Reply 7760 of 27453, by Ozzuneoj
- l33t
wrote:Installed the MediaVision Pro Audio Studio 16 card into my Socket 370 system with success after changing the IRQ and DMA to be set to ISA legacy and disabling the on-board audio, but in Windows 98SE, the sound effects are playing way too fast (about 10x faster), and I have the clock set to use the one that's on the card with the MS-DOS driver and set as 28MHz clock in Windows to no success. In MS-DOS mode, it works without issues, especially with the Sound Blaster settings (works in MS-DOS prompt in Windows as well).
I believe this is related to the power supply not having a -5v rail. See here: ISA Cards & Devices Requiring -5V
For my retro activity I tested out a Diamond Monster Sound MX400 and an Aureal Vortex 2 SQ2500 I obtained recently. I had to replace an SMD cap on the MX400 after I got it, but both cards were in overall excellent condition. I'm happy to say both cards work great! I tested a couple games that have DS3D or A3D support and they sound fantastic in both. I must say, I really miss Aureal. Using A3D with headphones is something else. I did notice that switching to headphone mode rather than "satellite speakers" makes things sound MUCH better in general in A3D games. I always liked the effects of A3D but there was always something a little bit off about the placement and volume level... switching to headphone mode, even with stereo speakers, seems to make things sound ten times better.
I also tested out my Diamond Stealth III S540 Extreme (Savage 4 Pro at 166Mhz). It seems like a pretty nice card overall. Its certainly no Voodoo 3 or TNT 2, but in the games that work well with it, it runs extremely well for an "underdog" card. Descent III didn't like it much, but Need for Speed High Stakes ran great. 😀 I like all the crazy Windows desktop options it provides and the 2D quality seems top notch. I also had no problems at all running it on a Dell 1907FP LCD, where as most cards I've used have required that I go into the monitor's settings and force it to "auto-adjust". This one had no alignment issues in anything I ran.
Biggest problem I had was dealing with crashes and freezing due to leftover non-PNP sound card drivers being loaded with Windows 98SE. I had to go into the system.ini (did it through msconfig) and uncheck a few stray items related to an old SoundGalaxy BXII I installed some time last year. After I did that, the SQ2500 worked like a dream. I was about ready to blame my 440BX for having the absolute worst IRQ\IO handling I've ever seen, but it turned out to be a software problem. Its too bad there isn't a reliable tool to reset and remove all non-standard drivers and registry entries from Windows 98. I'd be totally fine having all of that stuff wiped back to the way it was when I first installed the OS, but I don't want to lose all of the game installations on my test system.
