486sx and 486dx
Reply 21 of 27, by Scali
derSammler wrote:
Yes, that would make sense. But then the jumper selects which CPU to use, and not really if an FPU is present. 😀
Well, I think that's a given... The FPU is internal, so only the 486 chip used determines whether the FPU is present or not 😀
I don't think it's possible to disable the FPU in a 486DX externally.
Reply 22 of 27, by CkRtech
Different jumper configurations for SX vs DX on a 486 is pretty normal stuff. I just assumed it was chipset related.
Displaced Gamers (YouTube) - DOS Gaming Aspect Ratio - 320x200 || The History of 240p || Dithering on the Sega Genesis with Composite Video
Reply 23 of 27, by RobertJ
Scali wrote:
badmojo wrote:
Never heard if any game taking advantage of it, could you provide an example?
Falcon 3.0 had an enhanced mode if you had an FPU.
That's the one I was specifically thinking about. It was one of my favorite flight sims of that era, and the reason I upgraded to a DX at the time.
8-bit Collection: 4 64Cs, 6 1541-IIs, 1 C128, 2 1571s, 1 C128DCR
Vintage DOS: Dell Optiplex G1, ATI Rage IIC, Sound Blaster CT4520, Thrustmaster FCS Mark II, Gravis PC GamePad
Monitor: Dell 20" 2007FPb
Reply 24 of 27, by Baoran
This is almost same as the motherboard I have: http://stason.org/TULARC/pc/motherboards/D/DT … -PKM-0037S.html
One of the differences is that one of the jumpers that is suppose to tell the cpu type to the motherboard is missing.
1.45 MiB
As you can see where the JP27 is suppose to be, there is no jumper.
Another difference is that there is winbond chip where it says "real time clock" in the picture and there is a barrel battery next to the keyboard connector.
Reply 25 of 27, by vladstamate
Another software I used a lot that required FPU was VistaPro. I still have that installed on all my retro PCs starting from 386 to Pentium III. Very fun software to play with.
YouTube channel: https://www.youtube.com/channel/UC7HbC_nq8t1S9l7qGYL0mTA
Collection: http://www.digiloguemuseum.com/index.html
Emulator: https://sites.google.com/site/capex86/
Raytracer: https://sites.google.com/site/opaqueraytracer/
Reply 27 of 27, by Scali
Baoran wrote:
Quake benchmark works 3.8 fps no matter how I set the jumpers, so no idea what the jumpers actually do.
Perhaps it's just to set the correct CPU model at the BIOS POST screen?
Does it change from SX to DX?
Perhaps you could also try running some CPU info software from Norton or such, which try to determine the CPU type independently, and see if they change based on the jumpers?
