First post, by Diamondfist
- Newbie
I have tried looking for another instance of my problem on the forums, but haven't had any luck. I am running Ultima 8 (both CD-ROM Hard Drive Edition and Ultima Collection behave the same). It plays fine, but sometimes when I save, the game flat out crashes. I had Munt installed, and had to uninstall it from my system since changing the midiconfig setting to 0 didn't work (the default setting, and Munt was using 1), and setting ems=true and umb=false also caused it to crash regularly. I am saving in different slots.
With my current settings, (and Munt uninstalled, ems=false and umb=true) it crashes much less, but I never had this problem before. When I don't have Munt installed, or have ems=true/umb=false set, sometimes the game save is just lost, but with Munt not installed, ems=false and umb-true, it will load the game save before I tried saving in that slot. My system specs are as follows:
System specs:
Windows XP SP3
DOSBox 0.74
512 MB RAM
P4, 1.4Ghz
NVidia GeForce (BFG Tech) 6200 AGP 256 MB
HDD 80GB
Santa Cruz DLS Synth (from mixer /listmidi in DOSBox)
I have included my current DOSBox cofig file, and a screenshot of the message generated when the game crashes. I don't know what else to provide, so if anyone needs more information, and knows what is the problem, I would deeply appreciate any help, and thank you in advance (and afterwards). I appreciate the time and trouble; I've been searching everywhere and haven't found a solution. Thank you!
Why do people always wait so long before they go to their gorilla?
