DOSBox Icon
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
DOSBox Icon
Postby robertmo » 2005-8-15 @ 14:31
It is a box.
It is old.
It reminds many games like: Alone in The Dark, Monkey Island, Heroes of Might and Magic, Betrayal at Krondor, etc.
DOSBox is actually a treasure chest, full of different emulated sound cards, graphic cards etc.
And it allows us to play our old treasures - old dos games.
And it looks nice.
icon.zip
(43.75 KiB) Downloaded 3647 times
User avatar
robertmo
Re: DOSBox Icon
Postby DosFreak » 2005-8-15 @ 14:43
Well it's simple, easy to understand but I dunno....Personally I think "chest" when looking at it...and I see your point about it being a treasure chest. Mabye I'm just overanalyzing.
Game Acronym List
DosBox CVS Builds
DosBox Feature Request Thread
DosBox FAQ
PC Game Compatibility List
"Who's got time to read all the way down to the bottom of an email?"
User avatar
DosFreak
Re: DOSBox Icon
Postby ChaosFish » 2005-8-15 @ 14:45
Nice concept.
I think, though, an icon shouldn't have much "hidden meanings". Although it's cool, it doesn't remind me anything of DOS at first sight, and first sight is the most important thing about an icon.
So if you could make an icon that somehow combines a box and DOS at the same time, I think that would be better.
Just my 2 israeli shekels ;)
User avatar
ChaosFish
Re: DOSBox Icon
Postby eL_PuSHeR » 2005-8-15 @ 16:52
It's nice and sure it holds some work involved but I agree with what ChaosFish said...
And moving to DOSBox General, by the way (what has this to do with Development?)
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
User avatar
eL_PuSHeR
Moderator
Re: DOSBox Icon
Postby robertmo » 2005-8-15 @ 18:43
I agree that it should have both dos and box.
Although if you look at other icons it is not that often used.
Generally the icon is so small that it mostly allows only 4 things:
1. A large letter - it could be "D"
-Opera has "O"
-Internet Explorer has "e"
-Alcohol has "A"
2. Part of a name or the whole name - it could be:
DOS
BOX
-LanChat
-Gens
-mIRC
3. A picture - can be a box
-ACDSee has an eye
-WinRAR has books
-Total Commander has a floppy
-eMule has a mule
4. Combinations of two pictures also exists
-Nero has a CD in flames
-WinImage has a floppy with a camera
5. As a DOS part is rather abstract so it requires a combination of a picture and text which is rather difficult.
icon2.zip
(44.31 KiB) Downloaded 2336 times
User avatar
robertmo
Re: DOSBox Icon
Postby avatar_58 » 2005-8-15 @ 19:16
I personally use this
User avatar
avatar_58
Re: DOSBox Icon
Postby Dominus » 2005-8-15 @ 19:54
just to be nitpicky, Nero has the burning Colloseum :)
User avatar
Dominus
DOSBox Moderator
Re: DOSBox Icon
Postby Targaff » 2005-8-15 @ 22:27
avatar_58 wrote:I personally use this
And do you have it in an icon format? ;)
Mine's similar, actually - just a black box with a c:\> command prompt in it.
Intel CC820 | PIII 667 | 2x128MB SDRAM | 3Dfx Voodoo 5 5500 @ Dell P790 | Creative SB PCI128 | Fujitsu MPC3064AT 6GB + QUANTUM FIREBALLlct10 10 GB | SAMSUNG DVD-ROM SD-608 | IOMEGA ZIP 100 | Realtek RTL8139C | Agere Win Modem
User avatar
Targaff
Re: DOSBox Icon
Postby ChaosFish » 2005-8-15 @ 23:05
How about an open box, that has:
C:\>
Lying diagonally in it?
User avatar
ChaosFish
Re: DOSBox Icon
Postby Gene Wirchenko » 2005-8-15 @ 23:27
[quote="ChaosFish"]Nice concept.
Just my 2 israeli shekels ;)[/quote]
What about a building block viewed from one corner with one letter on each visible face? Now, modify the block so that it is a cardboard box.
Sincerely,
Gene Wirchenko
Gene Wirchenko
Re: DOSBox Icon
Postby DosFreak » 2005-8-16 @ 00:03
Suggestion:
An Icon with black background and white text that say's "DosBox"?
heh. Original.
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Re: DOSBox Icon
Postby avatar_58 » 2005-8-16 @ 04:15
I got a little bored...
dosboxico.zip
(1.74 KiB) Downloaded 2915 times
User avatar
avatar_58
Re: DOSBox Icon
Postby ChaosFish » 2005-8-16 @ 13:26
avatar: You're in the right path! Just need to make the box more "box like" and having it all a bit more realistic and you're there!
User avatar
ChaosFish
Re: DOSBox Icon
Postby avatar_58 » 2005-8-16 @ 18:54
ChaosFish wrote:avatar: You're in the right path! Just need to make the box more "box like" and having it all a bit more realistic and you're there!
I could, problem being is that at such a small size an icon is a little hard to detail. (In other words that was a real box in its original size but once I shrunk it down it was hard to see) :sweatdrop:
User avatar
avatar_58
Re: DOSBox Icon
Postby DosFreak » 2005-8-16 @ 18:56
B
DOS
X
Dangit, the B over the O in DOS and the X under the O. Too lame?
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Re: DOSBox Icon
Postby HunterZ » 2005-8-16 @ 19:59
Use the code tag:
Code: Select all
 B
DOS
 X
You're perfect, yes it's true...but without me, you're only you.
User avatar
HunterZ
Re: DOSBox Icon
Postby robertmo » 2005-8-16 @ 20:04
Gene Wirchenko wrote:What about a building block viewed from one corner with one letter on each visible face? Now, modify the block so that it is a cardboard box.
DosFreak: no nead to repeat others' ideas ;)
User avatar
robertmo
Re: DOSBox Icon
Postby DosFreak » 2005-8-16 @ 21:09
Didn't see that one but I was just thinking one face whereas that one uses a 3 dimensional block?
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Re: DOSBox Icon
Postby Qbix » 2005-8-18 @ 11:53
HunterZ wrote:Use the code tag:
Code: Select all
 B
DOS
 X
anybody able to translate this into an icon ?
Wonder how it will look like.
Water flows down the stream
User avatar
Qbix
DOSBox Author
Re: DOSBox Icon
Postby ChaosFish » 2005-8-18 @ 17:21
I made this. It lacks quality, so think of it as an icon idea :)
The space inside the "O" is transparent (i.e. you can view the desktop through it)
User avatar
ChaosFish
Next
Return to DOSBox Development
Who is online
