First post, by ahtoh
I'm running AMD K6-2+ 500 Mhz CPU with ga-5smm motherboard based on SiS 530 chipset.
When using integrated graphics, I benchmark quake1 @640x480 in software mode at 25 fps (and it matches the other results I found online)
When I plug in my Voodoo 3 3000 PCI the same software benchmark end up with 11 fps.
Every other 3dfx game fps benchmarks like I have a pentium-200 ish CPU.
Is there a way to fix this?
I want to run my voodoo 3 at full speed
