Quake 2 Crusher loop
First post, by lazaredz
I need to do some stress testing/heat generation on a project I am working on.
I remember back in the day having a way to set Quake 2 to run a Crusher loop. It wasn't via commands. I believe it was a Autoexec.cfg file I customized and ran via a shortcut on the desktop.
I cannot for the life of me find an example of this on the web nor do I recall such a small thing from 20 years ago (I am so old ...... 🙁 )
Anywho, Thx in advance
Reply 1 of 5, by uzurpator
If I recall correctly all quake games had a scripting language and an "autoexec.cfg" file on the "baseq2" ( in your case ) would be executed automatically on the game start.
For an endless loop all you need to do is to execute a file from itsself, so for an endles loop it should be something like:
demomap demoX
exec autoexec.cfg
where demoX is the demo you want to play forever, or until a stack overflow in the game, but that should happen after several hours, if ever.
EDIT: More about Quake2 console:
https://www.eecis.udel.edu/~portnoi/quake/quakeiicom.html
Die ewigkeit ist hier und jetzt.
Reply 2 of 5, by RogueTrip2012
Download the 3Finger's crusher.dm2 Crusher demo at: https://www.fileplanet.com/28888/20000/filein … usher-Benchmark
There is also a massive1 from 3 fingers: https://www.fileplanet.com/28889/20000/filein … sive1-Benchmark
-Put the demo file in the /baseq2/demos folder.
-Run Quake2, open up the console.
-Type timedemo 1
-Type cl_maxfps 999
-Type demomap crusher.dm2
-Sit back and laugh at the crazy fps you get on a modern pc.
This came up looking for looping but says quake 3. dunno if it works in q2
Put this into your autoexec.cfg:
set loop "s_initsound 0 ; snd_restart ; timedemo 1 ; demo <demoname> ; set nextdemo vstr loop"
Start Q3 and type "vstr loop" from the console.
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>Win XP . AMD 960T . 8GB . Q.K2200. SB X-Fi . 512GB SSD . 2TB HDD
> Win XI . i7 12700k . 96GB . RTX4070TI . 512GB NVME
Reply 3 of 5, by lazaredz
Thank you both. Will try this weekend
Reply 4 of 5, by lazaredz
I tried just running the crusher demo from console command to make sure things were going to work and I got the following message:
ERROR: Server returned version 30, not 26
Any ideas?
Reply 5 of 5, by uzurpator
Most likely the demo is too old for the version of the game you are running.
