Reply 20360 of 53053, by luckybob
luckybob wrote:
and just think, all I wanted was the corsair ram dimms....
https://www.ebay.com/itm/202119853375
That box arrived and I was very disappointed with myself. Those dimms are 1GB. I have 2gb dimms. So now I STILL need to get 2x 2gb and NOW get 2x 1gb dimms. (because reasons)
The box itself was packed... OKAY. The seller literally just stuffed random memory into slots. I found RIMMS in the supermicro board that takes DDR3
I received:
Biostar A780L & athlon 64 x2 5400
Asus P5KC & P4@3.0GHz (SL7PU)
ECS K7S5A Pro & Amd 1700+
Supermicro C2SBX & C2D @2.2Ghz (SLA95) - missing heatsink, but I had a replacemen
Intel D975XBX & 3050 xeon (2.13GHz SL9TY)
The ram was all basic and non-descript save for the corsair and 4x 1gb ddr2-800 dimms in a nice red heatspreader. I now know that RIMMS fit into DDR3 slots. I hope like hell he just plugged them in and never tested them. Thank god the whole box of items only cost $25.
Couple of the boards will need a re-cap. I will likely do that and turn them to pay for other things. I find it quite therapeutic to solder things.
I also picked up a L2 cache card for the Macintosh 68040 series Quadra systems. (700,900,950) For those who are not familiar with Macs, the 68040 is comparable to the intel 486. In particular the Quadra 700 was the computers (in)famously on Jurassic Park. This card upgrades the computer from ZERO L2 cache to 128kb. Probably a decent upgrade.
https://imgur.com/a/YZMTV
Reply 20361 of 53053, by Ozzuneoj
probnot wrote:
Just came in the mail today. I'm looking forward to hearing these in person in my SB1.5 :D […]
Just came in the mail today. I'm looking forward to hearing these in person in my SB1.5 😁
ymvz0pQl.jpg?1
Awesome! I have an SB2.0 upgraded with the CMS chips and it is very cool! I hope to get it into a system soon so I can start using it more fully. 😀
Reply 20362 of 53053, by BSA Starfire
537.15 KiB
462.85 KiB
Tested and working according to seller, 386SX 33 motherboard/CPU,4mb RAM, Trident 9000 ISA VGA, Winbond IDE/FDD serial etc i/o card. £36 for the lot.
Reply 20363 of 53053, by meljor
@ Artex: Awesome 7950GT agp you scored there... I've got the 7800GS agp, 7900GS agp, 7800GS+ Bliss (24pp, 8vs version) but still did not locate the 7950GT, it should be even a tiny bit faster and indeed the fastest (Nvidia) agp card. It can not touch the Radeon HD4670 and HD3850 agp versions but for retro i like Nvidia better. Hope to also find it someday!
Do you also test all your hardware to see if it is working?
And what is so special about that 3200+ DKV4D cpu?
Reply 20364 of 53053, by martin939
I was stupid enough to sell my 3850 AGP DDR3 from Sapphire, duuhhhh no wonder it sold in like 30 minutes...
What I'm looking for ATM are TOTL ATI 9700/800's but they are quite rare.
I'm also looking at an X1950XT but do they all come with 256MB GDDR3?? I have an EAH X1900XT but it's 512MB.
Reply 20365 of 53053, by melbar
Athlon XP 3200+ (AXDA3200DKV4D)
Frequency: 2333 MHz
Bus speed: 333 MHz
Clock multiplier: 14
--> Not really common on ebay and other marketplaces...
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 20366 of 53053, by Deksor
Hey, I have that board ^^ but mine's dead unfortunately (thank to the varta battery 🙁)
Reply 20367 of 53053, by brostenen
Sweet... Congrats. 😀
For a new battery as a replacement for the Barrel type, I usually go for this solution.
https://www.ebay.com/itm/New-LIR2032-Li-ion-3 … 4MAAOSwpDdVGVUE
Reply 20368 of 53053, by Artex
melbar wrote:
Athlon XP 3200+ (AXDA3200DKV4D) Frequency: 2333 MHz Bus speed: 333 MHz Clock multiplier: 14 […]
Frequency: 2333 MHz
Bus speed: 333 MHz
^^ This! Thanks melbar. Fastest clocked Barton.
Reply 20369 of 53053, by Artex
Yep! I do have a test bench where I can quickly swap motherboards based on the generation of hardware I'm testing. I have some hard drives set up with different operating systems and just grab drivers as needed. I wish I had more TIME... 😀
Reply 20370 of 53053, by debs3759
I've been buying up motherboards lately to test my CPU and Graphics Card collections. I have boards for most PC generations from 486 and later, including Mini-ITX boards for some mobile sockets. Only thing I still need is 2GB or smaller IDE drives for 486 and earlier systems 😀 I will have at least 20 test systems when I get the right cases.
Reply 20371 of 53053, by brostenen
Socket3 heatsink with fan. NOS.
Reply 20372 of 53053, by Artex
Compact flash or SD cards work well for old systems.
Reply 20373 of 53053, by dirkmirk
Frequency: 2333 MHz
Bus speed: 333 MHz
Its SOOOOO bloody confusing the old Thoroughbred & Barton CPUS, did those overclock at 400mhz?
Reply 20374 of 53053, by melbar
It depends to the manufacturing date, that means if you can change the multiplier. If it fixed, i think it's too much for the core (14x200=2.8GHz).
If you can change the multiplier than you can set 12x200=2.4GHz.
Reply 20375 of 53053, by jaZz_KCS
Artex wrote:
Hah! Never noticed that but yeah! Here's the 6200 I have. :) http://imagizer.imageshack.us/v2/1024x768q90/922/Sqi2N4.jpg […]
FuzzyLogic wrote:
Apparantly the folks at XFX were into doggies on their boxes
Hah! Never noticed that but yeah! Here's the 6200 I have. 😀
Looks a little bit like a doggy version of Bowser on steroids.
Reply 20376 of 53053, by Kreshna Aryaguna Nurzaman
martin939 wrote:
This is the one I have, pretty much in mint condition (already gave it a good wash in soapy water) https://i.imgur.com/0zq7MIZ.j […]
So... is it okay to wash electronic boards with water?
Kreshna Aryaguna Nurzaman.
Reply 20377 of 53053, by meljor
No problem at all. Just make sure it dries up completely before running any current trough it.
Reply 20378 of 53053, by .legaCy
Yup as long as you leave it to dry really well and remove any power source(like batteries and stuff).
small boards after being dry on air (and shadow) i usually put them on a box with silica gel to get them really dry.
Reply 20379 of 53053, by Artex
Some recent pickups... The SCC-1A was a nice surprise as it was listed as a SCC-1. Upon closer inspection, it's the 1A variant with a few more instruments, and BOXED! Other than that, an odd-ball 3DFX Voodoo3 3000, some other 3DFX-related items including some stationary and one of the exit packets employees were given when they shut down.
I've started collecting some additional AMD boards including a KX133 Slot A board that was new in box, as well as the well-known and high-performing Abit NF7-S Rev. 2.0 which was one of the better boards back in the day, also new in box. I hope to use that new Barton in it.
On with the show!
3DFX Exit Packet 😢 😢 😢 😢 😢
3DFX Interactive MousePad (Old Logo)
3DFX Voodoo3 - 3DFX V3000-16 Rev. 1.0 16MB AGP (Boxed) (1999)
3DFX Voodoo Official Magazine Spring 1999
Abit NF7-S Version 2.0 NVIDIA Nforce2 Socket A ATX Motherboard (NOB) (2003)
Eagle JoinData Systems G486SLV Socket 3 with 256KB Cache (NOS) (1994)
EPoX EP-7KXA Via KX133 Slot A Motherboard (NIB) (2000)
Roland SCC-1A (Boxed) (1992)
Zalman CNPS 7000B-Cu LED CPU Cooler (NOS)
3DFX Voodoo2 - Quantum Obsidian2 90-2440 10MB PCI
3DFX Stationary
3DFX 'Take a Ride' Keychain
3DFX Matchbox
3DFX Voodoo5 6000 Case Badge
