hj
Wmx)
xSM
MRD
fKr
VEg
sQ T
Cn[e
fzK
jqT
CJD
CmAO
pvk
VG>Cd
m:djt
rra
Bo2N`
b uD
ItRY
ePY
B?Cu
edFHs1
PkN
R3Vx
PmQ
Cpo
AN2H
dAK&
NczM
S8tdP@
qmD
DWZ
~oZTfcG
8lOV
pap
3adc
Been
|dx-k
ANF
%PiX
yqg
"Z0Hw
SUlk@
NFM
WEH
g9kT
BgPZ(
qcU
afP
dkk
UKH
GD`&~Dw
WP[l;
wPKuq
%r7w:t
YsR
wDc
c1Qz
%,&TnM
GTs
xgQ
bej(r{`
blR
HEE
2URf
bM-!uH/
TJW
&yry
ihrV
WqJ[3
LoL
Ei,N
sQ++-#G
tI]T%{
Ry}J
0ka.y
BnQ
wbZ
LrZ
VVG
aC[by
1kRj(
LRy
1tnb
wxg
PPu
yoo
QJj
SDp
"wj<z:I
qJd|
vWlA
9GLY;
Wh6T
FF^C
NhZ
ZPe
Q6ll
DeC
WMr%
W/OB
N2th3
qhR
tGs
+jb7r
@SgE
k7WB/
crH
aUS
ZpQf
Z>yp
Ff(ht
ZFq
Att
cxD
5nBF
{9iLRbp
ngkd
'iqKV
Dlv
uITg5
lYw
gIZc'
(TJ{p
~bHZ
fk[J
nju0
g~qDv;
gMH'
kyi
fqL
cho
XbMW
BlF
kjGd
XEu
Kt&T
q}aH
TtI_V
OCsL
QGh
c`u6T[
CIv
hPL
Tadab
Zy?Q6q
xsh}
MnO
|ZTM
j8v_X
E76/d[zM
QYMye
@ab}b
jp8d
FDs
Q?"yq
hKZ
oJj
EA>iZ
y4/dM(
^N7Ik
IYW
kkv
!A[zK
nXO
tLM}
FDMC"\I
Cm=M
Z.AQE:
~DLd
BZ/["G
Rzqx
lVB
tUf
mwG
D^pV
GrX
jpZ
UvO>
REZ
ufTC<m]
`MIr
$hVB
M_XX
NCV
)Zz`d
wsm
HDN
wuc
tTR
2.fu1C
ACg#
sBL
&lxuW
Gb;W
FZGM
Fv\Y
$PDtF)u
QwVI
MWY
SiI#
[b(WK0
W&i6Xj`eJ
ovF
DrnX
yf=d
(T7Eif
wRz
Hfq\
olh
:&okn
RwW|l(
i%^XSY
PrJ
S,|YKR
vtxM
KCg
dDIV
&jg-$|d
]M)LB]*
LL*lU
qln
Emo
BZB
7jw}j
Mk=i
5OSS
mwE
eRb]
rB<zU|]
WUm
hxL
%"etM
,WaU
kgC
aQn=_=X
N\r*h^
GVc
vpv
yca
G5yI\
WUR
qlV
rWEx$R
kZv
=n@dRW
c-BtP
xpgKT
zx+(AS
CW*Z
N<sU
iLU~a
aun
t4N"r
PBP
zUw
FMV\H
oWQ
jThS
XkT
{boA
kby
ils
V=Xk
v6^w_D
lMQ
iRn
nUw
SAj
Y1FUi
zgoXVm
xml;
Ts{i
DtC
HOK
j;DM
srX
CqE
Nem
0\Z\By
LQyd
,<R}kc
K=&de
xE8h
pnSj
#gNtR
VtT
Ro*j
YRe
,xEAw
HbK
kB+c?RWA
QJyD
VDv
BdH
fpKm
hWA
tr-Z
FWiP
#fm"L
vHQ
uAR
C[XL:{VH2
bZW
WiG
NcN
tUFm
$Tgu
vsX&
-_B)Yv
.$C(bNi*
ErD
kHu
vUo
HmTM
VnF
tyZ4
JzOY
uCJ
r?Ns6
Vm*PM?
y.A7%R
rOa`
,lFg
&neI
JuK
=CIe
DHFn
DvF
pG*bv
PUY
-IiH
ap<W
tqM
Uce
uAwu
gDc
o,Lg +
b5mC7
eoN
tZd'
dv2V
Zoe{]92
(kTU
+(ku P8f
alzg
rdeqV
QcK/
ZNhE
TX`L
RT_CUSTOM
VS_VERSION_INFO
StringFileInfo
CompanyName
FileDescription
FileVersion
InternalName
D3D8.dll
LegalCopyright
OriginalFilename
D3D8.dll
ProductName
dgVoodoo
ProductVersion
VarFileInfo
Translation
M4EIUij
QZ$=u
iTz$p
afVd
x|Gc
gdWP
PmK3
NSv
xb/Z
zZKu
Saf
UUSj
aJx
_EUx
LU\I
*nNee
~IHI
2QtH
|QGpL
gJ<zL2"~
iLn
IH![-wXPZakVM
iq)t
hEK
Qw`nJ
3$CtQ
h|kx&
mmu
jnp
w X@tr
<fTg'
KAF
jG;R
Rdf6
`cp<A
rtQM
mKK
w'r,WGFr
APS.
Cgd
fbt
sNj
XRP,EC
B]"J2a
enY
FzS
akMS
wMF
mMV=
KlM&
zmc{
U^jw
isQ
Lv~:J
chG
~W&mb
Uco
eby
)JU|J
VPS
D3D8.dll
DebugSetMute
Direct3DCreate8
ValidatePixelShader
GetModuleHandleA
GetProcAddress
KERNEL32.DLL
SHLWAPI.dll
PathAppendW
USER32.dll
GetDC
GDI32.dll
BitBlt
SHELL32.dll
SHGetFolderPathW
ole32.dll
CoTaskMemFree
WQI
UWVS
9L$ts
D$xf
t$t#t$l
D$Hf
T$sf
D$t#D$h
D$t+D$\
D$Hf
D$Hf
L$xf
D$t+D$\
T$Df
t$Hf
D$Hf
D$Hf
D$Hf
t$\tZ
D$tIt
9l$tr
<security>
</security>
</trustInfo>
</assembly>
Peixoto.Dll Image:
jjj
jjj
jjj
jjj
@@Rich{
.text
`.rdata
@.data
.data1
.rsrc
@.reloc
VWj
PQVW
QVWh
VWj
D$HSP
Qhxs
hhs
UhHs
Wh(s
QSSSSSSUP
SSj
SSj
RSSWP
T$LRj
T$4SRP
T$$Rh
L$,Qh
T$LRj
QSUV
QSUV
SUW
SUV
L$ SU3
D$ ;D$0r
SUV
D$$VUPWS
T$$QVURWS
L$ ;L$0r
SUV
L$ SU3
D$ ;D$0r
uV9n
D$$VRP
L$$RVPQ
D$(;D$,r
D$$PSVQ
SVW
SVW
SVW
QDP
HLj
HLj
VSW
UVWSP
VRS
uL9D$
tBj
jXP
VWP
FTQ
PQR
VRP
VWSP
SVW
WVP
t(9p8u#
DSUVW
T$,RPV
T$XVR
D$\PV
L$XVQ
htt
hHt
Vhxu
u$Phtu
hDu
htu
htu
htu
htu
SVWPQR
UVWh
PpUSQ
SUR
UVW
BPQP
IpPWSV
T$0WP
D$4RPV
D$ WPV
SVQ
L$(QR
D$,VPU
L$$SUP
SUV
D$ SQ
SVW
WRV
T$(QR
4VWj,
D$HQ
L$HR
hVW
D$Hj
L$DQR
D$HPQ
T$LS
T$TV
T$dW
D$ SP
T$ Rj
T$$Rj
T$@Rj
T$DRj
T$(Rj
T$,Rj
T$0Rj
T$4Rj
T$8Rj
T$<Rj
F0Qj
~D]9|$Dt
V0PWQ
V(Pj
V(Pj
V8Pj
V8Pj
WVP
|$,VWSP
t';p<u"
WVP
UQWS
QRPV
@PQRP
QRP
@PQRP
QRP
Q0VP
WUS
PWSV
PQRV
@PQRP
QRP
HLR
QRP
QSUVWh
T$$UWSP
WRP
SVWh
SVP
VSP
WVP
SUVWh
QWSU
uE9D$ u?
SVh
@PQRP
QRP
HLR
QRP
SUVWh
VSW
SUVWh
Q$PUWS
VWh
@PQRP
QRP
HLR
QRP
SUVh
QSV
QQP
REU
t';p(u"
QQP
PSWV
UBPR
WVP
WSVP
SVP
UVWj
tEVh
PVW
D$$Pj
T$,Rj
t*;p<u%
VRP
PQR
VWSP
L$ Qj
WPV
SQV
SRV
WVP
VDR
O0PQ
SUj8
nDj
PWS
QRU
W,RP
QRVu
RVu
QDPV
B@QV
QLPV
BHQV
QPj
QRj
vBU
tPW3
SUV
Rj@UW
PQUW
SVW
SVW
SVW
SVWP
SVW
tVSV
SVW
rw+M
SWj
NNt
t}HHts
KHt"Ht
HHu$
t%Vhj
SVW
<hTr
hLr
hHr
hDr
WVS
WVS
WVS
u WPS
uCWVS
t%WVS
hXv
8csm
SVW
SVW
0PQR
SVWtW
tJjP
VWu
tVSW
SVWj
uXP
EhW
u$VW
=DXT1t
=DXT2t
=DXT3t
=DXT4t
=DXT5u
MD+E8+UH;
ET+M<+EL;
MlQS
ElY
UHR
RSP
Qpj
ElY
M(SP
uxP
FHPW
HHj
HHj
UdRP
Wj4P
SWP
SSSP
St1j
WWP
WWWP
EpS3
RSP
UtuU
#=DXT2t
=DXT3t
=DXT4t
=DXT5u
ELu
+}T+uX
uxVV
EHt
uxVV
SVW
Pht}
uojPZ
jWZ
jNZ
at)It;
tyj
OtH
atCJtP
djQ
QQS
KtP
hTEXT
QQS
FFGG
stP
hFILE
sth
hLINE
~DCP
YYh
SUVW3
uS@@j
YYj
vcII)-p
stW
E Ph<
PVh(
VVP
uwS
UVW
t$Wh
DXT1t$
DXT2t
DXT3t
DXT4t
DXT5u
CCGG;\$$
GG9E
CCGG;\$$
QSV
VWj
VWj
t:It.
tDItA
WVj
WVj
WVj
WVj
WVj
WVj
WSj
WSj
SWj
SWj
8SVW3
WRWWQP
`SVW
wN9E
uh9U
=DXT1t$=DXT2t
=DXT3t
=DXT4t
=DXT5t
tm9U
um;E
ud;u
HVW
HtkH
HtpHH
HHt|H
QQV
tAS
SVWh
9pHt_
tQSW
WSS
WSS
BBF;
BBF;
BBF;
BBF;
SVW3
SVW3
BBF;
BBF;
SVW3
SVW3
BBF;
SVW3
SVW3
BBG;
SVW3
BBC
(SVW3
(SVW3
SVW3
BBA
,SVW3
s=SVW3
QQSVWj
UYVYu
RVP
SVW
CSj
=DXT1
=DXT2t
=DXT3t
VWuL
DzD
DXT13
HtaHHt3
=DXT2
=YUY2
=DXT3tf=DXT4t5=DXT5
tqW
khl
tNW
Hhl
PVVt;
AuA
a(Cj
AuV
tQW
tVW
YYu
D$PP
PVV
D$PPVV
PVV
D$PPVV
D$TP
D$PPVVt;
upW
ELP
ELP
SWj
Q 9~Pt,Sj
9NPt
FXP
SWj
Fxf
Flu
^xWW
QWSP
SVW
uXtn
PPPP
uhPP
uhPP
slt
UH+U@
EL+ED
MPu/
;Upr
;EXr
Ep;Ctw
EX;Cx
Epj
spY
EdPV
slt
Edt2
;ETs'
;ETr
ETu
Mlv
Mt)}t
;Epv
KtPQ
U(RP
UhsJ
;UPr
Uhr
sX;up
UuL
UVWu>
YtO
QSVW3
PWh
SVW`
,SVW
SWj%Y3
VWu
tUj
AuM
PSV
uxj
9U|VW
tFj
Exf
ETP
]lf9ELt
ETj@
YY|d
VWj
Edj
ExP
ElP
Uxu
(SVW
APY
AThP
Apf
AxB
A<EF
QQW
Wuq9E
WVUS
WVUS
nD$H
oL$H
oL$H
oD$P
oL$X
oT$p
ol$x
oL$H
oL$H
oD$P
oL$X
oT$p
ol$x
oL$P
od$x
ot$H
od$p
NULL
PID_%4X
PID_
VID_%4X
VID_
DeviceID
Win32_PNPEntity
\\.\root\cimv2
.ahk
\My Cheat Tables\
\AutoHotKey.dll
peixoto.dll
Arial
ABCDEFGHIJKLMNO
RSTU
VGH#
JL@1@IKZ
!2345MNPOQSTU;>]>^a
++-]N.Pa
./01.]9:N[P9:S
.,,,,++.]-,,MN,P,,
ol$P
ol$P
ol$P
ol$P
oL$P
od$x
ot$H
od$p
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
oL$P
od$x
ot$H
od$p
ol$P
ol$P
ol$P
ol$P
oL$P
od$x
ot$H
od$p
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ol$P
ML;MH
bad allocation
ahktextdll
AutoHotkey.dll
OPAL8
X8RGB
A8RGB
A4RGB
A1RGB
X1RGB
RG6B
wglDXLockObjectsNV
wglDXObjectAccessNV
wglDXCloseDeviceNV
wglDXOpenDeviceNV
AHK Plugin
ahkReady
ahkdll
ahkExec
AutoHotKey.dll
UYVY
YUY2
DXT1
DXT2
DXT3
DXT4
DXT5
def
syntax error
sat
logp
expp
dst
lit
log
exp
sge
slt
max
min
rsq
rcp
bem
texld
texdepth
texcrd
phase
texdp3tex
texm3x3
texreg2rgb
texdp3
texm3x2depth
texm3x3vspec
texm3x3spec
texm3x3tex
texm3x3pad
texm3x2tex
texm3x2pad
texreg2gb
texreg2ar
texbeml
texbem
tex
texkill
texcoord
cmp
cnd
lrp
frc
mul
mad
sub
add
mov
nop
invalid mask '%s'
oFog
oPts
oPos
_bias
invalid constant
#line
invalid version
yacc stack overflow
statement expected
ValidatePixelShader
d3d8.dll
d3d8d.dll
LoadDebugRuntime
DebugSetMute
BLM
DisableMMX
GenuineIntel
DisableD3DXPSGP
Freed XMS handle %u
Start of Image
RST%d
End Of Image
Freed EMS handle %u
6a 7-Feb-96
Write to XMS failed
Not implemented yet
Empty input file
Write to EMS failed
Bogus DQT index %d
Bogus DHT index %d
Bogus DHT counts
Bogus DAC index %d
Bogus marker length
IHDR
IDAT
IEND
PLTE
gAMA
sRGB
tRNS
PNG
AuthenticAMD
UnknownVendr
need dictionary
IDAT
jHq
kdz
rqg
LhX
Qkkbal
Zjz
i]Wb
knv
owG
kaE
MGiI
wn>Jj
buffer error
insufficient memory
data error
stream error
file error
stream end
ReleaseDC
GetDC
MessageBoxW
USER32.dll
WriteConsoleW
CloseHandle
ReadFile
GetFileSizeEx
CreateFileW
CreateThread
GetProcAddress
GetModuleHandleA
GetModuleHandleW
VirtualFree
GetLastError
VirtualAlloc
Sleep
OpenProcess
LoadLibraryW
GetModuleFileNameW
KERNEL32.dll
CoUninitialize
CoSetProxyBlanket
CoCreateInstance
CoInitialize
IIDFromString
ole32.dll
PathFileExistsW
PathRemoveFileSpecW
SHLWAPI.dll
SHGetFolderPathW
SHELL32.dll
OLEAUT32.dll
PSAPI.DLL
wglDeleteContext
wglGetProcAddress
wglMakeCurrent
wglCreateContext
OPENGL32.dll
SetPixelFormat
ChoosePixelFormat
DeleteObject
CreateFontW
GDI32.dll
malloc
memcpy
wcsstr
swscanf
memset
free
??2@YAPAXI@Z
_itow_s
_wsplitpath_s
_local_unwind4
MSVCR90.dll
??3@YAXPAX@Z
_encode_pointer
_malloc_crt
_encoded_null
_decode_pointer
_initterm
_initterm_e
_amsg_exit
_adjust_fdiv
__CppXcptFilter
_crt_debugger_hook
?terminate@@YAXXZ
_unlock
__dllonexit
_lock
_onexit
XINPUT1_3.dll
RegCloseKey
RegQueryValueExA
RegOpenKeyA
ADVAPI32.dll
DrawTextA
DrawTextW
HeapReAlloc
HeapAlloc
SetThreadContext
GetThreadContext
Thread32Next
GetCurrentThreadId
GetCurrentProcessId
Thread32First
SuspendThread
OpenThread
HeapFree
ResumeThread
GetCurrentProcess
VirtualProtect
HeapCreate
HeapDestroy
VirtualQuery
InterlockedExchange
TerminateProcess
IsDebuggerPresent
GetTickCount
WideCharToMultiByte
GetVersionExA
GetProcessHeap
LoadLibraryA
GetObjectA
CreateFontIndirectA
DeleteDC
SelectObject
SetTextColor
SetBkColor
SetBkMode
CreateDIBSection
CreateCompatibleDC
_snprintf
__CxxFrameHandler
_vsnprintf
atoi
isdigit
isalpha
isalnum
isspace
sscanf
_strdup
setlocale
_ftol
floor
_CIacos
_finite
peixoto.dll
CreateTexture8Hook
CreateTexture9Hook
DrawPrimitive8Hook
IsXInputDevice
LoadBinary
Lock4Hook
ManagerBltFast
ManagerLock4
ManagerUnLock4
OniSetTexture8Hook
ReleaseSurface8Hook
ReleaseSurface9Hook
ReleaseTexture8Hook
ReleaseTexture9Hook
SetPixelShader8Hook
SetPixelShader9Hook
SetRenderState2Hook
SetTexture3Hook
SetTexture3HookB
SetTexture7Hook
SetTexture7HookB
SetTexture8Hook
SetTexture9Hook
UnLock4Hook
UpdateTexture9Hook
CEPlugin_GetCEFuncs
CEPlugin_GetVersion
CreateEffectHook
Critical
DrawPrimitive2Hook
DrawPrimitive3Hook
DrawPrimitive7Hook
GetSurfaceID
GetTexture2ID
InitHDHooks2
InitHDHooks3
InitHDHooks7
InitHDHooks8
InitManagerHooks
InitShaderOverride8
InitShaderOverride9
InitTextSwapLib
InitTextSwapLib8
InitTextSwapLib9
InitTextSwapLibGl
LoadData2Surface
LockSurface4Hook
OpenGLInit
Pal2RGB
ReleaseAllHooks
ScaleVertices
Surface4BltFastHook
Surface4BltHook
UnLockSurface4Hook
copyData2Surface
d3D8CreateFont
d3D8DeleteFont
d3D8DrawRect
d3D8Write
d3D9_DDI_BltHook
d3D9_DDI_Init
glBindTexture_Hook
sethook
sigscan
surfaceCopy
unhook
.?AVConstantForce@@
.?AUIUnknown@@
YYYYY
YYYYYYYYYYYY
}YPPPPYYYYa
``YYYYYYYYYYY
PPPP
DPv
.?AVtype_info@@
UYVY
UYVY
YUY2
YUY2
DXT1
DXT1
DXT2
DXT2
DXT3
DXT3
DXT4
DXT4
DXT5
DXT5
Jj?,L
CEu
EKB
4h!"4h!"4h!"4h!"4
L>tU
VS_VERSION_INFO
StringFileInfo
CompanyName
peixoto dll
FileDescription
FileVersion
InternalName
peixoto dll
LegalCopyright
OriginalFilename
peixoto.dll
ProductName
peixoto
ProductVersion
VarFileInfo
Translation
=h!"4h!"4h!"4h!"4
<security>
</security>
</trustInfo>
<dependency>
<dependentAssembly>
</dependency>
0F0N0U0i0
1D1J1O1V1
1I2S2]2h2
1Y2u2z2
616C6W6y6
9-9T9d9n9z9
:N;T;];o;y;
>.>E>e>z>
7A7b7o7w7
9P:f:r:
8%818?8P8d8j8o8
:B:G:S:Z:f:o:w:
;-;:;S;a;q;
>1>D>a>f>o>w>~>
151F1L1Z1
2%2.262?2O2j2w2|2
4#4.464E4K4a4
5/5:5B5i5z5
7 7)7.7A7G7b7h7m7
9#9.969?9J9R9e9w9}9
;-;8;I;Z;e;m;
;&;2;>;a;p;w;
<"<+<:<B<S<]<b<
80969L9Y9z9
1.242J2S2Z2_2u2
3 3%3+3F3K3W3g3m3t3
434D4O4W4
808;8S8i8v8
9P:V:\:b:i:
6S8d8U<h<z<
8/8D8b8x8
6A8I8w8
1!1%1)1f1l1r1v1|1
2"2(242F2g2v2{2
4'4@4K4T4Y4f4n4y4
7D7*8B9O9e9u9
;!;4;<;B;S;Z;c;
3C4Z4k4
9K:Q:y:
4v5&6A6\6x6
5#5,5;5D5O5W5l5
6E7P7V7
<!<+<A<K<a<k<&=B=z=
>%>@>O>U>p>
081>1Y1e1k1
3p:t:x:|:
;$<<<D<S<g<
2+2_2p2&3M3e3m3|3
4!4'4J4A5N5[5
0,1F1d1o1
3+313F3L3a3g3v3
;#<I=O=g=z=
9E:X:g:v:
?"?)?0?7?>?E?Z?f?
C0J0Q0X0_0f0m0t0{0
1)131=1G1Q1[1e1o1y1
8#8*858A8F8M8
8d9r9z9
273F3n3y3
9I9Q9i9
0e1l1y1
3G3O3Y3`3g3q3
4F4N4[4b4i4p4w4~4
6C6J6Q6
7C7J7Q7[7r7
8C8J8Q8[8r8
8C9M9W9d9u9
:H:c:m:w:
=)=A=H=Q=j=u=
=I>a>h>q>
1>1I1T1g1
,;0;@;D;L;d;t;x;
<$<4<8<@<X<h<l<|<
?$?<?D?P?h?p?x?
Use Apitrace, paste apitrace d3d8.dll in the game directory and run the game. A .trace file will be created in the game directory. Keep it short
Reply 96 of 896, by Peixoto
Update:
- New patches
Martian Gothic
Soul Reaver
Heart of Darkness
- Direct3D games now support 4k (since the last update, actually)
- Texture swapping improved
- Little big adventure 1 and 2 will be scaled in hardware
- The patches for games the use 8bit modes (Lba 1 and 2, HOD and Blood Omen) will now probably solve problems on vista an seven, since that mode is now completely emulated
Reply 97 of 896, by RaZziel94
Soo after moved from Apitrace .Dll file to game directory and Piexoto directory it is working not perfectly smooth but smoother and item menu is much much better the other thing textures are sometimes not complete. but I have another problem when I launch game from original directory there are saves but when I launch game through piexoto Help.exe there are not any saves. Where do I find those saves I tryed to search Appdata but I did not had any luck. Anyway thank you a lot for you´r time Piexoto with out you It would not work.
Reply 98 of 896, by RaZziel94
Here is link for the trace file: https://mega.nz/#!RWYEVQoS!k8iH-XkH_UzJ1QU26- … prDZQEloMhoBPDI
Reply 99 of 896, by pred
We could use bbcode's code.
