First post, by PcBytes
I seriously have nothing better to do in the weekend 🤣
Decided doing some builds, so here they are.
XP build:
MB: ASUS P4P800-E Deluxe
PSU: modified Deer DR-A300ATX (recapped and modified for intense 12v usage)
RAM: 3x512MB DDR400
GPU: Radeon HD3450 512MB AGP8x
CPU: Pentium 4 2.8GHz Northwood
HDD: Seagate ST3160215ACE 160GB PATA HDD
ODD: TSSTCorp/Samsung SH-S222A DVD-RW
Case: JNC RJA-FQ-70
OS: Windows XP SP3, of course!
Vista/Linux Mint build:
MB: ASUS P5GC-MX/1333
PSU: Allied AL-A400ATX (120mm variant)
RAM: 512MB Kingmax DDR2-667
GPU: Geforce 7300LE 256MB DDR2 PCI-E
CPU: Intel Pentium Dual Core E2160 1.8GHz
HDD: Seagate Momentus 250GB 5400RPM
ODD: HL-DT-ST GSA-4167B w/ white bezel
Misc: Pixelview PV-TV304+ TV Tuner (CX23881)
Case: JNC RJA-52
OS: Vista SP2 and Linux Mint 18.2
Reply 1 of 7, by greasemonkey90s
PcBytes wrote:
Vista/Linux Mint build: […]
Case: JNC RJA-52
I have the same board but i was gonna run xp or 7 and have it as a emulation box. Sound like yours is geared for cheap htpc form. How do u like it.
Reply 2 of 7, by PcBytes
It's a pretty nice small board. Not a lot of OC features (although I have to admit, a uATX board with OC features isn't something usual) but that's not really something I'd use.
Other than that, nice layout which allows for wire management (see the photo), except for maybe the front panel positioning which I don't really understand. Shame it doesn't support quads though (or so I've read somewhere) because I'd actually drop a Q6600 in it for more processing power.
Probably going to replace the GPU with something more powerful - I don't know what should I aim for though - a 8500GT, a Geforce 210 or a GTS250?
Reply 3 of 7, by SW-SSG
Either of these cards (though, realistically, the 210 or newer) should be able to handle HD video decoding of some kind in hardware. Various sites like YouTube can use this to assist with video playback, as long as you use a modern browser + up-to-date drivers. Might be something to consider.
Reply 4 of 7, by RetroBoogie
Damn, I read 'Athlon XP build' and 'Vista' and was intrigued. Anyway, I would use the GTS 250, it's basically a rebadged 9800 GTX+.
Reply 5 of 7, by xjas
PcBytes wrote:
MB: ASUS P5GC-MX/1333 PSU: Allied AL-A400ATX (120mm variant) RAM: 512MB Kingmax DDR2-667 GPU: Geforce 7300LE 256MB DDR2 PCI-E CP […]
Case: JNC RJA-52
^^ You're probably gonna want more RAM for Mint. You can run it with 512MB but it'll be crunchy. I'd recommend 1GB at bare minimum for XFCE or 2GB for Cinnamon / KDE. Throw another stick in there if you have one.
Reply 6 of 7, by dr_st
It's must be a typo. Vista on 512MB is lunacy. 😀 Even the XP build has 1.5GB RAM. Vista should have at least 2GB, preferably 4GB.
Reply 7 of 7, by BitWrangler
I know 7 runs way better on 1GB than Vista does, but you still want another half to 1 if you want to do anything much.
