First post, by 386SX
I'd like to ask some questions about Pentium 4/D/Duo chipset cause I don't understand some things. I'm trying a P4M800 ECS mainboard that supports up to Pentium D Socket 775 cpu with DDR2 memories and AGP 3.0. I thought this was almost the most modern AGP solution but than I've seen the Intel 865G chipset supported the Core 2 Duo cpu still with AGP 3.0 but DDR1. Why? Newer cpu with older memories?
Which was the best AGP Intel based newer mobo/chipset? And what about the Pentium D, which was the best chipset and mobo supporting it?
Thank
Reply 1 of 8, by Auzner
It was a transitional period. When Prescott came out there were both socket 478 and LGA 775 versions. You'd find any combo of 478/775 DDR1/DDR2 & AGP/PCIe boards from that era. Intel chipsets are probably better than VIA's, like the 865PE.
https://en.wikipedia.org/wiki/List_of_Intel_c … tium_4_chipsets
https://www.viatech.com/en/silicon/legacy/chi … ets/p4m800-pro/
https://en.wikipedia.org/wiki/List_of_I ... _(90_nm)_2
Reply 2 of 8, by martin939
Asrock is well known for such Franken-boards. Maybe they have something newer for AGP/DDR1/Core2Duo.
This one has both AGP, PCI-E, DDR1 and 2.
I wouldn't use any higher end Core2Quad's or big Prescott's on it though, the VRM's are weak.
Reply 3 of 8, by Auzner
I recall dual PCIe/AGP boards of that time having AGP tied off the PCI bus and being very bandwidth limited as such--bad choices generally. Best to pick one or the other.
https://en.wikipedia.org/wiki/Accelerated_Gra … based_AGP_ports
Reply 4 of 8, by Srandista
Best Intel AMD chipset would be 865PE, at least for me. This chipset was bring from Socket 478, and they just change Socket for 775, no other changes was made to chipset. Proper new chipset for Socket 775 was 9xx series.
ASRock did made few Frankenstein/transition board with VIA/Ali chipsets, I do own one, 4CoreDual-SATA2 (Socket 775, DDR1 and DDR2, AGP and PCIe (limited to 4x), SATA and PATA). Not the best board under sun, but supports almost all but FSB1333 Socket 775 CPUs, and its fully compatible with Windows 98, 2000, XP, even Vista and 7.
Reply 5 of 8, by agent_x007
My FSB 1600MHz friend has something to show about that statement... 😁
737.85 KiB
@OP In the old days (Pre Nehalem for Intel) ALL bus support (together with IMC) - was Northbridge "thing".
That's why, you can have a QX9770 CPU with DDR1 memory and AGP GPU.
Reply 6 of 8, by Srandista
agent_x007 wrote:
Srandista wrote:
Not the best board under sun, but officially supports almost all but FSB1333 Socket 775 CPUs, and its fully compatible with Windows 98, 2000, XP, even Vista and 7.
Fixed 😉
Reply 7 of 8, by Auzner
What kind of video card are you using, agent? It looks like AGP bandwidth is fine in that board: https://www.anandtech.com/show/1974/8
I would say you have the most modern AGP board then, so long as the card is a chip compatible with that motherboard. Like the wiki says, that can be an issue.
It is a bit era-weird to have that CPU with DDR1 and AGP though. But that makes it more fun 😜
Reply 8 of 8, by agent_x007
Actually there is a board which supports Phenom II x4, BUT it doesn't like anything newer than XP (nForce 3 FTW 😀).
As for GPU... I used with it most of the ones worth mentioning :
27.62 KiB
25.74 KiB
26.7 KiB
Because what is the point of having all this hardware than to test it 😉
966.04 KiB
^Out of all that hardware, the most problems I had with Radeon 8500 (top right corner) [old 3DMarks coudn't complete some tests, otherwise - GPU worked fine].
