Re: What retro activity did you get up to today?
Postby Ozzuneoj » 2018-1-01 @ 17:25
derSammler wrote:Finished something I started quite a while ago: An ESS 1688 soundcard with Dreamblaster S1 and 128 MB DOM on primary IDE. Boots right into MS-DOS 6.22 with the sound card already set up. Perfect for a bridge-board Amiga or to quickly test a mainboard without having to attach floppy, harddisk, etc.
Wow, that's awesome! I'll be honest, I've never even heard of a DOM before.
How does this work exactly? I didn't know that sound cards with IDE interfaces were actually bootable.
Time Machine = FIC PA-2013 2.1 - K6-2 500 - 256MB PC-100 - TNT2 Pro 16MB AGP - Labway Yamaha YMF719-E - Midiman MM401
Amibay For Sale Threads
I have lots of PC stuff for sale on Mercari! Get a $10 sign up credit with invite code VBGQMM.
User avatar
Ozzuneoj
Postby derSammler » 2018-1-01 @ 17:29
That card, a Formosa 1630 (aka "Audio Star 16"), is one of very few cards whose IDE port can be configured to primary. Since it's non-PnP, even a 286 can then boot from it (which was my test system -> works great!).
Finding the DOM was rather hard, as that construction form is quite unusual. But I wanted exactly that form so that it does not block or collide with an ISA card next to it. Had to import it from the US and paid quite a bit.
derSammler
Postby Ozzuneoj » 2018-1-01 @ 17:53
derSammler wrote:That card, a Formosa 1630 (aka "Audio Star 16"), is one of very few cards whose IDE port can be configured to primary. Since it's non-PnP, even a 286 can then boot from it (which was my test system -> works great!).
Very interesting. The DOM looks like one of these:
https://www.ebay.com/itm/New-128MB-Pret ... SwFnFWDFl5
Definitely looks handy! I wonder if there's a list anywhere of soundcards that have bootable primary IDE like yours.
I see a lot of them are 44pin female connectors. Must be kind of tough to find things that those will work on without weird adapters.
User avatar
Ozzuneoj
Postby liqmat » 2018-1-01 @ 17:57
bjwil1991 wrote:Had to re-install Windows 98SE a few times last night due to unforeseen cicrumstances with the ACPI BIOS driver causing issues (GPU conflicting with the ACPI BIOS driver for some reason), yet I cannot disable the ACPI in the BIOS since there is no option for the HP Pavilion 7955 (ASUS P4B-LA) motherboard BIOS.
I also attempted to create new profiles after re-installing Windows 98SE with no success mainly because I copied the files over to the appropriate profiles too early and forgot to reset the computer. Going to have to re-install Windows 98SE again when I get home by deleting the Windows directory entirely.
Some HP desktops allow you to go to the advanced BIOS settings by pressing Ctrl-F11 or Ctrl-Alt-F11 at post. Something like that anyway. Maybe you can access the ACPI that way? Worth a try.
User avatar
liqmat
Postby derSammler » 2018-1-01 @ 18:03
Ozzuneoj wrote:Very interesting. The DOM looks like one of these:
That seems to be the same, but I paid a bit more back then (+shipping). A standard DOM with 128 MB cost just 95 cents here in Germany.
derSammler
Postby derSammler » 2018-1-01 @ 20:05
Got the Neptune running. Looks like an XT when it boots. :D
Boot screen
RTC battery
The BIOS has some serious design flaws, it seems. After the reworked DALLAS was inserted, it kept asking for a password that wasn't even set. And the jumper for password on the mobo was set to "disable". After many resets, it stoped asking for a password. More funny, the BIOS keeps crashing when trying to enter it with the date not set. It also can not boot from hard disk in this case. So you need to boot from floppy first, set the date, and after that you can enter the BIOS and finally boot from hard disk.
It has the original BIOS from 10/94. Anyone knows if there is a newer BIOS available?
//edit:
Just found that last BIOS from late 1995. :)
derSammler
Postby bjwil1991 » 2018-1-01 @ 23:36
Disabled the ACPI BIOS after pressing the Ctrl-F11 key combo to get more options, and it did help somewhat. When I restart Windows, even if it freezes, I get a code 12 on the GPU stating it cannot get resources for some reason, and when I checked the resources, they're all correct and not conflicting with anything whatsoever.
The BIOS is version 3.05, which will be upgraded to 3.11 (HP OEM ASUS P4B-LA motherboard).
C64, WheelWriter 10 Series II QuietWriter 8, Pack-Mate 28 Plus, K6-2/300, Pavilion N3350, iMac G3 & G4, Socket 462, 2x Inspiron 600m, Athlon 64, Dimension 4550 & E510, ThinkPad R40, Presario C700, ASUS X54C, Raspberry Pi B+, 2B-3B+, Custom FX-6300
User avatar
bjwil1991
Postby Geforcefly » 2018-1-02 @ 04:40
Built a retro-ish machine featuring the following parts:
Abit TX5 v1.2
AMD K6-2 400 @ 410
128MB of RAM
40GB Samsung HDD capped to 32GB
Geforce FX 5200 PCI
Sound Blaster 16 ISA
16x/48x DVD/CD-ROM
3.5" floppy
Windows 98SE
BTW the Abit board works with a K6-3, and I've had it POST with a Rise MP6 266. This board works with everything.
DOS/Win3.1: Packard Bell 386SX-II | 386SX-20 + 387SX | 8MB RAM | 13.6GB HDD @ 502MB | TVGA8900C 1MB | SB16
Win98: Dell Dimension 4550 | P4 2.8 | 512MB DDR | 40GB HDD | Radeon 9600XT | SB PCI128
Geforcefly
Postby appiah4 » 2018-1-02 @ 12:09
Secured the purchase of a Diamond 3dfx Voodoo 2 8MB and a Creative Sound Blaster 16 CT2920 (This card is absent on Creative's own list of products funnily enough, it seems to be a PnP version of the CT2290, which is a fantastic SB16 if I may say so myself).
Now I am considering completely retooling my Slot 1 P3 system; it was a P3 450 (which was currently being upgraded to a P3 700) with a Voodoo 3, now I'm thinking of turning that P3 700 system into a GeForce DDR or GeForce 2 GTS + Voodoo 2 SLI setup. Worth it?
1989:A500|+512K|ACA500+|C1084S
1992:HIPPO-VL+|DX2-66|8M|GD5428|CT2290|S2
1995:PCI597-1|P133|32M|Trio64|V1|CT3980/2M
1998:S1573S|K6-2/400|64M|RagePro|V2/SLI|CT4500/32M
2001:GA-6OXT|PIII-1200|512M|GF3Ti200|MX300
2004:K8V-D|3700+|2G|X1950P|SB0350
User avatar
appiah4
Postby bjwil1991 » 2018-1-03 @ 04:00
Does anyone know how to get the Media vision Pro Audio Studio 16 to work in MS-DOS? I cannot seem to figure out what TSR program it is for voice and sfx.
User avatar
bjwil1991
Postby KCompRoom2000 » 2018-1-03 @ 04:38
I received a pack of 25mm heatsinks today, so I put a few of them on the Voodoo2 card in my Slotket build. In case you're wondering what I used to stick the heatsinks on, I cut up an 80mm thermal pad into three squares that match the size of each heatsink.
Now I don't have to worry about losing the card from heat issues.
1988-96:SL-54U5|P233MMX|64MB|Virge325|YMF719-S
1995-98:P2B-VE|C433|192MB|Rage Pro|Voodoo2|CT4500/32M
1998-01:GX150MT|PIII-S 1400|512MB|GF4Ti4200|SB0350
2000-05:A8V|A64 3700+|2GB|RadeonX800
User avatar
KCompRoom2000
Postby TheAbandonwareGuy » 2018-1-03 @ 05:33
Found a NEC Multisync FE770 at work today in the ridiculously sized crate of CRT monitors. Impressive picture quality. Its on the list of things awaiting approval for sale to me (its basically a done deal. Were just doing formalities at this point). There is also a 1994 17" CRT with fully detachable VGA (never seen that before on a non LCD). I didnt have time to test it as I do this off the clock after work and I don't want to stay here indefinitely....
Also: discussing buying retro computers by the pallet. I need to double time on buying that pre-built shed. Beat that @Artex
https://www.youtube.com/channel/UCuFY6Z ... 2tV8b00x_A
1996|P200MMX|64MB EDO|Virge DX 4MB|SB16 OPL3
1999|P3 933|384MB SDR|GF2 Ultra 64MB|CT4620
User avatar
TheAbandonwareGuy
Postby Cyrix200+ » 2018-1-03 @ 07:39
Found some games, transferred them to the 486SX and played them. Dangerous Dave is a hard game! Fascinating that I still know the levels after more than +-20 years.
Retro workhorse: Asus P2B-LS | Tualatin Celeron 1400MHz | Matrox G400
Image gallery
User avatar
Cyrix200+
Postby badmojo » 2018-1-03 @ 11:00
TheAbandonwareGuy wrote:Also: discussing buying retro computers by the pallet. I need to double time on buying that pre-built shed. Beat that @Artex
I’m pretty sure that a house full of rare, boxed, classic hardware beats a fantasy shed filled with “under discussion” pallets of used retro computers, but maybe I’m measuring it wrong.
If it's broke, then fix it!
User avatar
badmojo
Postby badmojo » 2018-1-03 @ 11:02
bjwil1991 wrote:Does anyone know how to get the Media vision Pro Audio Studio 16 to work in MS-DOS? I cannot seem to figure out what TSR program it is for voice and sfx.
In my experience you need the correct version of the drivers for your specific PAS16 but start with the installer package on Vogon Drivers. If that doesn’t work then try the Pro Audio Studio package you’ll find there too.
User avatar
badmojo
Postby TheAbandonwareGuy » 2018-1-04 @ 01:05
Under discussion just became done deal. There mine as soon as I get the shed 2 paychecks from now (prebuilt building vender most likely).
It's quantity vs quality I guess. Subjective as usual too.
User avatar
TheAbandonwareGuy
Postby Private_Ops » 2018-1-04 @ 03:13
Finished my "modern" retro box (for games all the way to about 2009).
Shuttle XPC SK22G2 (Via 890 chipset)
Athlon BE-2400
4GBs DDR2-800
Ati HD 7670 1GB GDDR5 (An OEM card, 7750 refused to work in this box)
Western Digital 500GB Black
SATA DVD-Burner
Windows XP SP2
Will have to make a seperate post in the System Specs thread to show it off.
I can't decide on any single machine specs to put here.
User avatar
Private_Ops
Postby Ozzuneoj » 2018-1-04 @ 04:35
This is semi-retro... only because it involves a PC I built in 2008 that is still used heavily. My sister has been running out of space on her PC since she got a new camera several months ago. She takes tons of high res photos and videos. The system is actually based on my first dedicated HTPC in a really sweet little Athenatech micro-ATX desktop case. Funny thing I've noticed... there are a lot of arcade computers that use this case, sometimes ones made to replace Quantum3D Graphite systems. They are somewhat similar in size. :)
Anyway, the system now contains an Asus M3A78-EM AMD780G board (original), was upgraded last year to a Phenom II 840T (from an Athlon X2 5050e), 4x2GB DDR2-800 (had 2x2GB before, and I actually found another 2x2GB of the same low profile DDR2 recently for a perfect match), Sandisk Ultra 240GB SSD + WD Blue 2TB HDD (had only a Seagate 7200.10 250GB before), Geforce GT 520 (had an 8600GT which is getting pretty outdated driver-wise... this should be perfect), FSP micro-ATX PSU (350W bronze unit I believe... replaced the original Sparkle unit that died 6-7 years ago). The thing runs beautifully now! And if she ever needs a newer system, the SSD and HDD will migrate over easily.
From retro to modern with a few upgrades. :)
User avatar
Ozzuneoj
Postby luckybob » 2018-1-04 @ 04:40
Well, I made my whole garage REEK of ozone today. I'm conducting some "experiments" with the retrobrite cream. Results are so far disappointing, but not entirely surprising. Once I get things a bit more hammered out, I'll share some details.
I just need to borrow someone's oxygen concentrator for a bit...
User avatar
luckybob
Postby Ozzuneoj » 2018-1-04 @ 05:10
luckybob wrote:Well, I made my whole garage REEK of ozone today. I'm conducting some "experiments" with the retrobrite cream. Results are so far disappointing, but not entirely surprising. Once I get things a bit more hammered out, I'll share some details.
Please do share. I've been thinking about getting an ozone generator and a UV light and cobbling together some sort of retrobritening apparatus. It'd be a large bag filled with ozonated air containing a box. The box would then be lined with something very reflective and would have a UV light in it. I can't really use the outdoors for this kind of thing. Its like 0F and cloudy here right now and will be until probably March... :lol:
User avatar
Ozzuneoj
PreviousNext
Who is online
Users browsing this forum: BLEXBot [Bot], cyclone3d, Exabot [Bot] and 16 guests
