First post, by emendelson
About a year ago, I put together a lot of work by Dominus and made a single build script for DOSBox SVN under macOS:
https://github.com/emendelson/OneStopDOSBoxOSX
I tried using it under High Sierra (with my existing build environment), and it produced this error from the make command:
Making all in serialport nullmodem.cpp:151:21: error: ordered comparison between pointer and zero ('TCPClientSocket *' and […]
('TCPClientSocket *' and 'int')
setCD(clientsocket > 0); // CD on if connection established
1 error generated.
make[4]: *** [nullmodem.o] Error 1
make[4]: *** Waiting for unfinished jobs....
make[3]: *** [all-recursive] Error 1
make[2]: *** [all-recursive] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
-e **Error** line #597 : make failed.
Is this error the result of my ignorance (very likely), or has something changed in SVN that would cause this problem in macOS?
Any insights gratefully received.
