First post, by buckeye
Upon finding out that higher end P3 boards/cpus are sold for a mint these days I thought about pairing my V2's with a low level Pentium 4 in the range of 1.6-2.0ghz. Anybody try this combination with success or does it lead to problems with voltage or whatever? The OS is going to be Win98SE.
Reply 1 of 5, by Jade Falcon
Rank BANNED
BANNED
I done this setup a few times before, I never had one problem.
Don't believe the Lies others will tell you about the cards roasting or running hit do to the faster cpu. I have 2 voodoo2 in x58 system even.
Reply 2 of 5, by Captain NA
yes, Voodoo2 pretty mutch run on any 5v PCI slot system, even works in windows 10 systems. Also can't see how a fast CPU will be able to toast the card.
It's life Jim but not as we know it.
Reply 3 of 5, by Bobolaf
As others have said they do work. The Voodoo 2 does actually get warmer if you keep it busy. So it will run hotter on your P4 than on a original Pentium for example. But unless you have some real ventilation issues with your case its nothing to worry about. If your case can take a front mount fan or side mount next to PCI slots its never hurts to add a fan.
Reply 4 of 5, by Jade Falcon
Rank BANNED
BANNED
No they dont get hotter with a faster cpu.
Reply 5 of 5, by Gamecollector
P4 3.2E + 865PE + Radeon HD3850 + Voodoo2 SLI + WinXpSp3. Works perfectly except glide 2.1.1 games (both DOS and Win32), can't detect a card because the CPU is too fast.
P4 3.2E + 865PE + Radeon 9100 + Voodoo2 SLI + WinME - works ok if you use 3.02.02 or 3.03.00a drivers. Earlier version fail the detection because of a fast CPU.
Have tested a Voodoo2 SLI with C2D E8400 + Q45 Express + WinXpSp3 setup. The result is similar.
