First post, by infiniteclouds
I just got a Tseng Labs ET3000AX VGA/EGA card and popped in in my Slot 1 Gigabyte board and while I get an image for BIOS once it loads into DOS there is no image. This motherboard's BIOS has a setting to switch between PCI or AGP VGA at boot.... but not for ISA -- is this the problem? Or do I need to set a certain IRQ to LEGACY ? My board is a 6BXC. There are several dip switches on the card as well but I can't find documentation on them.
Thanks in advance for your suggestions!
