First post, by Pabloz
This is kind of weird and im not sure whats going on. Maybe its the power supply but i doubt. I have 3 PSUs, two AT and one ATX
i have been testing different motherboards brands and models.
Some motherboards not listed here posted at first try, no mattery what, they always posted and machine booted.
By post i mean the monitor received a signal displayed the boot.
But on others....for example:
pcchips m919
pcchips m912
pcchips m915i
pcchips m520
fic pa-2013
Soyo 6vba 133u
The m919 is a casino jackpot, posts when it wants to post, else black screen and no signal on the monitor. its a 50% chance it wont post and you need to turn off and turn on again.
But i noticed that on the rest, there was a high percentage chance that it wont post, and that you need to turn off and turn on again for it to post and boot.
So im wondering if you experienced this with old hardware, there is no chance that im the only one that experienced this. Because there were NO changes done and nothing touched, it just needed to turn off and turn on again.
besides one of the reasons for it to not post is the memory for example, but memory was not changed at all and posted on the second try.
Any thoughts? could be capacitors even if they are not bulky they die after 20 years? or could be the voltage regulators?
Reply 4 of 8, by ODwilly
My old Soyo 478 motherboard is like that. All the primary caps were blown and replaced with fresh Rubycons. However all the secondaries are the same junk brand. When I can get it to boot it runs great, but getting it to boot is like rolling dice weighted on 1. I think if I invested in a full recap it would stabilize, but there are like 30 small caps.
Reply 5 of 8, by PcBytes
Do a full recap. Believe me, most of the times you get those symptoms, a full recap will fix that.
One question though - is it one of these Dragon boards? If so, it's definitely worth a try to recap one.
Reply 7 of 8, by ODwilly
Yes, yes it is. P4S Dragon Ultra. I'm not equipped for a full recap but I think I'm just going to send it off to bad caps or have a friend do it for a few bucks.
Also found a boxed kt880 dragon ultra and 3200+ on the curb last week. Won't post but everything gets warm which is a good sign. Also needs a recap.
Reply 8 of 8, by BLockOUT
im not sure if full recap can fix these issues. I also have them from time to time
older boards are full of 22uf 25v caps everywhere. You can get a 486 board with more than 20 of those 22uf caps. do those make any difference at all? or the bigger caps are the issue?
