First post, by vglover2005
Hello, I am using Glidos for Carmageddon because I was having trouble running it in Hi-Res mode. Now I know My video card does fully support OpenGL which Glidos calls for and the drivers are updated. But when it said I needed to install the 3DFX Patch for Carmageddon, doesn't that require a 3D Graphics Accelerator that is supported by Carmageddon such as Voodoo?
When I run the patch, and have the Glidos Server running, it does start, but it says it's running in 640X480 mode, but I set it to 1024X788.
Does the Windows95 version support Hi-Res, and would the only way to get Hi-Res suppose would be to buy a Voodoo video card?
I have a Radeon 9800 PRO 128MB, and a 3.0Ghz computer.
Thank You.
