dgVoodoo 2 for DirectX 11
General information and assistance with dgVoodoo.
Re: dgVoodoo 2 for DirectX 11
Postby Waltc » 2017-12-02 @ 23:42
ZellSF wrote:Direct3D is Windows only. It is not available in the DOS version of Lands of Lore II at all.
It is available on the Windows version, which GoG does not provide, and it looks pretty much the same as the Glide renderer.
Thanks for the clarification...I didn't think I was going bonkers...;) I knew my DOS version of the game had never supported D3d hardware acceleration. So Willow must have the Windows version--IIRC, he said he had the DOS version, which threw us off...Thanks again.
I finally coaxed the Glide wrapper ON, again, long enough to take a screen shot--here's the Hardware accelerated page when Glide is functioning long enough to grab it...;)
User avatar
Waltc
Postby willow » 2017-12-03 @ 08:35
Waltc wrote:
willow wrote:I have 3d acceleration with glide and whith direct3d (bilinear filtering is ony available with 3d acceleration). Graphics are similar and it's normal because with the last patch of LoL, it's the standard comportment.
I'm not sure if you understand, quite yet, so I've included some screen shots. Main Menu shows you it is DOS 1.30--GOG version. Options Menu shows you what it looks like when GLIDE acceleration is not available--note that "Hardware acceleration" is grayed out. BiLinear filtering only shows up when Hardware acceleration is turned ON--in the absence of GLIDE acceleration, BiLinear is not available in my version of the game. THe "Video Controls" menu shows the full gamut of D3d options available--D3d software options, note. When Glide acceleration is enabled then all of these options are grayed out with the exception of bi-linear filtering which is then visible and selectable. Last is my D3d diag page to show you that D3d is enabled on my system. As I mentioned I also have D3d hardware accelerated games from that time which run accelerated fine.
Now, *if you and I have the same version* of the game then you are running the Glide emulation when the option for bilinear filtering shows up shows up. If we are not running the same version--somehow--then I'd like to know where to get a patch more recent than the 1.30 DOS version of the game....;)
Again, I'm of the opinion that this is caused by something Microsoft has done in these latest builds that is somehow interfering with both DG Voodoo2 and nGlide--because both wrappers functioned fine in earlier Win10x64 builds. If you'll read some of the earlier posts in the thread--this is what they are talking about. I was only hoping that someone could offer some advice. I can play the game all day long in D3d software mode--it just doesn't look near as nice as played hardware accelerated through the GLIDE wrapper.
I think you don't have understanded.
Did you think that I speak about direct3d with a dos version? It's very strange.
Direct3d version is not available with dos version but only win95 version. The last win95 version is 1.30 and include dos version.
When I speak about glide, it on dos version (win95 don't have glide) and about direct3d it's on win95 version. It's logicial because there is no d3d acceleration in dos version.
willow
Postby willow » 2017-12-03 @ 08:37
I have spoken about win95 version.
willow wrote:Have you tried directx version?
LoL2 have a win95 directx version.
i have tried and it works with win10 fall update. Only CGI are jerky.
willow
Postby lowenz » 2017-12-03 @ 18:52
*tears of nostalgia*
Got Nightmare Creatures (1.2a) working with dgVoodoo2.
lowenz
Postby lowenz » 2017-12-03 @ 19:15
ZellSF wrote:Nightmare Creatures works perfectly. Resolution forcing works too, but the game natively supports high resolution anyway. Though you probably need dgVoodoo2 to make that work anyway (without dgVoodoo2 it only reports 0x0 as the only available resolution).
Question 1: can you use the default movement keys (I can't :| ) or rebind them somehow?
Question 2: can you use the the mouse somehow?
It's a brilliant game for.....20 years ago (!?!?!?!?)
lowenz
Postby ZellSF » 2017-12-03 @ 21:28
Keyboard controls work fine, mouse does nothing.
ZellSF
Postby lowenz » 2017-12-03 @ 21:33
The keys I rebind in the menu work for me too.
But for the movement?
lowenz
Postby ZellSF » 2017-12-04 @ 01:03
lowenz wrote:
ZellSF wrote:
lowenz wrote:Question 1: can you use the default movement keys (I can't :| ) or rebind them somehow?
Arrow keys work fine for movement here.
willow wrote:
ZellSF wrote:You can fix jerky CGI with some compatibility flags. I can never remember which though.
Do you know how modify compatibility flags?
Easy way is to just right click the exe, properties than compatibility and then run this program in compatibility mode for Windows 98... Unfortunately, that might introduce more problems, so if possible you want to install Application Compatibility Tools from the ADK: https://developer.microsoft.com/en-us/w ... oyment-kit or Microsoft Application Compatibility Toolkit 5.6 if you're on Windows 7: https://www.microsoft.com/en-us/downloa ... px?id=7352
Then you want to run Compatibility Administrator (32-bit), right click on "New Database(1) [Untitled_1]", rename it to something, then right click again "create new > application fix", fill in the three fields, click next two times, you'll find a list, you want to only check "Win98VersionLie", then next and finish. Now click "File > Save as", save the database somewhere, then click "File > Install".
I'm guessing the game starts on a code path intended for NT OSes if it doesn't detect 95/98 :-S
ZellSF
Postby Myloch » 2017-12-04 @ 17:16
Please kindly keep the splinter cell series bugs out of the general topic, there's a specific topic for them.
"Gamer & collector for passion, I firmly believe in the preservation and the diffusion of old/rare software, against all personal egoisms"
User avatar
Myloch
Postby gameragodzilla » 2017-12-04 @ 17:20
Myloch wrote:Please kindly keep the splinter cell series bugs out of the general topic, there's a specific topic for them.
Oh sorry. Will do.
gameragodzilla
Postby ZellSF » 2017-12-05 @ 19:57
Gunners Heart, a SkyGunner inspired game works great with resolution forcing (minor text artifacts). By default it's a 640x480 only game.
Myth: The Fallen Lords' 3DFX render works, some artifacts with resolution forcing. No widescreen, which is only available in the unofficial OpenGL renderer.
Myth II: Soulblighter's Direct3D render also works great (on the latest unofficial patch, haven't tested unpatched), maybe a bit weird to use considering the game has updated Direct3D11 and OpenGL renders available, but neither of those has any sort of UI scaling.
Recoil works with resolution forcing (usually limited to 1024x768) with both 3DFX and Direct3D renders. Screenshot is Direct3D.
I said earlier Metal Fatigue still didn't work. That wasn't true, it has worked since 2.51. I just didn't retest with the ATI Radeon virtual GPU. It works with resolution forcing, but has some glitches in borders. It can probably be fixed by a post-processing shading (some Reshade shader that colors everything black + UI mask). Also the game seems to handle widescreen nicely despite not offering it in its options (I had to change 1600x1200 to 1280x720 in DirectXRendEng.dll). FMVs and menus are stretched, but gameplay is perfect.
ZellSF
Postby AlphaPapa » 2017-12-07 @ 01:53
Chrome and Firefox think that the latest version 2.54 is a virus.
I am working on getting Episode I racer working but I just keep crashing at the first blue loading bar. Anybody have any tips?
I have tried with the fast video memory access checked which previous posts indicate. and toggled a few other items.
I have had it working with dxwnd before but would prefer Dgvoodoo2.
Thanks for the hard work you do Dege
EDITED for detail
AlphaPapa
Postby Dege » 2017-12-07 @ 09:55
Try to increase the amount of emulated VRAM. Such crashes are typical when games run out of that.
Dege
Postby brad86 » 2017-12-07 @ 14:57
Hi guys.
I'm having an issue with dgVoodoo with Tomb Raider 2-5.
All games present some kind of texture noise a few ft in to the distance. Playing with the settings in both the games setups or dgVoodoo doesn't fix this. Even supersampling has no affect.
I'm trying to get a consistent, clean high resolution look with all Tomb Raiders, and this is the only thing getting in the way.
Tomb Raider 1 with TombAti has no such issue.
Images do not show the problem, so I captured a short 10 second video. Look at mansion bricks and path ahead and you can see what I'm talking about.
https://streamable.com/5mqa0
User avatar
brad86
Postby Dege » 2017-12-07 @ 15:55
You don't have bilinear texture filtering enabled, that's why it's noisy.
But even with that enabled, it can be still noisy a bit in case of lacking texture mipmapping.
Dege
Postby brad86 » 2017-12-07 @ 16:13
Dege wrote:You don't have bilinear texture filtering enabled, that's why it's noisy.
Bilinear filtering in dgVoodoo or Tomb Raider setup makes no difference from what I can see.
I really don't like filtering textures (blurring) anyway.
Is there no way I can resolve this?
Tomb Raider 1 with TombAti for instance looks fantastic with SSAA and no bilinear.
User avatar
brad86
Postby AlphaPapa » 2017-12-08 @ 02:36
SW EP I Racer:
Thanks for the tip Dege. I was trying with the max amount (gtx 970). maybe a smaller amount. i think the requirement back in the day was 2mb!
Got it running on my xp machine with the smaller exe from lucas ftp dump(viewtopic.php?f=8&t=39154&start=20) and have tried with those cleanly installed files back on Win10 x64 but no luck. Is there a way to do logging that I can provide for you?
AlphaPapa
Postby ZellSF » 2017-12-08 @ 21:09
Lode Runner 2 was apparently fixed between 2.53 and 2.54.
Mega Man Legends.. always worked? Why did I think this was broken? Supports resolution forcing too:
Outwars works fine, but mouse cursor is broken in menus in any "emulated" modes. Maybe worth navigating the menus with keyboard for resolution forcing though, the game is limited to 640x480 so there's quite an improvement:
Dark Vengeance works. Resolution forcing too (usually limited to 1600x1200 with bad UI scaling).
Asghan: The Dragon Slayer's Direct3D render works fine too. I can't get the game to actually work well on Windows 10 at all though and wouldn't really recommend anyone try. Looks nice though:
Typing of the Dead still shows just a black screen. Interesting log?:
totd.LOG
(149.49 KiB) Downloaded 8 times
ZellSF
Postby ZellSF » 2017-12-10 @ 12:28
Might and Magic IX works perfectly, maybe no surprise seeing as it's LithTech. Usually 800x600 only, changing resolution breaks the UI. Not with dgVoodoo2's resolution forcing, but poor texture filtering (forcing looks bad) means it's not going to look great anyway. Non-emulated modes didn't actually work for me, the window would just lose focus.
Only mention of Ghost Recon here said it only gave a black screen. Not in the latest version and resolution forcing works fine too (game has bad UI scaling).
Wizardry 8's Direct3D7 render works fine too. No advantages to running it in dgVoodoo2 though.
ZellSF
Postby lowenz » 2017-12-10 @ 16:50
Is there a way to force via dgVoodoo2 the windowed mode for Jedi Knight - Dark Forces 2 and Mysteries of the Sith?
Not the menu GUI, ALL the actual game.
I can't find a way :/
lowenz
PreviousNext
Return to dgVoodoo General
Who is online
