debs3759 wrote:derSammler wrote:Just bought a lot of 90 ISA/PCI/AGP cards.
Pictures, or it didn't happen
jheronimus wrote:Unfortunately, when I brought it home and turned it on, the screen showed its biggest issue — the tube was really worn out. The image is incredibly dark, just look at this DOOM screenshot, brightness and contrast at max:
derSammler wrote:jheronimus wrote:Unfortunately, when I brought it home and turned it on, the screen showed its biggest issue — the tube was really worn out. The image is incredibly dark, just look at this DOOM screenshot, brightness and contrast at max:
Did you try lowering contrast? Contrast makes dark parts even darker and bright parts brighter. It's not a good idea to increase contrast if you want a brighter picture.
derSammler wrote:debs3759 wrote:derSammler wrote:Just bought a lot of 90 ISA/PCI/AGP cards.
One of the seller's pictures:
More when I've got those.
derSammler wrote:Did you try lowering contrast? Contrast makes dark parts even darker and bright parts brighter. It's not a good idea to increase contrast if you want a brighter picture.
The will also be a brightness adjustment on the flyback if you open up the monitor.
Some of the older ones even had holes in the case so the use could adjust the focus and brightness without opening up the monitor.
Munx wrote:Anaxagoras wrote:Hi,
I bought this graphics card, NVIDIA 7950GT AGP version.
I think that this graphics card are one of the last sold for AGP bus.
It works very well in my Pentium 4 and there are a lot of difference with the previous installed card, a NVIDIA GeForce 6200.
Doom 3, Quake 4 and Painkiller waits me!!!
That's the raddest, most tubular card I've ever seen!
furan wrote:Here's that keyboard next to the monitor and mouse. Really ties the room together.
Ozzuneoj wrote:What do you think?
Ozzuneoj wrote:5.jpg
Ozzuneoj wrote:http://www.vogons.org/viewtopic.php?f=46&t=17341&p=632994#p632994
Users browsing this forum: daveculp, Google [Bot], rasz_pl, tensi0n, Thermalwrong and 12 guests
