Halo CE on Geforce2 Ti
First post, by tanasen
So I've restored a retro pc. I have an ECS P6BAP-A+ REV 1.0 motherboard, Pentium III 1000B, 320mb of ram and the Chaintech Geforce2 Ti 32mb version.
I've been trying to play Halo Combat Evolved in Windows XP in all resolutions and lowered all graphics but the framerate remains the same, about 18fps average... I have installed the 5.2.1.6 Nvidia drivers (in dxdiag it says version 6.14.0010.5216) and DirectX9.0c I know that the gpu supports only up to directx7 and Halo is a directx8.1 game, so is that the main reason I can't have a playable experience (plus the limited 32mb of vram)?
PC1😜 III-S 1.4GHz, GA-6VTXE, 512MB SDRAM, Albatron FX5900XTV 128MB, SB Live! 5.1
PC2😜 III 800MHz, MS-6178, 256MB SDRAM, 3DFX Voodoo3 2000 PCI, Creative CT4810
PC3😜 MMX 200MHz, SY-5EAS5, 128MB SDRAM, Diamond Monster 3D, Diamond Viper V330, ESS 1868F
Reply 1 of 26, by F2bnp
It's been years since I played it on period hardware, but Halo CE on PC was kind of a hog in its day. You are essentially skating on the minimum system requirements, this game came out in late 2003 so it was not uncommon to own a fast Pentium 4 or Athlon XP or even Athlon 64 and GeForce4, FX or Radeon 9600++ cards at the time. Even in high end systems, it proved to be quite a struggle to maintain 60fps at resolutions above 1024x768.
Anyway, since you've tried lowering the resolution and graphical details and see zero change in performance, it is safe to assume you are severely CPU limited. If the system is performing in a satisfactory way in other games, I would just forget about Halo. IMO, it would take at least a Tualatin 1.4 and GF4 Ti or one of the faster GeForceFX variants to make this experience pleasurable.
Reply 2 of 26, by tanasen
2003? In wiki it says that the release date was November 2001...
Reply 4 of 26, by tanasen
Ok I'll stick with older games then. Quake3 , Unreal Gold run excellent.
Reply 5 of 26, by SPBHM
Halo was demanding for Radeon 9700 and Geforce FX at high res
geforce 2 will run with lots of effects disabled and not very fast,
the game was originally made (I know it was originally multiplatform, but it switched to that hardware spec) for the Xbox which had a geforce 3/4ti style GPU, but highly optimized and at low resolution.
Reply 6 of 26, by Jade Falcon
Rank BANNED
BANNED
Well, I know I never had much problems paying the game with a 2ghz northwood and a voodoo5500 back in the day. But The voodoo did not support anything like pixel shader, try truning off things like pixel shader and stuff, a GF2 should be more then able to play the game at 800x600 if its a 64mb card with some of the setting set lower.
oh and I'm not nuts, halo can be played on a voodoo5500
http://www.3dfxzone.it/enboard/topic.asp?TOPIC_ID=1092
Reply 7 of 26, by foey
Just fired this up on a machine I've been playing with recently...
Pentium III 1.4Ghz, 256mb Ram, 815e Chipset, 128mb Nvidia FX5200 PCI (64bit Memory) @ 300/475, Windows 2000 SP4.
Video Settings :-
800x600
No V-Sync
Specular :- No
Shadows :- No
Decals :- No
Particles :- Low
Texture Quality :- Medium
I'm getting 20-30 FPS in the first "training screen" After, when running in the corridors I'm getting anywhere from 30-50, some dips down to 18 in highly populated areas.
Cyrix Instead Build, 6x86 166+ | 32mb SD | 4mb S3 Virge DX | Creative AWE64 | Win95
ATC-S PIII Tualatin Win9x Build :- ATC-S PIII Coppermine Win9x Build Log [WIP] **Photo Heavy**
Reply 8 of 26, by SPBHM
the game offered shader 2.0, 1.1 and fixed function mode, so if you run with a geforce 2, geforce 3/4 or newer the load and effects are different, I suppose the 5200 PCI runs in shader 1.1 mode?
Reply 9 of 26, by foey
I'm assuming it's related to CPU bottleneck since none of the graphic settings have any affect to the FPS. I think my extra 400mhz with addtional cache is making the difference here.
Both my crippled FX5200 and the Geforce 2 should be on/around the same pace here.
Reply 10 of 26, by leileilol
I think it has to probably do with the sloppy way Gearbox ported it (just before Halo they had ported Crazy Taxi with performance issues). Any plasma weapon overheating tends to make the fillrate crap itself, which has me thinking they have some combine ops going on with everything or unneccessary alpha modulation on all additive stuff (instead of like, uh...modulating the color to black). It definitely doesn't reflect its Mac-era performance in the prerelease footage on obviously-pre-Geforce3 hardware 😀
Reply 11 of 26, by F2bnp
I used to think the PC version was just as good as the XBOX version in the visual department, but it turns out it lacks a few features and effects.
Digital Foundry had a great video on the original game and they touch on newer version of the game, such as the PC version. https://www.youtube.com/watch?v=C6NSm54ImcA
Reply 12 of 26, by swaaye
I remember there being some kind of fast shader patch for the multiplayer mode. Or Custom Edition some such.
Maybe this
http://hce.halomaps.org/?nid=105
Reply 13 of 26, by SPBHM
yes that's kind of disappointing, but overall the PC version is more enjoyable to play due to resolution alone, I played the entire campaign on the XB and PC and those differences I didn't notice easily without the side by side comparison, now resolution and framerate is easy, still looks great on the Xbox on a CRT TV... but I no longer have the Xbox.
one interesting thing is that on my (limited) testing the 9500PRO is a good bit faster than the FX5900SE, not a big surprise since it's DX9, but on benchmakrs from back in the day the FX was faster, maybe it's because I used drivers from 2008 or something, but the difference is very clear, the 9500PRO perhaps suffers more with some effects, but overall is clearly smoother.
but those cards can't really keep a 30fps stable at 1024x768, with a p4 3GHz
not sure which card is needed for 60FPS lock, but when I played it on my 5850 it was very easy with low GPU usage, I'm guessing something like a x800xt already can get close to that level?
Reply 14 of 26, by F2bnp
I agree with you, I'd take higher res any day of the week. Just thought it was cool to point it out 😁.
And yes, it is a very demanding game on PC. Xbitlabs used to be an amazing resource for these years, but it went down at the start of the year with almost no warning. Fortunately, I was able to find this, there were also graphs for 1280x1024 and 1600x1200, but the links are dead.
So yeah, you're not far off there!
Reply 15 of 26, by tanasen
Hello again. I'm kind of looking for a dx9 agp card that could boost the performance of that pc. I found a couple geforce 6200 128mb and 256mb, an FX 5200 128mb, an FX 5700 256mb, a Radeon 9500 Pro 128mb and a Radeon 9550 256mb.
Which one of the above would be the best choice for some 2003-2004 games (Halo CE, Doom3, FarCry, HalfLife2, GTA SA) on a P3 1000B? I'm leaning towards the FX 5700 or the 9500 Pro.
Reply 16 of 26, by RogueTrip2012
I'd say radeon is faster but would be bottlenecked by a P3 1ghz.
I built a 5700 Ultra with a Pent4 3ghz w/HT system back when it was new. Before that it was a 1.2ghz Taulatin with a GF3 Ti200.
With the P4 w/HT system even at 800x600 Doom3 was spotty to were it never even played it very long . HL2 had to drop DX7 or 8 but did finish the game on that system.
My point is I don't think those games will run well on that P3.
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>Win XP . AMD 960T . 8GB . Q.K2200. SB X-Fi . 512GB SSD . 2TB HDD
> Win XI . i7 12700k . 96GB . RTX4070TI . 512GB NVME
Reply 17 of 26, by candle_86
Honestly Halo was a hog in its day, I ran it with my buddies at lan parties, on a Duron 1600 with 512mb of ram and an MX440 and it was barely playable, so im not surprised at your slowness
Reply 18 of 26, by tanasen
RogueTrip2012 wrote:
I'd say radeon is faster but would be bottlenecked by a P3 1ghz. […]
So what would be a decent upgrade in order to reach the maximum potential of the 1000eb, apart from the ram which could be maximised to 384mb? Would the 6200 and fx5200 also be bottlenecked by the cpu? I have seen a video of a P3 866mhz running doom3 on a Geforce6200, quiet good, maybe 20-30fps.
Reply 19 of 26, by candle_86
You can try a Radeon 9800 Pro/Geforce 6600GT they could run it at Ultra at 1024x768
