Re: Compaq Deskpro!
Compaq Deskpro!
Postby TheAbandonwareGuy » 2017-11-04 @ 19:24
Paid 80 for this on eBay. It's supposedly working and passed a system stress test. The IO is untested but the fact it passed a stress test tells me they keyboard and mouse ports are at least ok and I have a Compaq USB PCI card I can use for USB if its USB bad. It's a Deskpro 6266. I've been wanting a Pentium II AGP system for a while now for 1997 to 1998 games that I feel are too new for the S7 MMX machine and too old for the Pentium III. He was asking 88 total shipping included but I talked him down to 80 even citing the minor case damage and the IO ports being untested and the work it would take to bring it back to factory condition. Not a bad deal considering there was already a wealth of information available about these machines and Deskpros are my preferred model of vintage computer.
Pentium II 266 MMX (Kalmath?)
256MB SDR (Maxed out)
10GB HDD (Not stock. Not in a 1998 system no way)
ESS 1869F Integrated Audio (No clue if that's any good. Will be replaced by my SB Live)
CD ROM Drive (unknown speed)
3.5 Inch Floppy
Unknown AGP 2x Video Card (Should be either a Rage Pro Turbo, a Matrox Millinium II, or a Matrox G200)
It should have 4 PCI and 2 ISA. There combo slots so only 4 cards may be installed at once. The AGP is nice but the caveat is that it uses a non-standard mounting bracket so only cards with top mounted VGA can work. I'll have to swap the bracket but that's not hard to do. It will either get my RiVA 128 or the card I just bought as era correct AGP video unless it has the G200 option. If it has the G200 I'll leave it configured as is. It will also get my half functional Voodoo2 (only works in GLIDE and with one texture unit disabled. So it runs like a 8MB Voodoo Graphics). This will be the base for my Windows 95 build. I'll likely use 2.1 OSR since that has the USB and AGP drivers built in if I remember correctly. I'll also install my second gen (non-gold ports) Soundblaster LIVE although the onboard audio has a rather beefy speaker backed a by Phillips amp). Since it's been brought up here before let me go into detail on what the deal with those half bracket Compaq video cards are just to dispel any standing mis-understandings. (Note: Picture from UXWBIlls video here: https://www.youtube.com/watch?v=RhlYV836tUE)
Basically, they are normal AGP video cards with half height brackets missing the bottom portion that are dual width in reverse. Shown here is the Rage Pro Turbo option. It's a normal PCB. It just lacks the metal bracket like seen on my Rage IIc that I just bought shown in the second picture.
In theory any card that:
1.) Has a VGA port that is mounted on the top 33 percentish of the board
2.) Can have its bracket swapped out
3.) Does not extend lower than the AGP slot (it would hit the IO port below if it did)
could be retro-fitted into this system. Vice versa the Compaq cards could probably be fitted into any normal ATX machine. The bottom half of the bracket slot however would be blank unless you swap in a compatible full height bracket. Overall if you have basic computer knowledge and aren't trying to fit unreasonably newer cards with DVI ports on the bottom into it its not that restrictive as most 90s video cards fit the above 3 criteria.
https://www.youtube.com/channel/UCuFY6Z ... 2tV8b00x_A
1996|P200MMX|64MB EDO|Virge DX 4MB|SB16 OPL3
1999|P3 933|384MB SDR|GF256 SDR 32MB|CT4620
User avatar
TheAbandonwareGuy
Re: Compaq Deskpro!
Postby probnot » 2017-11-04 @ 20:59
Neat, I always wondered what this card I had was from.
User avatar
probnot
Re: Compaq Deskpro!
Postby BitWrangler » 2017-11-04 @ 22:12
TheAbandonwareGuy wrote:It's a Deskpro 6266. I've been wanting a Pentium II AGP system for a while now for 1997 to 1998 games that I feel are too new for the S7 MMX machine and too old for the Pentium III. He was asking 88 total shipping included but I talked him down to 80 even citing the minor case damage and the IO ports being untested and the work it would take to bring it back to factory condition. Not a bad deal considering there was already a wealth of information available about these machines and Deskpros are my preferred model of vintage computer.
I thought I had a PII Deskpro, but on a check of the pile it's transmogrified into a P-233 MMX Deskpro, a 4000 series. Man that series runs the whole gamut, P, P pro, P MMX, and P II.
Ahhh Compaq, they think they get a free pass on being "industry defining" due to knocking out an AT class 386 before IBM, so standards don't apply to them. So them and IBM seem to have some of the least completely "IBM compatible" machines around... well I guess on the software side they're mainly hunky dory.
I know I've seen that style of VGA card and bracket before, not sure if I own one, unless the 4000 is the same.
Basement full of ancient PC stuff, starting to go through it. Most recently toyed with DOS era stuff 15 years ago, so memory might be rusty. So what's this BitWrangler guy's deal ??? >>> http://www.vogons.org/viewtopic.php?f=25&t=56382
User avatar
BitWrangler
Re: Compaq Deskpro!
Postby TheAbandonwareGuy » 2017-11-04 @ 22:57
I think I'm going to start a separate Deskpro thread. Any chance a mod could move the existing posts to one?
User avatar
TheAbandonwareGuy
Re: Compaq Deskpro!
Postby JidaiGeki » 2017-11-05 @ 14:27
That cut-out top-mounted VGA card is also similar to those used with NLX boards/cases. I have a couple with a square rear plate, rather than a long one. In any case TAG, that's a nice Deskpro, I have a soft spot for Compaqs.
JidaiGeki
Re: Compaq Deskpro!
Postby Stiletto » 2017-11-05 @ 20:26
TheAbandonwareGuy wrote:I think I'm going to start a separate Deskpro thread. Any chance a mod could move the existing posts to one?
Done. :D
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Re: Compaq Deskpro!
Postby TheAbandonwareGuy » 2017-11-05 @ 20:28
Done. :D
Thanks Stiletto.
User avatar
TheAbandonwareGuy
Re: Compaq Deskpro!
Postby Standard Def Steve » 2017-11-05 @ 21:15
Now that brings back memories. Back in 99, the high school that I went to installed a bunch of those Deskpros. Most of them were PII-400s with that exact desktop chassis. The new media lab had Deskpro towers with PIIIs in them, I think 550 or 600MHz.
Standard Def Steve
Re: Compaq Deskpro!
Postby PTherapist » 2017-11-05 @ 22:53
I used to have one that looked just like that, also a Pentium II (think it may have been 300 or 400MHz, not sure, but I still have the CPU in storage somewhere). I upgraded the CPU to a Pentium III 600MHz and the RAM to 128MB and it made a great little Windows 2000/Windows XP system back in the day, with an AGP Voodoo 3 16MB card installed.
I lent the system out to a friend of my mother's about 10+ years ago and never asked for it back. Not sure if he even still has it, I should really try and find out as I'd love to have that system back.
PTherapist
Re: Re: Compaq Deskpro!
Postby Scraphoarder » 2017-11-05 @ 23:05
This Deskpro also brings out memories for me. We aquried around 100 refurbished to work with a P3 550 in 2002 when deploying Windows XP. They replaced old Deskpro 2000 and Prolinea 5xx models running NT4. The last one was taken out of service three years ago from a library where it had been running a self service book loan application.
The odd AGP form factor were annoying and beside the ATI cards i never saw other that used that except a Matrox card.
User avatar
Scraphoarder
Postby TheAbandonwareGuy » 2017-11-06 @ 00:42
So these can go up to P3s?
UXWBill says in his video they only have jumpers for CPUs up to 400 in the Slot 1 configuration.
User avatar
TheAbandonwareGuy
Postby Deksor » 2017-11-06 @ 06:26
These jumpers are probably made to select the multiplicator of the cpu and the FSB. Since Intel locked the multiplicators, there's no need to select the proper multiplicator. All you need is to select the right fsb
Deksor
Postby PTherapist » 2017-11-06 @ 10:42
Yeah, pretty much the above. When I replaced the Pentium II CPU with the 600MHz Pentium III, I didn't need to alter a single thing it just worked immediately at the correct speed (same FSB).
PTherapist
Re: Compaq Deskpro!
Postby Cyberdyne » 2017-11-06 @ 12:44
You can even change that partition to a normal FAT16 partition, extract those files, and use them in that included mini Windows 3.1 or full blown windows.
Then you do not have to restart, to change your Deskpro Bios settings.
I am aroused about any X86 stuff that has full functional ISA stuff. I think i have problem.
User avatar
Cyberdyne
Re: Compaq Deskpro!
Postby TheAbandonwareGuy » 2017-11-06 @ 17:09
Cyberdyne wrote:You can even change that partition to a normal FAT16 partition, extract those files, and use them in that included mini Windows 3.1 or full blown windows.
Did the slot 1 systems use that software BIOs or did that stop with Socket 7 based Deskpros? I'm really hoping mine doesn't because that will not be a fun piece of software to find.
User avatar
TheAbandonwareGuy
Re: Compaq Deskpro!
Postby Jade Falcon » 2017-11-06 @ 17:17
That type of VGA card is very common for compaq's and a few others. I recall fining an HP that used one.
I'd keep the rage and add a voodoo1 or 2 to the system If the have the pci port for one.
the ATi card will be nice for playing MW2 in 3d. If I recall most card like this are matrox cards, ATi rage and a few 3DLabs cards. maybe a s3 virge too.
Jade Falcon
BANNED
Re: Compaq Deskpro!
Postby Cyberdyne » 2017-11-06 @ 19:59
Deskpro 2000 and 4000 use those. Idk if slot 1 machines use them.
User avatar
Cyberdyne
Re: Compaq Deskpro!
Postby TheAbandonwareGuy » 2017-11-06 @ 21:32
Jade Falcon wrote:That type of VGA card is very common for compaq's and a few others. I recall fining an HP that used one.
The Matrox plus my half working V2 would be ideal just to keep the 2d signal hit to a minimum. Anything from 1999 is new enough I would run it on my P3-933
User avatar
TheAbandonwareGuy
Postby TheAbandonwareGuy » 2017-11-08 @ 18:44
Mine arrived today. The BIOs is password locked and the case locking solenoid auto engaged when I powered it up....
I told the seller if he doesn't provide the password within 24 hours its going to be an item not as described case.
User avatar
TheAbandonwareGuy
Re: Compaq Deskpro!
Postby alex_theman » 2017-11-08 @ 19:49
TheAbandonwareGuy wrote:Mine arrived today. The BIOs is password locked and the case locking solenoid auto engaged when I powered it up....
Have you tried resetting the BIOS/Settings partition? I think you can reset it by downloading the right utility off of HP's FTP (I think this is it) and booting from the floppies it prompts you to create when you execute it. Then use some of the tips listed at this thread to get the case off if you can't get it off normally.
alex_theman
Next
Who is online
Users browsing this forum: kd0kqq, LHN91, linkdex [Bot], MetalMilitia, SammyFox and 6 guests
