First post, by buckeye
In prep for a Voodoo 2 sli setup wanted to look into maybe modding this case for adding more fans but it may not be practical. Anyone think I might be better served going with a black case with fans since they're so plentiful? See pics and let me know what u think.
    1.42 MiB
    1.98 MiB
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 2 of 5, by ODwilly
You could drill holes for a couple 60mm exhaust fans on the back of that beige case it looks like. You can spend $30 or so on some nice ones and be done with it. Love the look of that case btw.
Reply 3 of 5, by Auzner
A 120mm would fit for the rear.
Depending on how the design is, cut the back and hammer it flat. Then hammer a new 90 deg edge and rivet it back on. Many ways to do it with scrap metal and rivets.
67.85 KiB
Reply 5 of 5, by torindkflt
Some options that require no physical modifications to the case whatsoever would be fans on the front that fit into one of the unused 5.25 drive bays, plus an exhaust fan that mounts in one of the unused expansion slots, as shown below.
46.77 KiB
Drive Bay Fans
22.5 KiB
Slot Fan
One downside to this I learned from experience is that the fans in the drive bay can be quite annoying, because small size means faster speed to move the same amount of air...multiplied by however many fans are in the fixture. But, like I said, at least it would require no actual modifications to the case. If you have the size adapter brackets to do so, you could even mount the hard drive in that same bay and you'll get the extra benefit of the bay fans helping keep the drive cool.
