First post, by madeskimo
silent hunter commanders edition does run in dos box, but time commpression is limited to 64 or 16 highest at times
Reply 1 of 4, by TPJ
When no enemy is on a map, time compression is limited to 128x (sometimes even 256x). With enemy on a map (but no in sight) time compression slows down to 64x. When enemy is in sight, time compression is set to 8x.
I'm working on Celeron 2.4 GHz, GeForce FX 5200 128 MB, Sound Blaster 5.1. I'm running DosBOX in fullscreen mode (doublebuffering, of curse) with 4-5 frameskip and about 5000 cycles (soon I will probe more), on Linux (Aurox Linux, but I'm sure it will run on other distributions too).
Reply 2 of 4, by funky3l
This issue is not related to DOSBox itself - that's the way Silent Hunter was coded. If you have any uints in the neighbourhood, you cannot set time acceleration to a value higher than 64.
Reply 3 of 4, by airwolf
i need to know how to get silent hunter commanders edition to work im using dosbox and d-fend and can understand how to work it i need a complete walkthrough on how to do it and then i should be fine i have the silent hunter commanders editon cd rom please help me with this
Ryan
