486sx and 486dx
Reply 20 of 27, by derSammler
Yes, that would make sense. But then the jumper selects which CPU to use, and not really if an FPU is present. 😀
Reply 21 of 27, by Scali
Well, I think that's a given... The FPU is internal, so only the 486 chip used determines whether the FPU is present or not 😀
I don't think it's possible to disable the FPU in a 486DX externally.
Reply 23 of 27, by RobertJ
Scali wrote:
badmojo wrote:
Never heard if any game taking advantage of it, could you provide an example?
Falcon 3.0 had an enhanced mode if you had an FPU.
That's the one I was specifically thinking about. It was one of my favorite flight sims of that era, and the reason I upgraded to a DX at the time.
8-bit Collection: 4 64Cs, 6 1541-IIs, 1 C128, 2 1571s, 1 C128DCR
Vintage DOS: Dell Optiplex G1, ATI Rage IIC, Sound Blaster CT4520, Thrustmaster FCS Mark II, Gravis PC GamePad
Monitor: Dell 20" 2007FPb
Reply 24 of 27, by Baoran
This is almost same as the motherboard I have: http://stason.org/TULARC/pc/motherboards/D/DT … -PKM-0037S.html
One of the differences is that one of the jumpers that is suppose to tell the cpu type to the motherboard is missing.
The attachment 20180202_153440.jpg is no longer available
As you can see where the JP27 is suppose to be, there is no jumper.
Another difference is that there is winbond chip where it says "real time clock" in the picture and there is a barrel battery next to the keyboard connector.
Reply 25 of 27, by vladstamate
Another software I used a lot that required FPU was VistaPro. I still have that installed on all my retro PCs starting from 386 to Pentium III. Very fun software to play with.
YouTube channel: https://www.youtube.com/channel/UC7HbC_nq8t1S9l7qGYL0mTA
Collection: http://www.digiloguemuseum.com/index.html
Emulator: https://sites.google.com/site/capex86/
Raytracer: https://sites.google.com/site/opaqueraytracer/
Reply 26 of 27, by Baoran
Quake benchmark works 3.8 fps no matter how I set the jumpers, so no idea what the jumpers actually do.
Reply 27 of 27, by Scali
Perhaps it's just to set the correct CPU model at the BIOS POST screen?
Does it change from SX to DX?
Perhaps you could also try running some CPU info software from Norton or such, which try to determine the CPU type independently, and see if they change based on the jumpers?
