Reply 21780 of 52778, by TheAbandonwareGuy
oeuvre wrote:
Those old Dimensions were pretty cool. They were built really well until around 2001 or so.
They weren't super terrible after that. Mine has an X800 Pro (which is occasionally swapped for a FX5950), 2GB RAM, and an Audigy Platinum Pro. I also added a SATA Hard Drive for game storage. Works great as a high end mid era XP machine.
Reply 21781 of 52778, by Predator99
The lot I got today is mostly junk for too much money, but at least this one is running. When I see what people pay for a Socket 4 board its almost worth the money. The CPU is from my own collection however...
1.25 MiB
629.4 KiB
Reply 21782 of 52778, by uzurpator
I had this board in my first PC. I recently even almost got one, was edged by a hair.
Madly jealous, frankly. I want my PC back 🙁
Die ewigkeit ist hier und jetzt.
Reply 21783 of 52778, by AlaricD
Does that one have the FDIV bug?
"The Big Bang. The ultimate hero of low frequency. The divine intergalactical bass drum connecting the tribes of our solar system."
Yello
"Solar Driftwood"
Reply 21784 of 52778, by cyclone3d
I am a sucker for sound cards with onboard wavetable.
This ISA ESS sound card with 1MB QDSP QS700 onboard wavetable and a wavetable header. Apparently there is a jumper to switch between onboard and a daughterboard.
I wonder how this ESS will do against Opti 930/931 cards with QDSP wavetable.. with/without real OPL3.
257.09 KiB
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 21785 of 52778, by Predator99
632.81 KiB
Yes it has. Just noticed the the nose for the cooler is broken on the socket 😵 But can still use the others...
Reply 21786 of 52778, by Predator99
For how much was it sold? 😉
Reply 21787 of 52778, by uzurpator
Offically, it wasn't. I made an offer, but the guy who was selling it replied to me that he gave it away to someone.
Reply 21788 of 52778, by derSammler
Predator99 wrote:
Yes it has.
Try Dr. Hardware, which actually tests for the bug. In that screenshot, it seems the tool doesn't even detect the presence of the FDIV opcode. Could be of course that the BIOS knowns about the bug and disables the opcode, but that's not visible by this "test".
Reply 21789 of 52778, by badmojo
That's a great looking card - excellent SB Pro 2, ESFM, and that QDSP chipset is not bad IMO.
Reply 21790 of 52778, by OldCat
Excellent haul: a rare Kontron IP-Lite Color in working condition. There are some hiccups here and there (I will post question about strange screen behaviour in some circumstances), but I have to say, it's an impressive rugged machine. Very heavy, too. Makes my Toshiba T3200SX luggable look like a proper laptop. 😎
    181.83 KiB
    469.47 KiB
    108.66 KiB
Reply 21791 of 52778, by Predator99
derSammler wrote:
Predator99 wrote:
Yes it has.
The name of the test is "test for CPU bugs". Therefore I assume the output means it has the FDIV bug 😉
Reply 21792 of 52778, by Predator99
Yep
490.54 KiB
Are they rare? I have some more P60/66 I never tested as I had no S4 board before...
Reply 21794 of 52778, by henryVK
Very cool! Looking forward to hearing more about the machine.
Because you mentioned looking for a 486 laptop, I couldn't help but notice this rare beauty in Berlin.
Expensive, but potentially worth the price 😉
https://www.ebay-kleinanzeigen.de/s-anzeige/t … 105288-278-9684
Who knows if it's still there after half a year, though.
Reply 21795 of 52778, by derSammler
Just got another great box of goodies:
CPUs
* Pentium II 350 MHz SECC2 (!) with passive heatsink
* Pentium III 650 MHz SECC2 with passive heatsink
* Pentium 200 MHz (non-MMX) with passive heatsink
* Pentium MMX 200 MHz
* Cyrix M II-300GP
* Pentium 4 1,6 GHz
Graphics cards
* 2x no-name ATi Radeon 7000 cards
* 2x Matrox G45+ cards, one with 2x VGA, one with 1x VGA and 1x DVI
* 2x ELSA Synergy II -32
RAM
* Lots of server RAM, 1 GB DDR with ECC
* Lots of PS/2 72-pin modules, mostly standard. Cool are a couple of very late 32 MB modules from Kingston
* Some SIMM modules, one is from 1986 with 150ns
* A COAST module. That one came as a surprise, as it wasn't listed. Now I have already two of these as spare parts 😀
Reply 21796 of 52778, by jaZz_KCS
@ derSammler
Any PS/2 memory that would be compatible with the L40SX laptop model? Still searching for compatible RAM, I tried adjusting and resoldering some RAMs to make them compatible, without any success.
Reply 21798 of 52778, by jaZz_KCS
It uses FPM 80ns true parity (36bit?) proprietary SIMMs
There were 2, 4 and 8MB modules available.
ThinkWiki -->
"2MB fest eingebaut
Aufrüstbarkeit mit SIMM 80ns mit Parity auf 18M (2 Steckplätze à max. 8 MB) - es waren 1, 4 und 8 MB Module erhältlich
Maximal also 18MB"
There are a few restrictions, as for example you cant use 2x 4MB sticks, that simply doesn't work. So optimally I am looking for 8MB + 4MB or 8MB + 2MB, or even 8MB + 8MB. I would even be happy with one 8MB that works. But this machine is VERY picky.
If you put in 8MB + 8MB then together with the 2MB integrated it would have 18MB total, cutting off the last 2 to get down to 16MB to make it work with the machine.
More info
http://www.google.de/url?sa=t&rct=j&q=&esrc=s … jyKS1L7hTdbLcyu
http://www.google.de/url?sa=t&rct=j&q=&esrc=s … 1jdIkRT0A5eNVE7
