catfromnesbox wrote:can you fix this game called ''scarface the world is yours'' ? the game worked fine in older windows.
iriyap wrote:Do you think you can make the following fixes for American McGee's Alice? ...
iriyap wrote:Maybe make the FMV's vert-, they seem to be some kind of widescreen.
SalaciousCrumb wrote:Could you fix a glitch in POP:WW and POP:T2T? Whenever I force AA through the NVIDIA Profile Inspector (be it OGSSAA, SGSSAA, TrSSAA etc.) the water effects stop rendering correctly. I've tried using different AA flags but to no avail. I'm pretty sure it has something to do with the game engine. This issue is not present in POP:SoT.
Here are some clips for reference:
https://www.youtube.com/watch?v=N2NXQwRR2YI
https://www.youtube.com/watch?v=PYtCxXYBX4s
cloudhaacker wrote:Hey Peixoto, I haven't been on for a while - just got a new laptop and am in the process of getting all my games installed. I was working on Onimusha Warlords, and I'm having the same issue as RaZziel94 on Page 5. When I run the game in my native resolution (1920 x 1080) the game window is itty bitty. Cutscenes will play bigger if I enable that in your app. I tried running my desktop all the way down to 640 x 480, and that almost works for fullscreen, but there's ghosting all around things that move. I did try to copy the whole game and everything into a Windows 7 Virtual machine I have, and it runs fine in there, albeit a little slow (and no controller then) so it's something with the way Windows 10 or my Nvidia Graphics are handling the Directx8 calls I assume. If I use Wine3d for windows dll files with just the game, that slows things down, but I don't get all the other benefits from your patch. So I'm willing to do an apitrace for you and I can post a video too if that helps to show what's happening, but I can't figure out how to get apitrace to work now, I used it before when I talked to you months ago, but I just downloaded the new version and I guess I'm lost. Can you give me a hint as to what to do? Thanks for all your hard work, this patch program is something very special, and I feel bad that all you get is people asking for help or asking for other games
. You are appreciated by many!
Peixotos's patch remote settings:
32bit: 1
d3d: 1
d3D_Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_d37ca5c2cde53609\nvldumd.dll
error_log: C:\Games\Heart of Darkness\Peixoto\error.log
frame: 1
hd: 1
injector_dir: C:\Games\Heart of Darkness\Peixoto
max_4x3_res: 1280x960
Mydocs: C:\Users\Lifell\Documents
os_version: 10.000000
resolutions_list: 640x480 720x480 720x576 800x600 1024x768 1152x864 1176x664 1280x720 1280x768 1280x800 1280x960 1280x1024 1360x768 1366x768 1600x900 1600x1024 1680x1050 1768x992 1920x1080 1440x900
script: scripts\HOD.ahk
script_hwnd: 0x130908
target: C:\Games\Heart Of Darkness\HODWin32.exe
target_dir: C:\Games\Heart Of Darkness
target_name: HODWin32.exe
upscale: 1
Desktop 1920x1080
Direct3D user mode driver implemented in C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_d37ca5c2cde53609\nvldumd.dll
OpenAdapter Hook 0
DirectDrawCreate Hook: 0
Succeeded to create DirectDraw
Succeeded to create Direct3D
Succeeded to hook IDirectDraw2::CreateSurface
Succeeded to hook IDirectDraw::CreateSurface
Succeeded to hook IDirectDrawSurface::restore
Succeeded to hook IDirect3DDevice::EndScene
Succeeded to hook IDirectDraw::EnumDisplayModes
Succeeded to hook IDirectDraw::SetDisplayMode
Succeeded to hook IDirectDraw2::SetDisplayMode
Succeeded to hook IDirect3DDevice::Execute
Succeeded to hook IDirect3DDevice::CreateMatrix
Succeeded to hook IDirect3DViewport::SetViewPort
Succeeded to hook IDirect3DViewport::Clear
Succeeded to hook IDirectDraw::GetDisplayMode
Succeeded to hook IDirectDrawSurface::QueryInterface
Succeeded to hook IDirectDrawSurface::GetPixelFormat
Succeeded to hook IDirectDrawSurface::GetSurfaceDesc
Succeeded to hook IDirectDrawSurface::GetDC
Succeeded to hook IDirectDrawSurface::ReleaseDC
Succeeded to hook IDirectDrawSurface::SetPalette
Succeeded to hook IDirectDrawPalette::SetEntries
Succeeded to hook IDirectDrawPalette::GetEntries
Succeeded to hook IDirectDraw::SetCooperativeLevel
Succeeded to hook IDirectDraw2::SetCooperativeLevel
Succeeded to hook IDirectDrawSurface2::flip
Succeeded to hook IDirectDrawSurface2::blt
Succeeded to hook IDirectDrawSurface2::GetAttachedSurface
of coursemissperkins wrote:Are these patches easy to install? I'd like to install the resident evil 2 patch.
Lifell wrote:Hello!
Thanks for your work. I have however an issue with running Heart of Darkness with this patch. Running the game normally works.
- Code: Select all
32bit: 1
d3d: 1
frame: 1
hd: 1
upscale: 1
Desktop 1920x1080
OpenAdapter Hook 0
This is what the error.log gives me.
My steps:
1. Install game from disk.
2. Set everything to run as administrator in the compatibility settings (right click on .exe > properties > compatibility tab)
3. Download .zip file (this patch).
4. Unblock the zip in properties (right click on .zip > properties > check unblock > apply > ok)
5. Extract to C:\Games\Heart of Darkness\Peixoto (I tried C:\Games\Heart of Darkness as well)
6. Set every .exe in Peixoto folder to run as Administrator
7. Open "Help.exe". Set both options on and click start. I also tried to uncheck "Enable Upscaling".
So I run the shortcut on my desktop or I press start. It shows a command prompt window with the text above and exits after the line "Succeeded to hook IDirectDrawSurface2::GetAttachedSurface". Nothing happens. Event viewer is not showing anything regarding crashing or what not.
My OS is Windows 10 64 bit. I don't know if it matters but it never asked for the folder where Heart of Darkness is installed. Also, in the NVIDIA Control Panel I've set it to not do any scaling.
David_OSU wrote:Thanks Peixoto for sharing these patches with the community. I applied your patch to Tomb Raider 2 along with the high resolution textures (from IOS) and the remastered cutscenes. Game looks much better now.
Peixoto wrote:Lifell wrote:Hello!
*snip*
Sorry for the late response
Can you double check if you don't have a wrapper like dgvoodo installed in the game's directory ?
The is a new version coming soon with some improvements in the emulation of 8 bit color mode, it might solve your problem
Return to Release Announcements
