*START HERE* SoftMPU 1.91 - Software Intelligent MPU-401 Emulator
Forum for discussion of bugs, code, and other aspects of SoftMPU.
Re: *START HERE* SoftMPU 1.9 - Software Intelligent MPU-401 Emulator
Postby dr.zeissler » 2017-12-16 @ 20:16
No ISA free :(
CPU: PII 133-333 MOBO: SNI-D981 RAM: 512- FDD: Dualfloppy 3,5"HD/5,25"HD - 3,5"HD - 5,25"DD ISA-Catweasel HDD: 2x40GB - DVD
ISA(3): Audician32-S2Dreamblaster - GusACE PCI(3): Monster3D- Intel NW AGP(1): Matrox G200 8MB
dr.zeissler
Postby Scali » 2017-12-16 @ 20:22
dr.zeissler wrote:Any chance to get this thing working on a 286 ? (probably not)
Not as-is, but perhaps it is possible to use the same trick we used for Tandy:
Patch 'out' instructions to 'int' instructions, so that an interrupt handler, installed by a TSR, will be called.
Downside is of course that every game will need its own patch in order to work, so it won't be a generic solution.
Scali
Postby TimMer1981 » 2017-12-19 @ 09:47
dr.zeissler wrote:No ISA free :(
Only option will be clearing an ISA slot then, otherwise no luck. :depressed:
Are all the ISA cards really crucial? Most 286s have multiple or even just ISA slots, no?
"I will take your bones, still alive and in great pain, and make them into a chair. I will call it "My Screaming Chair". Every morning I will sit in it and listen to you scream. Any questions?"
User avatar
TimMer1981
Postby dr.zeissler » 2017-12-19 @ 11:11
Amiga Brideboard. VGA/LAN/HDD/SOUND, so no way :(
3x 16Bit ISA available (normally 1x16+2x8; but Board is extended to 3x16)
Current configuration:
1. VGA ET4000
2. SC1630 Formosa (ESS/SBPRO/MPU401)+primery IDE-Interface with CF-Card and Ontrak Diskmanager
3. EtherlinkIII
I really need VGA, otherwise emulated MDA/CGA is no option for me.
I really need Sound and HDD, no LPT-Option for the amiga-side here.
I really need LAN otherwise I'll have to copy the files with Disks :(
dr.zeissler
Postby TimMer1981 » 2017-12-21 @ 02:02
So, sadly for the 286 lovers here, that's a definite "No" on SoftMPU. Only HardMPU (or ofcourse a genuine classic MPU-401 card), given there's an ISA slot to spare.
User avatar
TimMer1981
Postby timitt » 2017-12-28 @ 19:57
bjt wrote:
lazygamereviews wrote:I'd be happy to try a patched version! Would bypassing the RTC check affect functionality much?
No, it will still use the RTC. Not really sure why the check is failing on your Compaq (could your copy of SoftMPU be corrupt?) but here's a patched version anyway.
Just noticed that I have the same problem with RTC check. This computer is Compaq Prolinea 4/25s. Seems that patched version (without check) works for me too. Maybe the official version could have flag to skip the check for our special needs Compaqs :D
User avatar
timitt
Postby TimMer1981 » 2018-1-03 @ 14:51
Question out of interest / wanting to learn: what would be the maximum recommended clockspeed of a pure DOS 6.22 machine using a MT-32 and SC-55 together with SoftMPU?
I've got a AMD K6-2 400MHz running at stock speed, is 400MHz okay for DOS games and the MT-32, SC-55 and SoftMPU? Or is downclocking a wise choice?
User avatar
TimMer1981
Postby dJOS » 2018-1-05 @ 02:01
TimMer1981 wrote:Question out of interest / wanting to learn: what would be the maximum recommended clockspeed of a pure DOS 6.22 machine using a MT-32 and SC-55 together with SoftMPU?
I clocked my K6-3+ Down to 200 mhz which seems to provide awesome compatibility - I have an AWE64 and the Yamaha OPL3 board many folks have and run midi via the onboard port for both without issues via SoftMPU (i leave it running even for games that don't need it). I don't run both cards at the same time, I swap them out depending on the games I'm playing - I can also run my CPU up to 500 mhz without issue of I want to run something more demanding. I also take out the S3 Virge and swap in a GeForce 6200 for quake 3D etc.
The impossible often has a kind of integrity which the merely improbable lacks.
dJOS
Postby TimMer1981 » 2018-1-05 @ 14:04
Have you noticed differences between 500 and 200 regarding compatibility?
No possibility of running them together, using different settings? I've got a AWE32 (ISA) running next to a Aureal Vortex 2 (PCI). I use the AWE32 for speech, samples and the Waveblaster option and I use the Vortex 2 for the MPU-401 interface.
Seems like quite a hassle; isn't the 6200 capable of doing decent 2D work?
User avatar
TimMer1981
Postby dJOS » 2018-1-05 @ 22:10
Tbh I haven't found anything specific that didn't work at 500 but I figure the chip will last longer under clocked too.
both sound cards are ISA cards and one of my 2 slots is a dud so that's the main reason.
I found a bunch of games like the Sierra quest games don't like the 6200 which is a shame because it'd be easier to just use it and put the Virge away.
dJOS
Postby bjt » 2018-1-09 @ 13:40
timitt wrote:Just noticed that I have the same problem with RTC check. This computer is Compaq Prolinea 4/25s. Seems that patched version (without check) works for me too. Maybe the official version could have flag to skip the check for our special needs Compaqs :D
Thanks for the report. I'm planning to remove this check as it's pretty redundant anyway.
User avatar
bjt
Postby timitt » 2018-1-11 @ 17:56
Much more thanks for the software. It works like a charm (the version that don't have the check). I don' need to get real MPU-401 card and can use all my ISA-slots for other use (LAN, GUS MAX and OPL3sax-card).
User avatar
timitt
Postby bjt » 2018-1-11 @ 23:40
timitt wrote:I don' need to get real MPU-401 card and can use all my ISA-slots for other use (LAN, GUS MAX and OPL3sax-card).
Glad it's useful for you 8)
User avatar
bjt
Re: *START HERE* SoftMPU 1.91 - Software Intelligent MPU-401 Emulator
Postby bjt » 2018-1-21 @ 20:45
New release out now - please see the first post for details.
Other than the major fixes mentioned, this release removes the requirement to specify a Sound Blaster address and interrupt in MPU-401 mode. If a Sound Blaster isn't specified, SoftMPU will run in non-interrupt mode, and game compatibility will be reduced accordingly. This is intended for use with UART-only MPUs in situations where a Sound Blaster may not be available, for example with PCMCIA or LPC MPUs.
User avatar
bjt
Postby Scali » 2018-1-22 @ 10:26
I tried running Ecargxus by The Phoney Coders: http://www.pouet.net/prod.php?which=4248
I used the new DreamBlaster S2P fork, which also runs without interrupts. I didn't get any sound, so I guess this demo requires interrupts?
Would it be very difficult to add interrupt support for all devices? Firing a software interrupt shouldn't be too difficult, so I suppose it's only about getting it to fire at the right time? The state machine for the irq generation should already be in the DOSBox code.
Scali
Postby bjt » 2018-1-22 @ 11:40
Yes, it requires interrupts.
Not sure if triggering the interrupts from software would work. There might be a problem if the game's ISR sends a non-specific EOI to the 8259.
User avatar
bjt
Postby Scali » 2018-1-22 @ 12:09
bjt wrote:Not sure if triggering the interrupts from software would work. There might be a problem if the game's ISR sends a non-specific EOI to the 8259.
Hum yes, in some cases that may be an issue...
Of course one could also virtualize that port, but I'm not sure how far you'd have to go.
If it's just a case of filtering out EOIs when you are inside the software-triggered interrupt, it's not too difficult. You'd just get this:
Code: Select all
cli
intTriggered = true;
int 0Ah
intTriggered = false;
sti
if (!intTriggered)
  out 20h, al
But the problem may be that during the handling of int 0Ah, they enable interrupts again, and an actual hardware interrupt is triggered.
That could also be solved in theory, by checking the PIC state to see if any interrupts are active (you'd probably want to store the old interrupt state at the time you set intTriggered = true, because a hardware interrupt may already be active, just masked).
So then you'd get:
Code: Select all
if (!intTriggered || intActive)
  out 20h, al
Hum, well, it may be an even bigger can of worms than this...
Mind you, I think 99% of the time you'll get lucky, and just letting extra EOIs through shouldn't be an issue in most cases.
Scali
Previous
Return to SoftMPU
Who is online
Users browsing this forum: No registered users and 0 guests
