Best 386 Motherboard?
Reply 80 of 287, by Anonymous Coward
SiS made a pretty good chip, but things started to change during the Socket 7 era. PCI killed off quite a few of the players in the chipset industry, and the Intel Triton chipset pretty much finished off whoever was left. I was surprised that SiS, ALi and VIA managed to hang in as long as they did. I suspect it was largely the Asian market (and AMD) keeping them afloat.
Reply 81 of 287, by Radical Vision
Then this board is good, bcuz when i did show it, at least 4 people did tell me it is good is from ASUS, but the chipset is total trash..
But good to hear other things, as the board is in really good condition , like brand new..
Not only chipsets, back in that era many brands did die, or changed direction to other type of products..
BTW your ultimate 386 link is broken, fix it, i was interesting to see the ultimate 386 build...
    686.06 KiB
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 82 of 287, by Anonymous Coward
Google killed Picasa...and along with it all of my photo comments. The photos are still available on google photo (which is a crap service). I migrated some of my stuff over to imgur, but at the moment the link escapes me.
I'm actually in the process of redesigning my Ultimate 386, and I'll create a new post when it's ready. What I can tell you is that it will most likely use an AMI Baby Screamer if the airport customs people don't confiscate it.
Reply 83 of 287, by feipoa
Radical Vision wrote:
Yeah i did saw it on my first look for it, but was not sure if that is the correct board..
Interesting to see the chipsets are SIS, that chipset brand is considered from many to be bad and not worthy..
The SiS Rabbit, SiS 471, and SiS 496 are generally well liked among 386/ISA, 486/VLB, and 486/PCI motherboards, respectively. I didn't really follow SiS much after that, though I've heard that the SiS-based socktet 4 board is faster than the intel-based counterpart. I did find the SiS 460 (ISA 386/486) to be disappointing performance wise.
Reply 84 of 287, by feipoa
Google also killed my Picasa account. They migrated it over to Google+, but then all the picasa links I had didn't work, and google messed up all the photo categories. I had over 200 folders going back to 2003. Google+ was such junk in comparison, I elected not to pay my $5/year for storage and let it all go.
Reply 86 of 287, by feipoa
Some boards like to have all 8 SIMM slots filled. To avoid uncertainty and frustration, best to source 8x1MB sticks and 8x4MB sticks. Some systems do not like 2-chip (without parity) and 3-chip (with parity) modules. So, again, to avoid uncertainty, best to source 8-chip (without parity) or 9-chip (with parity). Seems to me that I haven't had trouble getting the fastest DRAM settings working with 70 ns modules, with the exception of one motherboard (UMC 481/482 when using MR BIOS), which only handles the fastest settings with particular 60 ns modules. To help reduce frusturation, it might be nice to source 60 ns DRAM.
Reply 87 of 287, by Anonymous Coward
I always use matched 60ns 9-chip SIMMs when available.
I'm hoping to have 32MB installed in my system, but more than 16MB can be problematic in many of the boards with earlier chipsets and BIOSes. Some 386 boards can take up to 64MB of RAM, but normally they don't cache all the RAM. The only board I had that cached all 64Mb used an ETEQ chipset, but it was kind of slow.
Reply 88 of 287, by feipoa
The only benefit I can see with 64 MB on a "386" would be if using Windows NT 4.0. Will that OS run properly on a "386" with L1 cache and 486 instructions? Perhaps on a BL3 (DLC3) or TI 486SXL2?
Reply 89 of 287, by Anonymous Coward
Maybe NT 3.x would run okay. I personally wouldn't want to use anything less than a 5x86-133 on NT4.
Reply 90 of 287, by Radical Vision
That damn boards does not want to post, but i have only x6 SIMM memory sticks, so i hope it is from the need of all slots to be filled with memory..
I have other 386 board with OPTI chipset and the board want all 4 slots to have memory on them in order to post, so i guess then that is the thing here..
    557.47 KiB
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 91 of 287, by feipoa
I was under the impression that all 386 boards can only use 4 or 8 modules, and nothing in between.
Reply 92 of 287, by Radical Vision
Well the damn board wont post with 4 modules, or 2 modules or 6 modules, i did just try to see if it will post but nothing...
As my other OPTI board want all slots to be filled with memory (4 on the board) and then it will post, while with 2 sticks nothing..
But i don`t have more then 6 sticks of SIMM for now, so i can`t fill all 8 slots in order to see if this is the deal like on the smaller OPTI board i hope so, as the CPU is AMD DX...
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 93 of 287, by gdjacobs
Aren't there some freak boards that break that rule?
Reply 99 of 287, by Anonymous Coward
There are a few 386 boards that take FPM (not EDO) 72-pin SIMMs. Most of them are either PS/2s or OEM machines. I've seen a few relatively standard 386s with that configuration though. I don't know that there's any advantage of going that route unless it's difficult to get 4MB density 30-pin SIMMs.
There is one very small form factory 386 board I've seen that has four 30-pin SIMM slots and a single 72-pin SIMM slot. Supposedly it can go up to 128MB of DRAM, but unfortunately it only has 128kb cache, so you can only cache 16MB in writeback mode.
