Dune Help
First post, by Guest
I am having a lot of trouble getting this game to run. When I tried installing it, it said that what the program uses to test speed or something doesn't work on my machine or whatever. So, I have no idea what that means.
When I try running Dune off the C drive that I mounted, all that comes up is a black screen and DOSBox freezes up.
What should I do? This is so confusing. 🙁
Reply 1 of 8, by Guest
Here is the message "Sorry...the system that I use to measure time doesn't seem to be reliable on your machine."
It says that when I try running the game from the CD-ROM which you have to in order to play.
This us using the new 0.63 version. Should I try an older version?
Reply 2 of 8, by BadLife
Not sure what the problem is but I have the Dune version that came on 5.25" floppy disks and it runs fine. Is this the very first Dune game not Dune 2 which was sort of the first RTS?
Reply 3 of 8, by HunterZ
I've been able to get both floppy and CDROM versions of Dune 1 (and Dune 2) working fine in DOSBox. I don't remember if I got that warning or not, but try telling it to ignore it if it gives the option to - it certainly won't hurt anything to try.
Reply 4 of 8, by Theboss
I got the same error but its works fine though, just ignore it and run setup to complete install and you're off.. I have 2 different cd versions of Dune and they both work fine 😀
Reply 5 of 8, by HunterZ
Theboss: Just out of curiosity, what is the difference between your two CD versions of Dune?
Reply 6 of 8, by MATT091282
Well nevermind I solved the problem. I was running the installation from the local drive the whole time instead of the CD! 🤣! I felt like such a goof. Well anyway its great to play this game again! 😀
Reply 7 of 8, by Theboss
HunterZ: Besides the different cd gfx, one is a orange cd with dunes and the other just a silver cd with text displayed on it, they seem the same expect that I cannot load savegames if switching cds 😦
MATT091282: its a cool game! I recently played it again, great old memories from when I played it on the Amiga.
Today I got in Dune 2 orginal cd so another gaming round seems in place 😁
Reply 8 of 8, by HunterZ
Theboss: Strange... Maybe one of the versions comes with a patch already installed? I checked dlh.net and they only have a Pro Audio Spectrum 16 fix listed under patches for that game.
