Reply 20801 of 52884, by TheAbandonwareGuy
derSammler wrote:
Got those today. Only three really interesting boards: a Slot 1, a Turbo XT (complete with RAM, CPU, and FPU), and a 286 with He […]
derSammler wrote:
Oh my, now I also bought a lot of 20 main boards incl. an XT one. 🤣
Got those today. Only three really interesting boards: a Slot 1, a Turbo XT (complete with RAM, CPU, and FPU), and a 286 with Headland chipset and 16 MHz CPU. Also two 386 boards, but both damaged by battery. Will take CPU, FPU, and SRAM chips from those and toss them. They are beyond repair.
Rest is modern crap. May keep some of the modern ones still.
So this is what I scored lately for not even 100 bucks:
Don't just throw away stuff because its too new for you. Today's modern is tomorrow's retro.
Reply 20803 of 52884, by TheAbandonwareGuy
derSammler wrote:
Where did I say that I throw away any of the modern stuff? Not keeping it is not throwing away.
Sorry. I had just made an assumption. I know alot of members here don't like dealing with actually selling stuff (for understandable reasons)
Reply 20804 of 52884, by kixs
386_junkie wrote:
kixs wrote:
Managed to find 😲
Hope it works as it was sold as untested.
You sir are the only other person I know to have one of these... we ourselves are in a very small but exclusive club together... 🤣
This is quite a surprise. Didn't know it was so rare 😲
Reply 20805 of 52884, by amadeus777999
Got my first GA-486AM/S and put it through its paces. I used the standard Am486-40/160mhz combo with all settings max and it scored 1150 rtics in Doom shareware - 64fps+ which secures it the third place among the fastest 486s in Doom(at least according to the "Doom benchmark results" site).
50mhz with all settings max runs great but under 60/66 the board stops after "Starting PcDos"... no matter what. It's equipped with a Riva128 and a SBLive! 4830(if I remember correctly) which plays back sfx-samples fine but the Wavetable functionality is compromised.
Still better though than in the Hot433 where the card hang when midi was enabled. Most likely a PCI issue which does not occur when an older VGA card is installed along it instead of a newer one.
    1.77 MiB
    1.54 MiB
Reply 20806 of 52884, by 386_junkie
Very!
I never thought I'd see another one... i'm glad you found. Let me know if it works and everything is ok with.
Reply 20807 of 52884, by bjwil1991
Here's my video about the two Dell laptops I have: https://youtu.be/X6Z9sknthyk
Reply 20808 of 52884, by bjwil1991
Bought some games today:
I also bought an external IDE HDD enclosure (USB) and optical drive enclosure (FireWire), and a Netgear Play2TV PTV1000 (Intel GPU PCs only).
Reply 20809 of 52884, by sf78
More goodies from the hoarders house.
292.37 KiB
416.07 KiB
451.16 KiB
Reply 20811 of 52884, by sf78
Also this (among many other things). Man, I really really hope it works. It was on a top shelf with a bunch of saw dust and other crap on top of it and more falling from the ceiling. 😵
153.45 KiB
Reply 20813 of 52884, by martin939
Clean it up first before turning it on! You never know what's inside, it's HV so it might short pretty easily and make the thing FUBAR.
Reply 20814 of 52884, by sf78
Well, the 5154 kinda worked. The horizontal sync seems off as the text judders and is unreadable. It probably needs new caps to fix it. On the other hand, all the other screens and PC's in the lot (Canon A-200, 5151 and 386/486) worked just fine. This AT model keyboard was also there, as well as a brand new mini tower with a PSU. 😊
edit: Oh, and those are just (Scandinavian key) stickers on the keys. The hats are not THAT worn out.
183.49 KiB
179.03 KiB
Reply 20815 of 52884, by easy_john
PowerVR based 3d accelerator
2.86 MiB
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 20817 of 52884, by Formulator
Excellent find, the day I found one I got the magic smoke from a blown line suppression capacitor. I even remember the sound it made when it blew. Luckily it was an easy fix. You probably knew this but I learned after I got it that the middle knob can be pulled out to adjust contrast if need be.
Reply 20818 of 52884, by DeafPK
sf78 wrote:
Damn, I'd like to watch the unboxing of that AT case
"an occasional fart in their general direction would provide more than enough cooling" —PCBONEZ
Reply 20819 of 52884, by JidaiGeki
Some additions to my Microsoft collection. Only two of them contain hardware; WSS V1. 0, and WfW additional user pack.
    1.88 MiB
