First post, by GabrielKnight123
Hi all Ive been looking at my Dos book and an advanced boot disk that has options for things like booting up with EMS on or off or CDrom on or off and I did what I could and got it half working but when I select the option for the EMS it does that right but skips the options for which mouse program, here is what I have im using Dos 6.2 for the boot up options
Config.sys
[MENU]
menuitem=EMS, Start PC With EMS Ram.
menuitem=NOEMS, Start PC Without EMS Ram.
[COMMON]
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
[EMS]
DEVICE=C:\DOS\EMM386.EXE RAM AUTO HIGHSCAN I=B000-B7FF
[NOEMS]
DEVICE=C:\DOS\EMM386.EXE NOEMS HIGHSCAN I=B000-B7FF
[COMMON]
DEVICE=C:\CTCM\CTCM.EXE
DOS=HIGH,UMB
DEVICEHIGH=C:\CDROM\oakcdrom.sys /D:mscd001
FILES=80
BUFFERS=60
[MENU]
menuitem=MOU1, Start PC With Mouse.com
menuitem=MOU2, Start PC With BBBMouse.com
[MOU1]
[MOU2]
Autoexec.bat
Soundblaster settings as normal
PROMPT $P$G
SET PATH=C:\DOS;C:\MOUSE;C:\CDROM
SET TEMP=C:\DOS
LH C:\CDROM\MSCDEX.EXE /D:mscd001 /L:D
if %CONFIG% == MOU1 LH C:\MOUSE\MOUSE.COM
goto end
if %CONFIG% == MOU2 LH C:\MOUSE\BBBMOUSE.COM
goto end
:END
Im not very savy with programming but all help will be appreciated.
